Results 1 to 18 of 18
    COTA member
    Reputation: Dry Side's Avatar
    Jet 9 RDO 1x10 Chain Guide
    I plan to build a Jet 9 RDO this winter with a SRAM X0 1x10 drive train (HBC 32T Spiderless chain ring). Would this be the best chain guide to use for XC?
    e*thirteen XCX-ST E-Type
    I use their E type and ST mounted ones and really have been pleased.
    and if you don't like e*thirteen for some reason, MRP makes nearly identical guides. Theirs are the 1x series.
    Does MRP have an E-type version out now though? I'm also going 1x10 on my RDO when I get it and the e13 has been the only E-type I've been able to find.
    Any updates on this? I am looking for a 1X configuration as well. Preferably with a 28T or 30T. Would appreciate ring recommendations and chainguide for a SRAM XO crankset with spider.
    I'm using the MRP1x and XT cranks with a 32t ring. The only issue I see is not being able to get the guide as low as possible because it hits the tabs for the outside/big ring. If you use a SRAM crank with removable spider you should be able to get it lower. You might run out of adjustment in the guide though because it was designed to go down to a 32t ring.
    I just got the XX1 crank set with a 32t ring. I will hopefully set it up tonight and see how much lower the guide could go for smaller rings.
    Here is my old set up.
    Plant Powered Mountain Bike Racer.
    That would be great to know, please do follow up and post results.
    Contacted MRP and received this response:
    "For your bike you will want the 1X in a S3 mounting style. As of
    right now we do not have a S3 that will fit the 28 and 30t chain rings but
    we are working on them. With the current S3 style you could mount it with a
    30t but it might rub on the lower portion of the guide."
    With the XX1 crank I was able to get the chain guide lower then with my old XT cranks. If you run a spiderless crank you should be able to run a 30 tooth ring and possibly the 28. I was able to bottom the chain guide out agains the top of the chain and there is still about an 3/16" of space in the aluminum mounting arm that the guide could slide down father.
    These picture are with a 32t ring.
    This is the position I normally run my guide. There is still about 1/4" it could go down from this point.
    Err
    Err is offline
    Calm like a bomb
    Reputation: Err's Avatar
    Mar 2005
    Azpoolguy......is the XX1 crank spiderless like the XO is?
    Quote Originally Posted by epiphreddy View Post
    It is technically not spiderless but it has a removable spider just like the XO but with a smaller bolt circle to accommodate smaller rings.
    If you are looking for a single ring set up it would be a very good choice as you have a lot of ring sizes to choose from.
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    That looks sick Errr.
    NOAH SEARS
    MRP
    WHITE BROTHERS
    TECH QUESTIONS HERE: INFO@MRPBIKE.COM
    Err
    Err is offline
    Calm like a bomb
    Mar 2005
    Quote Originally Posted by NoahColorado View Post
    Sup Noah? Thanks, has been a fun project. It's actually the Wifeys. She was diggin in for rippin laps on PBR and Horsethief a couple months back.
    JMH
    JMH is online now
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    That bike is still SOOOO dialed looking. The color kit and the angleset are oooh la la.
    JMH
    Reputation: 06DODGECTD's Avatar
    Quote Originally Posted by Err View Post
    How did you get this to work? I have the same crankset and I just bought the xcx e type guide, but it will not align with the chain ring. I used all the spacers and the plastic piece that comes with the RDO, but it's still off by 5mm or so. Any ideas?
    Here is a couple of pictures if this might help. Thanks!
    Never mind, I just figured it out. I moved the chainring in the inside of the crank instead of the outside. Works perfectly now! Thanks for your pictures it certainly helped me.
  1. 1x10 for carbon frame, need advice on chain guide
    By i.a.n. in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-30-2011, 05:04 PM
  2. Replies: 1
    Last Post: 11-20-2011, 09:14 AM
  3. Going 1X10....questions about chainring choices, chain guide vs. bash guard
    By trumpus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2011, 06:29 AM
  4. Chain Guide Reco for 1x10??
    By MTBDad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-10-2011, 04:57 AM
  5. e.13 XCX chain guide and Race Face 1x10 alignment
    By cyrjm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-29-2011, 12:42 PM
Hot Deals
Contests
Latest Mountain Bike Articles
