Here she is, finally got her out last weekend. I can only describe the ride as fast, efficient yet comfortable, coming off a 29er hardtail/s for many years I am really appreciating some rear suspension again. I can't see any penalty over the hardtail, this bike seems to match the performance with the added benefits or rear suspension.
Weight is a nice 21.5 lbs so it has ended up lighter than my hardtails, probably has a fair bit to do with the Keronite SID which is superb.
Thanks dudes.
Just some additional notes. It's setup with a 100mm fork, for those that like a bike that carves single track this one does that. Handling is tight and direct which I really enjoy but in no way is it scary, it's great for racing. With a -6deg 90mm stem I have found that on granny gear climbs even with grades at up to 27% the front end barely wants to wander. New XTR shifting is very direct and very positive, best I have ever experienced, super snappy. The XX Keronite fork is smooth and precise too, I really like the hydraulic lockout but I am still playing around with the perfect -ve +ve settings. You can run the Kashima rear shock in the wide open '0' sit and spin with no visible bob. If you like to mash out of the saddle, run it in propedal position '1' to still enjoy a nice plush rear end but no visible bob when out of the saddle, works for me. The J9RDO frame is stiffer than my hardtails so this I am sure is helping the handling a fair bit as is the 15mm front axle. The maiden ride was over 100km too so it did get a very thourough testing. eXC Beavers didn't like being run tubless, they both front & back had their sidewalls tear on rougher sections of track, unlike my Karma's which seem to be bullet proof. I really liked the way the Beavers rolled though but tubes only. I am really pleased that the bike can take 2 bottle holders & 2 full sized bottles, this is rare on a dually let alone a 29er dually. I suggest the King Cages for best results also, frame size is a small.
It's the World Cup SID XX, it weighed 1490 grams with a cut steerer. The seat tube is MSC's carbon titanium, not the lightest but it's cut down as well. Weight is as you see it in the photos but with stans 29er 'race' wheelset, Kenda Karma's and 90 mls of stans in each tyre.
I confirmed the weight on two different digital scales and there was only a 20 gram difference between the two. I don't consider the parts to be overly weight weenie either for my weight of 73kg, there could be weight shaved elsewhere on the bike and myself , it's a triple ring crank too. Brakes are Formula R1's with carbon levers, nice brakes to use. The wheels in the photo are my training wheels which are stans crest's which make the bike a little heavier of course by roughly 200-300 grams I'm guessing, still pretty light considering it includes chain stay protector, der hanger, all shock hardware, bottle cage bolts and frame protection which comes standard with the Niner and it's very nice to have frame protection included with the frame from the factory.
I'm pretty sure there are a few of us still on triples. On a 29er with grades which can average 18% & kick to 27% and longer miles a triple is absolutely needed. Without going into ratio comparisons between doubles & triples, a triple makes the bike more versatile. Shimano 10 speed crank with 24t granny is closer to 32t middle now so shifting from granny to middle is really efficient. I also prefer to spend more time in a 32 that 26 or 28, 32 is more efficient I find.
That pic is the reason I haven't bought another XC bike yet... I really need to find someone in Miami that has one of these beauties that I can ride, even if it's in a parking lot, lol...
I can't buy a bike without at least a test ride...
I have everything ready.. XTR group components, Roval Carbon Rims w/ Schwalbe Racing Ralph Tires, FSA Carbon Bar etc., ready to install but no bike to sample... AMAIZING !!...
That has to be one of the nicest builds I've seen... Congrats to you !!!:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
I replied to your other thread; I am racing the bike this weekend, lots of climbing and it's mostly lots of tight single track so I will report next week but so far I can't fault the bike other than it's made of carbon Those parts you have would make a very sweet build!
I would bet many RDO owners bought without a test ride or even seeing the frame in person. I don't think I have heard of one RDO owner who has been disappointed.
Hey BB,
Wow, that was a while ago!
That original Juice cracked, it was replaced under warranty OK so I sold the replacement frame as new and bought a Niner One 9 to take it's place. The Juice was a great bike even though it's a simple steel frame, very special sort of ride.
Yeah, it's definitely 21.5 lbs - confirmed that on two different digital scales and the difference was only a few grams. It could go lighter too, go a double crank, new XX grip shift, lighter seat post etc. There is one chap that built a large J9RDO and it is only 9.4kg, seen it on Niners Facebook Page, it has some funky Euro parts on it but that is damn light.
Sick Bikes, im building one up an RDO soon, does anyone know the correct Q factor for XX crankset and XX front deraileur part number for the RDO? Thanks
I wavered back and forth between the Rockshox SID 100mm and the Fox 120mm shock. In the end I took the 1# weight penalty and went with the Fox because I can easily choose between 120mm and 95mm. Fox is very easy to setup and I like that it matches the RP-23 rear shock.
I'm extremely impressed with my Terralogic fork so far. It's slightly heavier, but the performance is quite remarkable, doing exactly what it's supposed to - staying nice and stiff on climbs and under hard cranking, and then immediately soaking up any actual bumps. Nice not to have to lock it out manually. I was a bit skeptical about it, but so far quite pleased.
I just want to write a little bit more about the J9RDO - Now having done another solid ride on it since the rains have paused I am even more impressed with the bike now if that was possible. The trail I did was mostly rocky, quite rough up and down so plenty of variety. I have also done this trail so many times I have lost count so I know it very well. The J9RDO was fast, in fact 10 mins faster than my fastest ever time on a hardtail 29er but that would makes sense since this track is rough. What I really loved though was how easily the J9RDO handled the rough climbs and rough single track, it's a dream come true. After 70km of riding that stuff I was still feeling fresh! It may be totally fitness or coincidence but the longer the ride went on the further away I got from my riding buddies, these are fit guys, I have to work and struggle to stay with them on road bikes but I feel that with the help of the J9RDO I had that little bit extra that made a huge difference on the trail. To put simply, the bike climbs like a hardtail but when it gets rough it knows how to look after you - what more can I say other than if you are on the fence don't wait, just get it if you like to go quick! I truly love mine and would even buy another if I could!
new to posting, based in Rotorua, New Zealand, where muzzanic does most of his riding. Have been riding a SS SIR9 for over 3 years, just bit the bullet and purchased nice Jet9 RDO in stealth colours. Running 1x9 with E13 cranks and chain guide, white brothers loop 120, racing ralphs (FR 2.4 rear 2.25), niner carbon bars and post, niner stem. Eating up lots of miles quickly and loving it.
Coming off HT SS, I had been worried it wouldn't climb so well but after over 12 hours of riding in last 8 days have put that worry to bed. Mine isn't super light like a lot are posting (I am guessing 24 lb's) but is a practical build for this area and just performs amazingly well.
How bout some description on your ride... Some of us haven't had the privilege to ride such a beast in the way it should be ridden...:thumbsup::thumbsup::thumbsup:
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
