Page 14 of 17 FirstFirst ... 4 10 11 12 13 14 15 16 17 LastLast
Results 326 to 350 of 412
  1. #326
    Reputation: ejreyes6's Avatar
    Dec 2010
    Jet 9 RDO Frame Crack
    If you bought a RDO you should get a RDO regardless. Isn't the MSRP the same?
  2. #327
    The MSRP has gone up about $400 or so from version 1 with the addition of the thru axle and carbon rockers. The Jet Carbon's MSRP is about the same as the Jet RDO V1 and is basically the same bike with revised cable routing and a revised seat tube that hopefully won't break.
  3. #328
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by epiphreddy View Post
    If it was me & I had a 2012 Jet9 RDO ( top of the line at the time I brought it ) & it cracked, I wouldn't be very happy having it replaced with the Jet9 Carbon.
    Even though the Jet9 Carbon is the same frame, All be it with a lesser shock.
    I would be happy to put my old shock & alloy rockers on a new Jet9 RDO front & rear Triangle. If I had to, But would do what ever I could to keep the RDO on the bike.
    I replace my bikes quite often & need the most money I can to do this, I would like my chances of selling a second hand Jet9 RDO for more than a Jet9 Carbon.
    Raising money, my friend broke his neck Mtbing, Please Share link. http://givealittle.co.nz/cause/elliottkeys/donations
  4. #329
    Have there been any reports of the new Version 2 frames cracking at the seat tube like the Version 1 frames? By V2 frame I mean the one with new cable routing and also 142 rear thru axle.
  5. #330
    I see an obvious line of some sort from the bolt downwards, no play though. Planning on calling Niner about it tomorrow, but given the five year warranty, they do much better than others in covering their frames. Called Competetive about it, they are sending me the warranty form, and I will bring it by a shop. Again, I am don't think it is there, but given the location of what could be just a clear coat/paint crack, I am having it checked out.
  6. #331
    I don't think I was screwed.
    I bought mine on close out originally.
    The new one has been built up, but it has been sitting in the garage because I have been using my SS all season.
    I will ride it at the Firecracker 50 I think.
    Now I am in road bike mode.
  7. #332
    Reputation: ch13f's Avatar
    May 2014
    New Jet 9 RDO Seat Tube Crack XX1
  8. #333
    May 2014
    Photo up above is of my new dream bike. This bike is heaven on the trails around here and begs to go faster than I am capable. Never wrecked, this was my 9th ride on it and about 70 miles total. As I started up an incline I heard a pop and this was the result. I also lost a pivot bolt as you can see at the bottom just left of the chainring. Sucks donkey balls! I called up my LBS and they assured me all would be taken care of promptly Monday morning. I've been dealing with them for years and I know this to be true. I'm glad Niner takes care of their customers so well and am confident they will do the same as in all other cases. I'm 238lbs and am well within the rider weight limit Niner post in their online encyclopedia of a 295lbs. Our trails here in Louisiana ain't nothing but rooty single-track. No drops are descents.
  9. #334
    I Tried Them ALL... Moderator
    Reputation: Cayenne_Pepa's Avatar
    Quote Originally Posted by ch13f View Post
    That's gnarly.
    "The ONLY person who needs to race.....is the entrant"
  10. #335
    So it appears that the even the new RDO frames are doing the same thing? Ch13f, what size of bike is this and how much do you weigh all geared up? Just curious...
  11. #336
    May 2014
    This is a size large and I put my weight earlier. I don't ride with a hydration pack or tools of that sort. All my local Trails are located in parks. I do carry a pack when I go ride away from home but haven't had a chance as of yet. I was still getting used to the dynamics of the bike.
  12. #337
    Yup, just look at ch13f's pic above, that is a new frame with the carbon rocker and notice the cable routing is the new.
  13. #338
    May 2014
    I'm back on the bike again. My LBS Bicycle Superstore of Lake Charles, LA had everything filled out for warranty when I brought my bike to them Monday during my lunch break. And by Friday they had received the new frame and built up my bike and had it ready for pick up. After I got off work I burned a couple laps. Niner warranty was excellent and my LBS really looks out for their customers.
