Results 1 to 32 of 32
Thread: Clyde Questions
    I Strava Hamburgers
    Reputation: 14Stone's Avatar
    Jun 2010
    Clyde Questions
    I'm a rapidly shrinking clyde and Niner really appeals to me as a bike brand I want to ride next year.
    I have an Air One and a RIP 9 on my short list, but can't find any information on max rider weights. I imagine it won't matter in the new year, but I've heard that the frames are really designed for lighter riders with 29er flavors.
    Does anyone know where I can find this information, or am I wildly off base with what I've read?
    Nov 2006
    rip9 is one of the most solid 29er bikes in the universe ...
    Underskilled
    Reputation: CaveGiant's Avatar
    Why a RIP not a WFO, that is the strongest.
    Why would I care about 150g of bike weight, I just ate 400g of cookies while reading this?
    Reputation: david8613's Avatar
    May 2005
    i had started with a jet 9 when i first converted from being a life long cannondale guy and now i ride a wfo 9, very stiff and strong but climbs awesome for a 5.5 inch dually!
    I Strava Hamburgers
    Jun 2010
    I think my avoidance of the WFO is more that I have a much larger XC flavoring of courses and races around here, with a small amount of downhill.
    How does the WFO climb anyway? Decent, or are you really working on it as compared to lighter / hard tail bikes?
    The Air 9 carbon isn't off the list either, but its more of the "if I win a mini lotto" option.
    Can you define "rapidly shrinking clyde"?
    If "14Stone" or 196 lbs is your weight then I guess I'm a superclyde.
    That may help with some feedback.
    Fat On A Bike
    I am 250 and I ride a Jet 9
    It is a rocket. No problems with my weight. Run Stan Flows, Fox QR15, and I am good to go.
    Ofir
    I Strava Hamburgers
    Jun 2010
    Definition: 273 atm, probably end somewhere in the 210-220 range once I jump to a proper XC bike for when I race.
    Whats the weight like on a Jet 9?
    EDIT: 14 stone is just a reference to being under 200lbs and a really overly lofty goal
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by 14Stone
    Hi the Jet9 is about 1.3 lb ligher in the frame.
    I have both & really like both but I would push everyone over 210 lb onto a Rip9 because I just think it would just work better for them & I think they would be faster on it than they would be on the Jet9.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Underskilled
    The weight between all the frames is small compared to a clyde rider.
    I have my WFO set up with a RP23 tuned to my weight and for high efficiency.
    For me, post tune, it is the fastest most efficient pedaler I have ever ridden.
    It has the huge advantage over the XC bikes that you never have to worry about it breaking or flexing when you put the power in.
    Mon-fri I put slicks on and commute, I beat most roadies on the flat, but I also drop a few flights of stairs, and even ride up a couple too!
    Just make sure you have the RP23, get it tuned and you have a bike that pedals like an XC race bike but can drop technical terrain easily
    May 2005
    i had the original jet and yeah it was fast, but i was 240lbs at the time and yes i felt the flex, i dont know about the new jet. but i can tell you this the jet was really quick uphill almost like a hardtail quick, but pointed down you needed to pick your lines, carelfully. with the wfo 9 she pedals up the hills really nice you dont even think about it, no bob, tremendous traction, just pedal, you dont realize your on 5.5" travel bike. point it downhill and she is much faster than the jet, cause you dont need to pick lines, just run over everything! and believe me the wfo picks up so much speed so quick you have to check yourself cause you will be at warp 5 without even realizing it. plus with the right parts this bike is super stiff, the only flex i feel on my bike is from my tires, its wierd... all my bikes i had in the past were between 25lbs to 28lbs, my wfo9 is around 37lbs give or take so its 10lbs heavier than what i am used to and i dont feel it all it is so effecient.
    Fat On A Bike
    Quote Originally Posted by david8613
    I am sorry but I really don't know why you claim the Jet is not a fast downhill and that you need to pick your line...
    Point and shoot. It is darn fast machine, and it roles faster then any 26" I ride against.
    with regards to the original post - If the guy's style is for XC and not for anything else, then the Jet is the bike he needs.
    There is no need for something else where the aim is for XC.
    Also, no flex for me on my v2 Jet.
    Ofir
    Underskilled
    How much do you weigh blaad?
    May 2005
    yeah how much do you weigh bladd?
    Fat On A Bike
    I did wrote it before
    Just below 250.
