Results 1 to 41 of 41
    J9RDO HELP Cable Housing Slap
    I am running full length housing. I am using the latest full length housing kit from Niner. Despite my best efforts I can't get the housing snug taut enough inside the frame to stop it from making a ridiculously loud noise every time I turn or hit a bump. Has anyone else had this issue?
    Using SRAM XX1 housing, the plastic clear house and grommets supplied by Niner. This is a real downer.
    I tried running electrical tape on the outside of the housing to,keep,it taut. It looked ghetto and didn't work.
    Thanks in advance.
    Moosehead
    Reputation: moosehead's Avatar
    Do you have the cable housing shims at headbadge and at either end of the chainstay? They are the split shims that will provide some clamping around the housing to keep it taunt, see page 46 of the Niner Encyclopeia, labeled F1R in the firtst diagram.
    Apologies if you are akready doing this, if so perhaps try shimming the housing with a thin layer of tape inside the cable shim might help. Good luck.
    Thanks. I have those shims. I will try to fit some tape under them
    I'm having the same issue on my Rip9 RDO. Niner recommend followings the air9rdo niner encyclopedia's cable trick...zip ties. I doubt this will work since they show zip tying the front and read dérailleur cables together...and we have just on cable for the XX1. I'm going to try making some foam donuts to slip the cables in the downtube...
    My issue is the internal rattle. I am likely to go with interrupted housing. XX1 should be able to handle it. Whereas I can't handle the noise. It sounds like a rattle.
    May 2012
    Quote Originally Posted by cytoe View Post
    I did this on my air9rdo. You don't tie them together, its the tail on the zip tie that springs the housing to the side of the tube. Shimano recommends it on my s-works road bike also.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Quote Originally Posted by PeopleForScience View Post
    How do you get the zip ties inside the down tube? do you go in from the bb?
    Thanks,
    Martin
    Jun 2010
    Had the same 'problem' this weekend. What i did was pulling at the outer cable at the headbadge so that is 'tight'. Then i used some tape around the shim for a tighter fit in the headbadge so the outer cable cannot move out again. Pull the outer cable while installing the shim in the headbadge so the outer cable stays tight. This solved it.
    I had some cable slap when I did the full length cable with XX1. I just zip tied the shift cable and rear brake hose together. It solved the problem for me.
    Just pull the cable tight and zip it to the brake hose. When the bars turn it side loads the cable a bit at the head badge and it doesn't slide in to get slack.
    Reputation: brightsky's Avatar
    Dec 2008
    Mine slaps around a little also after the full length conversion. I was planning on trying some foam donuts or zip ties at some point.
    Thanks!...the zip ties did the trick...no more rattling
    Jun 2010
    How did you get the zip ties in?
    Quote Originally Posted by sand0kan View Post
    I disconnected the rear derailleur cable and removed the fork. I then pulled the cable housing out the head badge the length of the down tube (you don't have to pull all the housing out; use a some tape to mark the cable housing where it exits the down tube). I installed the zip ties through the head tube, pulling the cable housing back through the down tube. I used 4 zip ties. Hope that helps.
    Nice. This is pretty common and what Shimano also told us at the shop with TT bikes and internal cable routing. I don't have noise in my JET9 RDO but will use this solution if it should come up. Thanks for the details.
    Reputation: Bailey44's Avatar
    Dec 2010
    My cable slap is getting bad. I can pretty easily slide the cable in and out at the headbadge. My shim doesn't seem to be the split type. Is this a Niner part or can I grab it at any LBS? My Niner dealer is a long way from my house.
    Quote Originally Posted by moosehead View Post
    I think the issue is that the inside diameter of the Niner holes is not the same.
    Using the same slotted part I get excellent holding power in the chain stay but virtually none in the head tube.
    Since I am running XX1 I am going to try interrupted housing and see if that alleviates the slap.
    The other thing one could try is to run various brands of housing to see if the outer diameter of the housing is thicker thereby preventing sliding into the head tube.
    Reputation: G-Choro's Avatar
    Having the same problem. I have the split shims, new shift kit w/ full housing, and the cable slides in/out with ease. It's driving me nuts. Next time, Niner, just route the whole set-up externally. Such a PITA.
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    Haven't had this issue on my Jet RDO but my Orbea Orca road bike has a super noisy brake cable routed inside the top tube. I took a thick shoelace and cut the ends off. This resulted in a soft fabric tube that only weighed 4g for a piece longer than the top tube. I shoved it over the cable, it was longer so it scrunched up nicely inside and completely stopped all noises and vibrations.
    Might work!
    JMH
    Daniel the Dog
    Internal routing is for what? A solution looking for a problem!!!! And a PITA!
    Moosehead
    ^Jaybo, we got your schtick by now, pal. You did the same moaning in the Turner forum, and now nostalgically declare yourself a Homer. Sheesh.
    Next whine, you get 100 lashes with cable housing.
    Reputation: danvar's Avatar
    lmao!!!
    Dec 2010
    I had my bike at the shop I purchased it and told them about the cable slap. I told them about running the zip-ties as described and that said that should work. I ran to lunch and when I went back to pick it up, all they did was put a zip-tie on the cable entering the headbadge and one on the inside of the of the steering-tube. I was't too pleased that they didn't do what we discussed but I was tired of being there. Rain all day today so I couldn't test it out. Maybe it will work? If not, I will do it myself or take it to my real bike mechanic.
    Quote Originally Posted by onobed View Post
    Quote Originally Posted by G-Choro View Post
    Had the same issue w/ my Rip9 RDO cable routing; the split shims were not tight enough. I fixed it by wrapping some thin kapton tape around the cable (Kapton (Polyimide) Tape with Silicone Adhesive, Amber, 0.001" Thick, 1/2" Wide, 36 Yard Roll: Amazon.com: Industrial & Scientific)
    Dec 2010
    Yeah...that didn't work at all. On to next step.