  14. #339
    Jun 2014
    So my love hate relationship with my Niner Jet 9 RDO continues. This bike absolutly rips when tuned and is so damn pretty to look at and then it always seems to crack....Has anybody seen a crack in this location? Obviously you can see a tear where the protective tape is on the undercarraige due to some kind of impact. Im clueless as to what hit my frame and to make matters worse, this is my 3rd green/black Jet 9 RDO since last July. Last two have cracked where everybody elses's have cracked and I've only had this current frame three months.... It seems Niner fixed the frame design with stronger carbon placment as this one has yet to crack behind the shock like everybody else's and now this. Local bike shop has has no problems getting the last two replaced for me however this time with the impact mark, Niner has declined replacing it.... Anybody have any thoughts or suggestions.
  15. #340
    Reputation: pharmaboy's Avatar
    Does look impactish. Just keep riding it - there are always howls from people who think carbon explodes like an IUD under you, but I have never come across actual evidence of such occurrences.
    You must have at least 90% of strength there (assuming the cracks go all the way though on both sides). I wouldn't ride it if the crack opened up and you can see the inner carbon fibre, but there are repair options for carbon fibre which are superior to aluminium repairs - but it won't look as good again after repair
  16. #341
    May 2012
    The tear in the protective tape kind of gives it away as an impact. Or some kind of trauma while being stored. I wouldn't recommend riding it if you plan to have it repaired, calfee is relatively cheap. I think their most expensive repair is only like $300. That's pretty cheap compared to a new frame. And if you ride it more it will probably get more expensive.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
  17. #342
    29ers Only.
    Reputation: Niner Bikes's Avatar
    Dec 2004
    Hi Jeremy,
    Sorry to see this damage. Please make sure you bring the bike to an authorized Niner dealer for inspection. We can suggest possible solutions from there.
    Thanks,
    Nate
    Passion. Commitment. 29ers only.
    Follow all things Niner Bikes on Facebook!www.ninerbikes.com
  18. #343
    Jun 2014
    Thanks guys for your suggestions. The bike was actually picked up from my local bike shop (RBM) by MILLENNIUM BICYCLES last Friday who specilizes in custom frame builds and carbon repairs so I will post up how that turns out. I just sent you an email Nate so Im no sure if there is anything you are willing to do for me at this point since the bike was taken to a Niner dealer and I was pretty much told I can get a replacment at cost. Whether my dealer dropped the ball or not I really cant say as they had my last two replacements shipped to me in a week which I was very impressed with. Either way Im tired of riding my road bike and Im ready to get back out on the trails and I will post the outome of this great adventure.
  19. #344
    Jun 2014
    Jet 9 RDO Frame Crack-frame-repair-2.jpgJet 9 RDO Frame Crack-frame-rapair-1.jpg
    This is my first experience with carbon repair however it appears to have turned out well. For anybody wondering I paid 250 for the repair with clear coat. I opted to not have it painted for another 200 bucks thinking it would be hard to match Niner's awesome metallic paint job and figured it would add some character to my bike. Anyways I just picked up my bike and look forward to hitting the trails after work!
  20. #345
    Reputation: G-Choro's Avatar
    Hey, everyone. I've noticed my Jet 9 is starting to develop some cracks around the BB area. How frequently is this just cracks in the clear coat vs. a compromise of the carbon structure? Any way to tell?
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Quote Originally Posted by G-Choro View Post
    Pictures of these cracks might help us...
  22. #347
    Ah, yes. Of course. I will post some as soon as I get a chance.
  23. #348
    29ers Only.
    Dec 2004
    Hi, we would love to check this frame out and help evaluate what is going on - give us a ring at (877)646-3792 to talk to a real person, or email any photos to warranty@ninerbikes.com
    Thanks,
    Nate
  24. #349
    Quote Originally Posted by Niner Bikes View Post
    Thanks,
    Nate
    Thanks, Nate. Email on its way!
  25. #350
    My Jet 9 RDO cracked after 300 miles. Niner replaced the frame quickly for me. Love the bike just hope it doesn't crack again.
  1. SIR 9 Paint Crack or Frame Crack??
    By AaronJobe in forum Niner Bikes
    Last Post: 01-04-2013, 09:19 AM
  2. Replies: 45
    Last Post: 01-26-2012, 08:17 AM
  3. paint crack or frame crack?
    By fujibikeben in forum Frame Building
    Last Post: 10-16-2011, 07:53 PM
  4. Frame crack?
    By thickfog in forum Fat bikes
    Last Post: 07-03-2011, 06:29 PM
  5. Frame crack or paint crack?
    By Rad Rider 415 in forum Niner Bikes
    Last Post: 05-06-2011, 07:20 AM
