Page 5 of 5 FirstFirst 12345
Results 401 to 415 of 415
  1. #401
    Feb 2013
    Crack on the seattube - the only lucky one?
    Dears
    few month ago I noticed this crack on the seat tube. Bike bought in February but it's a 2014 frame that was almost unused.
    The seatpost was clamped correctly and I'm not such overweight to justify this...I'm the only lucky one?
    Frame still in warranty period but purchased not new and before going to the dealer asking for support I'd like to know if I'm the only one or same thing happened to someone else...
  2. #402
    Reputation: G-Choro's Avatar
    Quote Originally Posted by bertello80 View Post
    Dears
    Let's see...Click image for larger version.
    May just be clear coat flaking
    Sent from my XT1254 using Tapatalk
  3. #403
    Feb 2013
    Quote Originally Posted by G-Choro View Post
    NO, unfortunately not since you can feel and see the crack also from inside ....
  4. #404
    Ouch, that's too bad.
    Speaking with a Niner dealer will be your best bet. Niner warranties are not transferable, so by the book the frame wouldn't be covered if not bought new from a dealer, but maybe they'll make an exception.
    Sent from my SM-N920V using Tapatalk
  5. #405
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Is that the right size seat post ? 31.6
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
  6. #406
    Quote Originally Posted by muzzanic View Post
    It looks a little pinched, right?
  7. #407
    Carbon & Ti rule
    It does a little, I have brought seat posts in the past that have been marked 31.6 but measure 30.9
    It can be a trap.
  8. #408
    Feb 2013
    It can be a trap.
    No, seatpost is the right diameter 31,6.
  9. #409
    May 2015
    this Jet 9 RDO are damm easy 'cracked' frame, my down tube already 2 cracked. But my country distributor just don't want do any responsibility on the frame, i just told by the distributor my frame is 'UNDER ATTACK !!!'. WTH big jokes, my bike just less than 500miles.
  10. #410
    Dec 2011
    Downtube crack?
    Just noticed this crack at the top of the downtube on my black and white Jet 9 RDO. I plan on bringing it in to the local Niner dealer this week but I'm not the original owner. Any ideas on if this could just be a paint crack. Is the bike safe to ride?
  11. #411
    Reputation: pharmaboy's Avatar
    That looks like a carbon crack to me because it's through th white paint as well as the black clear coat section. That isn't the classic spot where the frames were failing due to manufacture error either - I'd imagine they will say that's from something like a drop off / jump to flat landing.
    If it's not making noise, then personally I'd continue to ride it, BUT, I'd also find a carbon repairer to patch it as well. Carbon seems pretty easy to repair, and cheap as long as you don't get the whole frame painted as well. They sand it back, scratch out the crack, then layer carbon and epoxy over it - not to different to repairing fibreglass as a process.
    That's assuming niner say no deal on warranty as the non original owner
  12. #412
    Reputation: HouseNotes's Avatar
    That's definitely a frame crack! I would be VERY careful riding it.
    Single Track Rules!
  13. #413
    Feb 2013
    Real crack or just cosmetics/paint
    Any idea if this is just a paint crack or real frame issue? Unfortunately I'm the second owner so..."goodbye"....unfortunately this s the rule Jet 9 RDO Frame Crack-whatsapp-image-2017-02-14-20.22.46.jpgJet 9 RDO Frame Crack-whatsapp-image-2017-02-14-20.22.47.jpg
  14. #414
    May 2012
    Any idea if this is just a paint crack or real frame issue? Unfortunately I'm the second owner so..."goodbye"....unfortunately this s the rule Click image for larger version.
Name:	WhatsApp Image 2017-02-14 at 20.22.46.jpg
ID:	1121524Click image for larger version.
Name:	WhatsApp Image 2017-02-14 at 20.22.47.jpg
    That is a crack in the carbon. And just FYI, if your dealer talks nice when they call in then they typically offer "crash replacement" pricing to the current owner of any frame. I've even had customer upgrade to newer versions of the same frame.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
  15. #415
    Feb 2013
    Quote Originally Posted by PeopleForScience View Post
    Yes, I had this but anyhow it's a approx 30% on the full price of the frame...so 2719....no way...
  1. SIR 9 Paint Crack or Frame Crack??
    By AaronJobe in forum Niner Bikes
    Last Post: 01-04-2013, 10:19 AM
  2. Replies: 45
    Last Post: 01-26-2012, 09:17 AM
  3. paint crack or frame crack?
    By fujibikeben in forum Frame Building
    Last Post: 10-16-2011, 07:53 PM
  4. Frame crack?
    By thickfog in forum Fat bikes
    Last Post: 07-03-2011, 06:29 PM
  5. Frame crack or paint crack?
    By Rad Rider 415 in forum Niner Bikes
    Last Post: 05-06-2011, 07:20 AM
Members who have read this thread: 10
