Page 2 of 2 FirstFirst 1 2
Results 26 to 48 of 48
  1. #26
    Ok, some good news. I got out for a long ride at the awesome Brown County trail system in Southern Indiana today. After four hours of riding - no creaking!
    It looks like it was likely the suspension bearings. The shop did check my cassette as well and put some extra lube on it, but considering the bearing were in such bad shape that still seems to be the more likely culprit.
    The question is - should the bearings be replaced regularly then? Maybe each season?
  2. #27
    Reputation: herothedog's Avatar
    I replace them when needed, which tends to be at about 16 months so far. For the most part I don't ride in wet conditions so that probably helps a lot. Although the last set of lower pivot bearings I went through seemed to be right after several surprisingly deep stream crossings (in which case my bb was shot as well).
  3. #28
    Reputation: pharmaboy's Avatar
    Unfortunateky, You can't assume it's the bearings because a decent mechanic would have done a thorough frame cleanup at the time - remove clean , degrease etc . Done that before, thought it was an upper pivot bearing, but it came back in a ride or 2, but the act of removing a rear wheel and tightening things while I was at it meant I couldn't tell what the fix was.
    Creaks can be massively frustrating!
  4. #29
    Reputation: kev84's Avatar
    My jet 9 has developed a knocking sound when pedaling??? Driving me crazy.
    Everything feels smooth nothing feels wrong…Just a knock or tick sound every pedal stroke. It seems to be coming from the left side
  5. #30
    Reputation: oaklandish's Avatar
    My replacement J9RDO developed a pretty nasty creaking while pedaling under load while climbing. I checked/tightened the BB cups into the adaptors, the chainring bolts, the pedals, the crank arms and the pivots. None of these stopped the creaking.
    After reading this I tried cleaning and re-lubing the 12/142 thru axle interface. This did not solve it. Then I removed the rear der. hanger and it had some debris from the manufacturing that had to be cleaned. I did this and then re-greased the interface of the this part and tightened the hanger to spec. This immediately stopped the creaking. hopefully this will be last of the noise.
  6. #31
    May 2012
    You know sram does not recommending re-using the PF30 cup right? as in, you remove them and they are done. That could cause some noise too I would imagine.
    Quote Originally Posted by oaklandish View Post
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
  7. #32
    Quote Originally Posted by PeopleForScience View Post
    Yep, I was rebuilding the bike this past Friday to ride over the long weekend. I had to reuse the sram adaptors that I had, but I added some green loctite. This actually enabled me to be able to tighten the BB cups to a much higher torque than the first time I pressed them in. I hope this der. hanger being loose and not mating to the frame tightly is the culprit. If so, I am just about dialed in on the replacement frame.
  8. #33
    My gloves stink
    Reputation: Appendage's Avatar
    Creaking victory
    SO glad I found this thread. Like previous posters, I had severe, continuous, annoying and embarrassing creaking during high-torque, low cadence pedaling in the big cogs. I'd already cleaned and greased the cassette/freehub interface, so I knew that wasn't the problem.
    After reading this thread, the first thing I did was check the hanger for looseness, and was disappointed to find it was tight. I took it off anyway and found the mating surfaces between the hanger and the frame were colored brown. Clearly some very fine dust taken up residence in there. I cleaned the surfaces and coated them with Teflon anti-seize.
    While I was at it, I also disassembled and cleaned all the pivots. There was some contamination in there but nothing severe. The bearings were all in good condition.
    I took her for a test spin today and hallelujah, problem solved- mostly. I still have some miscellaneous squeak/creaks during high-torque, low cadence pedaling, but it's 80% better (I think the residual creaking is from another, yet-to-be discovered source). I can't say whether the improvement is from the pivots or the hanger since I cleaned them both at the same time but if you're having creaking issues it's worth trying and not hard to do. BTW Niner is now recommending that pivot bolts be tightened to 10 Nm (the older bolts say 6).
    I dreamed I ate a 10 lb marshmallow. When I awoke, my pillow was gone.
  9. #34
    Always seems like the BB gets blamed initially for creeks. Gotta say I've never found that as the problem. Not saying it can't be, just not in my experience. Today's bikes just seem to be creek amplifiers which makes it even more annoying.
    What I've found, most of which have been mentioned. If anything has anything additional please add to the list.
    • XX Cassette - never had the problem before 10 speed SRAM. Showing up a lot recently
    • Chainring bolt - Recently noticed it in the big ring but not the small ring
    • Skewers - they are loose or have grit in them
    • Pedals/Cleats - usually only one side creeks so easy to diagnose
    • Headset - Never had this myself but friends bikes have had creeks there.
    • Saddle/post - Easy to figure out as it still creeks when you stop pedaling or stop when you stand up.
    • Spokes - Once had a road bike where the spokes rubbed against each other and creeked. Little lube there and it stopped.
    • Derailleur Hanger - Never had that as an issue but adding since I see it in the thread.
    • Housing Ferules. This one drove me crazy for a while. Seems like nylon ferules would fix this so I kind of wonder why I had this issue.
