Results 1 to 6 of 6
    Oct 2013
    Cool-blue Rhythm Jet 9 RDO move to 142X12 rear axle
    Hi Niners,
    Can someone tell me when did Niner move to 142X12 rear Axle?
    Was it the 2012/2013/2014 model?
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    They changed it on the 13/14 models All the Green Jet9 RDO's are 142x12 & all the Black ones with carbon shock rockers are 142x12.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Oct 2013
    New question here. Move to 142X12
    Quote Originally Posted by muzzanic View Post
    Thanks for the reply can you answer this as well.
    I just bought a demo bike from my LBS.
    it is the black and white model.
    my LBS said the frame is the 2013 model that was assembled March 2013.
    The rear axle is a regular 135X10 and not the 142X12.
    Does it make sense or is it the 2012 model frame?
    Jun 2010
    The Black/White all have 135x10. Does not matter when they were produced. Niner does not work with modelyears btw so it is hard to determin when it was produced. I guess they can check it with the serial number though.
    Carbon & Ti rule
    Quote Originally Posted by sand0kan View Post
    This.
    I'm not sure when the stopped making the Black & White, My wife's was made in 12.
    They my well have made your frame early in 13, But it is what most of us call a 12 model, Even though Niner doesn't do model years.
    Oct 2013
    Good job!
    thanks!
    i will indeed check with niner.
  1. Rear axle mismatch 142x12?
    By RezaKalimantan in forum General Discussion
    Last Post: 07-25-2014, 10:47 PM
  2. Scott Genius 740 - Which rear 142x12 axle?
    By jploski in forum Scott Sports
    Last Post: 11-29-2013, 09:31 AM
  3. Carbon hardtails with a 142x12 rear axle?
    By savechief in forum 29er Bikes
    Last Post: 10-25-2013, 01:32 PM
  4. chinese carbon HT frame with 142x12 rear axle?
    By simpy16 in forum 29er Bikes
    Last Post: 11-17-2012, 06:34 PM
  5. Replies: 1
    Last Post: 03-08-2012, 09:38 AM