    Quote Originally Posted by Bailey44 View Post
    Dec 2010
    When you say "pulled out the cable housing" did you leave the wire and just pull the housing? How difficult is it to get it all pushed back in?
    Yup, I left the wire in. I didn't pull the housing all the way out (I mentioned marking the housing before pulling it so you know the length of the down tube).
    Dec 2010
    I finally got around to doing this today and then hit the trail. It was quite as it could be.
    Dec 2010
    My cable slap is back, I think I'm just going to run it externally and be done with messing with it.
    I have found something that has worked perfect so far for me.
    Initially I tied a zip tie around the cable real hard right before the hole in the head badge, hoping that the zip tie would prevent the cable from sliding in. This didn't work since the zip tie just kept on sliding out of place when the cable moved. So I thought, if I could zip tie something with a rubbery surface, the rubber would prevent it from sliding in.
    So I took one of these: http://www.jbimporters.com/web/check...t_number=14391
    I cut it in half, and zip tied a piece around the cable right before the head badge with to ties. The rubber is big enough to not let the cable slide in. Also, the fact that its rubber, with two zip ties holding it in place, it will not slide out of place on the cable. Very discrete too.
    Reputation: Jeepman128's Avatar
    Quote Originally Posted by danvar View Post
    Do you have a photo you can share? I am struggling withe the cable slap as well.
    Here you go. Sorry its not the pest pic. Took it with my phone. Although you cant see it too good, the cable stop that came with the updated kit is also there. J9RDO HELP Cable Housing Slap-photo.jpg
    Reputation: ejreyes6's Avatar
    Dec 2010
    Here is another approach to getting rid of the cable slap on the J9 RDO with full cable housing through the bottom tube. I went to the hardware store and picked up some plumbers insulating foam for 1/2" pipe. I cut a 15" piece and slid it adjacent to the housing in the bottom tube. Essentially it took up space to prevent the cable from slapping around. Only a 5 gram penalty. J9RDO HELP Cable Housing Slap-imageuploadedbytapatalk1374748564.271309.jpgJ9RDO HELP Cable Housing Slap-imageuploadedbytapatalk1374748582.471800.jpgJ9RDO HELP Cable Housing Slap-imageuploadedbytapatalk1374748605.667770.jpg
    Dec 2010
    Quote Originally Posted by ejreyes6 View Post
    Here is another approach to getting rid of the cable slap on the J9 RDO with full cable housing through the bottom tube. I went to the hardware store and picked up some plumbers insulating foam for 1/2" pipe. I cut a 15" piece and slid it adjacent to the housing in the bottom tube. Essentially it took up space to prevent the cable from slapping around. Only a 5 gram penalty. Click image for larger version.
ID:	818985Click image for larger version.
ID:	818986Click image for larger version.
    Good plan and similar to what we did on mine.
    J9RDO HELP Cable Housing Slap-ninerrdo-cable-routing-bb.jpgJ9RDO HELP Cable Housing Slap-cablerun-brakeline.jpg
    Works PERFECTLY and is very easy to do with the least amount of friction/drag. Your shifting will never be better!
    Gave up trying to get smooth shifting and no ghost shifting on my V1 Jet9RDO. Now running the cable externally and got smooth shifting and no ghosting during 3.5 hour trail ride yesterday.
    I do think it would be nice if Niner at least offered some sort of discounted upgrade path to the current gen Jet9RDO for V1 early adopters.
    May 2012
    They do, just crash it into something. Take it to your dealer and get crash replacement. Doesn't get much better than that!
    Lol... last time I tried that I ended up with a dislocated elbow and my Niner didn't even have a scratch...
    Ok - so I have tried the following options:
    1. Internal - could not stop the slap.
    2. External - looks ghetto. If there was an alternate head tube badge that didn't have the holes that would be fine. But there isn't and Niner needs to be slapped for such a poor design.
    3. Internal but with the housing stopped at the head tube and BB.
    I am running XX1.
    Here is my feedback on each option:
    1. I hated the cable slap. It drove me nuts. I tried everything and nothing quieted the cables. Even on smooth paths the slap was annoying.
    2 worked fine but can t reconcile the crappy look with a high end bike.
    3. Wow - super quiet on smooth trails. Amazing actually. When the going gets rough I get ghost shifts which are annoying but it is workable.
    I am sticking with option 3 BC the occasional annoying ghost shift is better than constant cable slap.
    Thank you
    Nov 2007
    I am running continuous housing from the shifter to the r. der on the original Jet9RDO routing. It shifts great, but as others noted, the housing slaps around in the downtube. I tried a few different things but eventually solved it by cutting open the two ends of a thick shoe lace and sliding this "sheath" over the housing before inserting it at the BB. Basically, the piece of housing in the downtube is covered in soft cloth. Problem solved. I think I saw someone else on here do this as well.
    trail "cleaner"
    The zip ties on the full length housing took care of my slap noise in the downtube.
    I am running XX1.
    Thank you
    that's what i'm doing too and rarely have any issues with ghost shifting or noise.
  1. Naked Shifter Cable or Full length Cable Housing?
    By Scott Novak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 04:02 AM
  2. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  3. Is the shifter cable/housing the same as my brake cable/housing
    By dstorjoh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2012, 09:18 AM
  4. QBP cable housing $1/ft; Sram Derailleur cable $2/set; free ship over $30
    By bob13bob in forum Where are the Best Deals?
    Last Post: 03-29-2012, 06:51 AM
  5. New housing or new cable?
    By HX520W in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-17-2011, 11:10 PM