  10. #35
    Reputation: Dry Cownty Brewer's Avatar
    What kind of lube are y'all using on the Cassette? I always thought these were installed dry???
    Making Milk by Day, Beer by Night
  11. #36
    Jet 9 Bearings ahead of BB
    Quote Originally Posted by herothedog View Post
    I'm looking at the second replacement of the lower, forward bearings (in front of the BB) on my Jet 9 in as many years. The other bearings seem to last longer - at least they haven't seized. The lower front bearings froze to the point where it loosened the pinch bolts and caused a creak under heavy torque. Re-tightening the bolt (red one) fixed the creak, but not the cause of the problem. I'm awaiting delivery of yet another pair of enduro bearings. The low and forward position of these bearings on Niners seems to make them very vulnerable to environmental damage. For as little as they move through the suspension travel, I wonder if bushings here wouldn't be more appropriate (perhaps bushings with grease nipples). I suppose bushings aren't very fashionable though.
  12. #37
    under-load creaking - pivot bearings guilty - jet9 al
    Hit everything mentioned previously mentioned for weeks. Finally resorted to the most time-consuming repair and pulled all the pivot bearings. The bearings themselves were fine, it was their seating in the frame. I don't know if they were too tight or too loose (probably too tight as I kept tightening them and this alleviated the problem temporarily), or just needed lube but I cleaned out all the frame seats, lightly greased and rebuilt more or less to torque specs. That did the trick - no more creaking.
    Chris
  13. #38
    little mad riding hood
    Quote Originally Posted by Kuttermax View Post
    I got my bike back from the shop tonight. They got all the rear suspension bearing replaced. Sounds like my old ones were completely shot and binding up. Anyone else have this on a Jet 9 RDO after two seasons?
    yes. my husband and I just replaced all the pivot bearings on our 2012 Jet 9 RDOs.
  14. #39
    My creak was the bottom bracket. Disassembled, cleaned, re packed with some grease and topped it off with a squirt of lubricating oil on the the "bearings(black plastic)"....silent now
  15. #40
    Oct 2013
    Using different BB
    I am looking to use a different BB for my Jet 9 RDO and the bike shop recommend Praxis Works Press Fit. somebody try this BB?
    May 2012
    it wont fit. The jet9 rdo has an aluminum insert in the bb shell that the praxis will not clear
  17. #42
    Not true, I've got the praxis works conversion bottom bracket on my jet 9 rdo.
  18. #43
    Oct 2013
    Quote Originally Posted by knoxpossum View Post
    do you used the Shimano one? or Sram?
  19. #44
    I have the one designed for use with shimano hollowtech cranks to PF30 frames. I have a xt crank on my bike.
  20. #45
    Oct 2013
    I am using a Sram XX I think this will be fine
  21. #46
    Oct 2013
    I changed my BB and nothing happened so I decide to check my cassette and the noise was gone. after two big rides the bike is silent.
    also Niner customer service NO BUENO!!
  22. #47
    Reputation: minouchi's Avatar
    May 2005
    Hey Kuttermax, is your Niner still creek free? I've been working with the identical sounding problem for over a year.
  23. #48
    Quote Originally Posted by minouchi View Post
    For the most part I've had a very good season with my Jet 9 RDO. I have made a number of big changes to the bike though. At the start of the season I swapped out my White Bros Loop for the Rockshox RB-1. I also replaced my XX1 crank with a Quarq XX1 Powermeter. Later in the season I replaced the Fox RP23 with a Fox DPS Evol, including their newer mounting hardware and bushings. My local mechanic helped with a number of the installs and he always checks the bike over when I have it in. I haven't had any significant ongoing creaking issues this year but I do spread out the wear between my two Niners (I also have a RIP 9 RDO). For those of you looking to put an upgrade on the Jet 9 RDO, the DPS Evol is really cool. I've noticed a lot more mid-stroke support since making the change.
    That being said, there is no question that full suspension bikes require a fair bit of maintenance to keep running in tip top form. I took my RIP 9 RDO to a trip to Colorado this year and after a hard week of riding that included some shallow stream crossings it needed a lot of work including replacement of the suspension bearings. In contrast, my Jet 9 RDO has seen mainly dry trails.
    Niner is going to be launching their new racing bike very soon so it will be interesting to see what tweaks they make to the design. The various generations of the Jet 9 RDO definitely addressed many of the early design issues. Some of the aftermarket bottom bracket designs, such as the Praxis Designs Conversion, have also helped fix some troublesome issues for people.
  1. Keep Pedaling - for your Brain
    By mtbxplorer in forum Commuting
    Last Post: 01-09-2013, 03:55 AM
  2. Creaking and popping while pedaling
    By Stucksucks in forum Beginner's Corner
    Last Post: 07-09-2012, 10:27 AM
  3. Ghost pedaling
    By loggerhead in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-22-2012, 07:02 AM
  4. Replies: 28
    Last Post: 01-19-2012, 09:59 AM
  5. Pedaling with your Heels low?
    By Fleas in forum General Discussion
    Last Post: 03-12-2011, 09:35 AM
