Results 1 to 2 of 2
    Aug 2010
    Build a 2010 rip w 2010 jet parts??
    I had a last gen rip which I loved. I now have a 2010 jet, but I want to go back to a rip. Are all the parts interchangeable between a 2010 jet and 2010 rip? Thanks for the help.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by Allthegoodnamesweretaken
    Hi really to only 3 things to worry about is fork height (rip uses 120 & jet 100 ) & I would not run a 44 tooth chain ring on the rip because of chain suck.
    Hope you didn't cut the steerer on your fork to short the rip needs it approx 20mm longer.
    Every thing else will be ok,I have both the Rip9 & Jet9 & set up alot the same.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
