Results 1 to 5 of 5
    Mulleticious
    Reputation: BigwheelsRbest's Avatar
    New question here. Biocentric EBB - why don't you need to loosen the cranks??
    I just don't understand why you don't need to loosen the cranks to rotate the EBB. Surely the crank is exerting a clamping force on the EBB which should inhibit rotation during adjustment?
    (My Biocentric II rotates fine without me loosening the cranks up, but I just don't understand why...!)
    ..apologies if this has been dealt with elsewhere - I couldn't find anything specific
    greedy
    Reputation: have2ride2day's Avatar
    Shimano or SRAM? My Shimano cranks just need to be tightened enough to preload the BB bearings. I don't think it is enough tension to keep the EBB from moving once its bolts are loosened.
    Addicted to the Classifieds
    Mulleticious
    Quote Originally Posted by have2ride2day View Post
    SRAM - well, Truvativ Noir singlespeed specific, to be exact.
    May 2012
    SRAM cranks do not work how you think they do. The drive side bearing is a floating bearing. It has zero preload on it. You can look and see the gap between the crank and the drive side bearing. Shimano and almost every other crank uses a different system.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Mulleticious
    Quote Originally Posted by PeopleForScience View Post
    Well, I just looked and you're right. Thank you sir!
  1. How do I Loosen M395 shimano hydraulic brakes.
    By Daniel Armstrong in forum Brake Time
    Last Post: 09-19-2013, 08:46 PM
  2. Which screw do i loosen to remove the shifter cable?
    By TheeSuperUberV in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-25-2013, 01:33 PM
  3. Biocentric II where to get?
    By roman in forum Niner Bikes
    Last Post: 12-12-2012, 06:33 AM
  4. Stem/Steerer Clamp bolts loosen
    By Adroit Rider in forum Tooltime
    Last Post: 08-28-2012, 07:24 PM
  5. Can't loosen BB right side
    By justin51 in forum Fat bikes
    Last Post: 04-29-2011, 02:15 PM
