Results 1 to 5 of 5
    Oct 2013
    Bonking ... not feelin' well Jet 9 RDO 2013 - Shimano XTR M985 crank 40/28 compatibility
    Hi Niners,
    I've just bought a Black & White 2013 Niner Jet 9 RDO.
    It came with a M785 XT Crank.
    I've decided to buy a XTR M985 40/28 crank and I did.
    Only after the purchased I saw in the following link on the Niner website (
    "Shimano XTR recommended 2X chainrings: 26/38T. We do not recommend the use of 40T (48.8mm chain line) cranks because the large chainring may contact the frame".
    Now what exactly does that mean?
    1. Can I use the M985 with 28/40?
    2. If not, can I just replace the 40T chainring with 38T one?
    3. Is there a M985 38T chainring?
    4. If not, do I need to replace both chainrings or replace the crank to M980 altogether?
    Reputation: have2ride2day's Avatar
    It says "the large chainring may contact the frame". So, if it was me, I would try it before I did anything else.
    Addicted to the Classifieds
    May 2012
    That crankset is actually different chainline compared to the XT crank listed. I imagine that the chainrings will make contact with the frame like they say it does, although I have not personally tried it. I think the only chainring options for your crankset are 40T and 42T, I have not seen a 38T for the 88MM BCD that it uses. I see that the XTR niner build kits come with the raceface carbon crankset, that might be a good place to start.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Reputation: Radical Rad's Avatar
    So did the 40/28 work? Or what did you do?
    Oct 2013
    no luck with the M985.
    i changed to the M980 triple crank set up with 2 chainrings 38/26.
    sorry for the bad news...
  1. sram x0 crank and x7 derailleur compatibility with shimano triggers and chain
    By stmarti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2014, 02:17 AM
  2. Replies: 6
    Last Post: 01-10-2014, 07:08 PM
  3. Shimano XT crank requires Shimano Chain? SRAM rear compatibility
    By LookerBob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2013, 02:05 PM
  4. Replies: 0
    Last Post: 05-01-2013, 02:11 PM
  5. Replies: 2
    Last Post: 05-11-2011, 11:32 PM
