Results 1 to 3 of 3
    Does SAG affect pedalling efficiency?
    I just went from 20% to 50% SAG on my jet 9 rdo finding it wayyy more plush and confortable. Now i am concerned if SAG affects pedalling efficiency.
    Moosehead
    Reputation: moosehead's Avatar
    FS bike manufacturers recommend a sag range that is the best combo of pedalling efficiency and plush. Generally, dual links can get away with a bit more sag and/or less platform setting.
    That said, at 50% sag on your niner, my bet is the bike sits down into it's potential travel range, leaving less travel to deal with trail obstacles. You may also experience more bobbing than desired on climbs or when mashing - less efficiency.
    There's always next year.
    Reputation: padrefan1982's Avatar
    Mar 2005
    I don't have a Niner suspension frame, but I can't imagine pedaling anything with that much sag in the rear without any negative effects. 50%'s a lot of sag. I'd echo everything moosehead said, along with running that much sag could also lower your BB height=more pedal strikes. I'd also imagine you'd be bottoming out the suspension frequently as well.
    If you do like how it currently feels, maybe look into tuning your rear shock--different air can size or talk to Niner or a company like PUSH that deals in suspension tuning to see if there's a way to make feeling work for you with a more 'correct' set-up. But, if it works for you...
  1. Pedalling fast and long is they key
    By Jaybo in forum Endurance XC Racing
    Last Post: 03-15-2013, 03:46 AM
  2. creaking while pedalling...
    By osokolo in forum Beginner's Corner
    Last Post: 09-12-2012, 01:12 PM
  3. back pedalling
    By Kenrow in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2011, 06:44 AM
  4. Is there something wrong with my bike - pedalling backwards
    By Paladin54 in forum Beginner's Corner
    Last Post: 02-10-2011, 05:04 PM
  5. Any pedalling rides at SoMo tomorrow?
    By Jayem in forum Arizona
    Last Post: 01-16-2011, 12:27 AM
