Results 1 to 5 of 5
    Reputation: AllMtLemmon's Avatar
    Feb 2017
    Jet 9 Carbon 2015 and Red Face PF30 Bottom Bracket Adaptor combo
    Hey guys
    I've been sourcing the parts for the wife's Jet 9 Carbon 2015 in XS and can't wait to build it.
    http://www.jensonusa.com/images/Defa...5/BB239M00.jpg
    I would appreciate some help and your experiences on installing the Red Face PF30 Bottom Bracket Adaptor on the Jet 9 Carbon or any similar carbon PF30 BB shell.
    I understand that this was once a hot topic. I read a thread on here comparing none-permanent adhesive vs variety of loctite blues vs dry fit. But the thread is quite old and there was no mention of the Red Face adaptor then.
    Your thoughts/experiences to share on this combo?
    Feb 2017
    Decided against the Red Face Adaptor and went with the SRAM PF30 to BSA Adaptor instead.
    Installation was easy, but not ridden yet.
    May 2012
    Those adapters can work well but they are one time use. If you press it out then plan on recycling it. They also don't last forever, but they are cheap!
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Feb 2017
    Quote Originally Posted by PeopleForScience View Post
    Agreed, cheaper than the alternatives plus, being my first press fit install, I like the idea that it's plastic and contorts to and less likely to damage the BB shell.
    As it's on the wife's bike I don't think it will see much abuse.
    FNG
    Reputation: HD1911's Avatar
    Sep 2015
    I chose this one and couldn't be happier:
    PF30 Outboard Angular Contact BB for 24/22mm Cranks (SRAM, Truvativ, Etc.) - Black
    No Creaks/Rattles/Squeaks etc. No locate or adhesive needed. And super buttery smooth. Running a SRAM GXP XX1 Crankset.
  1. Best PF30 to Shimano 24mm Bottom Bracket? Praxis vs. Wheels Mfg. vs. Race Face vs. ?
    By gartenmeister in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-03-2017, 09:21 PM
  2. Replies: 2
    Last Post: 12-04-2014, 09:25 AM
  3. Replies: 1
    Last Post: 12-30-2013, 11:57 AM
  4. How do you remove this Race Face BB30 bottom bracket adaptor?
    By spunkmtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-17-2013, 03:04 PM
  5. PF30 bottom bracket install on carbon frame question
    By brightsky in forum Niner Bikes
    Last Post: 03-11-2013, 01:13 PM
