How did that work out? I was thinking about do the same thing. I don't like horizontal dropouts, and don't want to deal with an EBB. Since you can't adjust for chain stretch due to wear, does that cause any issues?
It was a little tight at first, the rear axle didn't sit all the way down in the drop out with the bike upsidedown, but after a ride the chain stretched a little and it's been fine. Few rides under it's belt now, and no problems so far. I've got a tensioner just in case it gets too loose, but so far it doesn't seem like i'll have that problem.
I started with 80mm and couldn't move it to 100mm fast enough after about 3 weeks. I like my front end a bit higher and need a little more cush for my hands tho..
Do any of you guys have a weight for your bike? I'm about to pull the trigger on a medium EMD frame and was wondering what some of the final weights were of some of your builds.
A bit over 24lbs in size large with middle of the road components. (e.q., XT 1x9 drivetrain, XT/mavic wheels). You could easily build one in the low 20s if you want to drop the cash..
The one of mine above was 22.38 as shown. I got new wheels that dropped it to 21.9.