    Ofir
    May 2005
    i was talking about the the first version of the jet that i owned, blaad did you ride that one? im pretty sure the newer jet is stiffer from what i hear, there is a difference the two... the hydroformed tubing would make the bike stiffer compared to the original.
    Fat On A Bike
    I am riding the second version. and yes, you are right, is is much stiffer.
    Ofir
    Underskilled
    I am just mistrusting the new Jet due to the problems of the old.
    Yet for someone even though my old RIP bent then snapped, i trust the new one...strange huh
    Fat On A Bike
    Quote Originally Posted by CaveGiant
    VERY
    Carbon & Ti rule
    Quote Originally Posted by blaadd
    Ofir
    The new Jet9 is very fast down hill, Much to fast for its own good !!
    I have the new Jet9 & Rip9.The problem being the Jet9 doesn't have the grip of the rip9 to be able to scrub off lots of speed when something bad jumps out at you & the penalty on the Jet9 is greater for not getting the speed off.
    At the weight of the OP the Rip9 would still be a better XC bike than the Jet9 for his Weight.
    Fat On A Bike
    Quote Originally Posted by muzzanic
    Interesting... One point to make is that here (Israel) the Niner guy specifically told me that for the style of my ride (XC) I would be better on the Jet rather then the Rip. I had asked him since I was not under 250 when I got the bike...
    ofir
    Reputation: Adim_X's Avatar
    I asked niner this question a few months ago,
    "Brian,
    I am curious what the rider weight limits are on your WFO and Jet 9? I am a clyde looking to go full squish.
    Adam"
    . Brian Bierro at niner stated the following
    "We do not have any for our bikes. Im sure you will be fine. Those are both super strong frames.
    Thanks for getting in touch. Let me know if you have any other questions.
    Brian"
    Hopefully he doesn't mind me posting.
    I Strava Hamburgers
    Jun 2010
    Quote Originally Posted by Adim_X
    "Brian,
    Adam"
    Brian"
    Hrm. I wonder if they say the same about the Air 9 Carbon. They have a weight limit on their carbon forks of 240.
    Thanks for the replies.
    I'm just putting together a short list for next spring when the XC season starts. The bike be purely for XC and not so much commuting. I have the Jubei II for training. I don't mind the Jubei but I find it heavy and a bit sluggish. Hammers terrain like a monster though.
    Gary Fisher and Niner are high on my list, but its hard to find a Niner dealer with XLs in stock.... mind you the same can be said for Gary Fisher too.
    Fat On A Bike
    If I were you I would not touch a carbon frame.
    As for inventory, this is going to change soon as the new batch of frames with the new color scheme is going to arrive soon. I would highly recommend a Niner. Once you ride it you would not look at other options. That's exactly what happened to me
    Ofir
    I Strava Hamburgers
    Jun 2010
    Oh believe me, I have no vision's of carbon in my future... XC is fun and I'd like to some day Podium but by no means am I even ever going to get to the level where a carbon bike is going to make me a better rider.
    Underskilled
    I would say there is nothing wrong with Carbon as long as it is used to add strength NOT drop weight.
    I did a 2-3m (~10'? nose dive yesterday to flat on my carbon forks, not even a twich, most stable things ever.)
    Dorado's are designed to be strong, not light, key key difference.
    I am slowly being brought around to carbon!
    I Strava Hamburgers
    Jun 2010
    I donno. Theres something about showing up with a Carbon bike outfitted to the brim with the best in parts..
    Then hill slugging it up what most people do on one wheel while eating a power bar, and talking on a cell phone.
    May 2005
    its funny it reminds me of the only carbon fiber bike i ever brought, it was a cannondale carbon rush, and yeah it was light as a feather, fun to ride but when i was thumbing through the handbook it said something like do not to leave the frame in a flat bed truck on a very hot day, that it could hurt the strength of the carbon! i sold it....
    Davir
    Reputation: davthedude's Avatar
    Feb 2005
    Gary fishers are not Clyde worthy i speak from experience three frame failures in one year.
    If you are serious about XC, and racing, then don't even screw around, build yourself an AIR 9. If you want a sometimes race bike, and a more trail/fun/recreational bike, then look to the RIP. Better yet, get both... I did.
    I Strava Hamburgers
    Jun 2010
    "Serious" is a relative term
    Thanks for the info guys. Looks like a Niner in my future.
    Reputation: schnee's Avatar
    Yeah, one of the reasons I picked the Niner over, say, the Tallboy. I'm too big, slow and fat to ride bling. My RIP is very, VERY strong, at the cost of only a few pounds over my previous bling-bike.
