Results 1 to 13 of 13
Thread: EMD Niner fit
    Dec 2012
    EMD Niner fit
    Hello all, just wondering if anyone can offer some insight into the proper fit of my EMD niner. I just finished building an EMD Niner and I've had it out a couple of times so far. I'm noticing that I'm stretched out pretty far and I'm getting numbness in my hands. I'm 5'11 with a 32" inseam. My frame size is large. My bars are 680mm wide with a 90mm stem with 10 degree rise. Anyone with approximately the same body size and frame using a 70 or 80mm stem? I'm thinking that may be the solution but wanted to get some input in regards to handling of the front end with a shorter stem.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    It would pay to tell us what frame size you went with.
    Quote Originally Posted by Jason R View Post
    Hello all, just wondering if anyone can offer some insight into the proper fit of my EMD niner. I just finished building an EMD Niner and I've had it out a couple of times so far. I'm noticing that I'm stretched out pretty far and I'm getting numbness in my hands. I'm 5'11 with a 32" inseam. My bars are 680mm wide with a 90mm stem with 10 degree rise. Anyone with approximately the same body size and frame using a 70 or 80mm stem? I'm thinking that may be the solution but wanted to get some input in regards to handling of the front end with a shorter stem.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Dec 2012
    Oops sorry about that,I have a large frame.
    Carbon & Ti rule
    I had a Lge Air9 & it felt big to me at 6ft
    I would have put you on a med.
    I would be going down to a 60mm stem & starting there.
    What seat height do you run ?
    Dec 2012
    Quote Originally Posted by muzzanic View Post
    Thanks for the help, I was looking at 70mm stems but that doesn't seem like it would be enough of a difference. I'll try the 60, my stem was only around 20 bucks so it won't be an expensive swap. I run a 367 mm Thomson elite seat post with the minimum insertion line just below the seat tube. Will a 60mm stem affect the handling much? My arms are almost completely straight with the current stem. Should the correct fit give my arms a slight bend?
    Carbon & Ti rule
    Check the seat height from the centre of the crank to the top of the seat inline with the seat tube.
    Dec 2012
    I have it set now so my knee is in line with the center of the pedal spindle. What measurement should I be looking for in regard to seat height?
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    That's strange. I'm on a large EMD, and I'm only 5'10 with about a 30" inseam. I'm also using a 100mm stem, and the bike feels perfect for me. I would have thought that the large would be a good fit for you.
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
    Carbon & Ti rule
    You may well like your fit, But it doesn't sound like the op does.
    The Niner site says Med 5'8 to 6 ft & for Lge 5'11 to 6'3 so at 5'11 he is on the short side of normal for that bike.
    Quote Originally Posted by J3SSEB View Post
    Bicycle Addict
    Obviously.
    Dec 2012
    To Muzzanic: I just measured from center of BB to top of seat and it's around 30.5 inches. What is the optimal ratio relation to my inseam? I noticed today on a short ride that the grips hit in the fleshy part of my palm, it's almost like all of my weight is being supported by my palms.I'm going to try to the stem first and I'm hoping that works. Another thing I noticed is that I have no lower back pain at all, which is rare for me on a new bike.I'm hoping that this means I have at least part of my fit correct.
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    A professional bike fit is probably a good idea.
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    Mar 2013
    Hi guys,
    Wondering if any of you guys out there can point out a fit fault or remedy.
    I'm experiencing pressure build around my elbow, any advice on a starting point to tweek?
    A professional bike fitting might solve all, but i just came back riding after several years and bought a completely new bike.
    It took me a while before to point out discomfort vs. weak core on my previous bike (a 26 HT) but with a 29er it's completely diffrent.
    I'm 5.10 with a 31 inseam moderate long torso on a Med EMD9 currently on a 710 riser 90mm 6degree stem 0 spacer. Reach feels ok and i'm happy how the bike feels, just after long rides 50Km or so i occasionally feel numb or sore around the elbows, back strains are felt when i run heavy on gears and on the sadle long climbs but i have a feeling that's mostly due to the long lazy hybernation where the core is not as strong as it used to be, or maybe i'm pushing hard to get the speed i use to ride before.
    any input are most welcomed.
