Results 1 to 7 of 7
    May 2012
    BB for 2012 air 9 with shimano xt crank
    Here is a link to a BB recommended by a jenson rep to work with a shimano crank. Does anybody have any experience with this adapter?
    Origin 8 BB30 Shimano MTN Adapter Kit > Components > Drivetrain > Bottom Brackets | Jenson USA Online Bike Shop
    Niner makes a press-in adapter that will allow you to thread in a standard xt BB, but the adapter alone is about double the price of the above link. Then you still need to buy the Shimano BB on top of that.
    I have no experience using that adapter kit you've mention but instead I'm using this one up to now.
    Truvativ Pressfit 30 Bottom Bracket > Components > Drivetrain > Bottom Brackets | Jenson USA Online Bike Shop.
    Since i've got my exisiting shimano xt crank, i settled on that adapter.
    May 2012
    OP - That is a bb30 kit that you linked to. The Jenson rep made a mistake because the frame is pf30
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    May 2012
    Hanky- I originally ordered that same BB. As soon as I opened it I knew it was wrong. The I.D. is too big for a shimano spline. XT splines are 24mm.
    People-I said the same thing to the rep. I ordered the frame and crank from jenson so the rep was able to pull up my order and see exactly what parts I am using. He insisted it was correct. I haven't received the BB or crank yet so I can't say you are wrong. I was skeptical also. Thats why I started this post. I do know the BB Hanky posted will not work. It fits the frame but not a shimano crank. I pulled an xt crank off a bike I already have and it doesn't fit that BB. I'll post more when the parts arrive.
    May 2012
    *spindle...not spline
    May 2012
    I just found this post on here. It shows an adapter that works with both BB30 and PF30 to allow the use of a shimano crank with a 24mm spindle. Hopefully the one I ordered will do the same.
    Bottom Bracket Standards - a guide to BB30, PF30, and Outboard Bearing compatibility
    May 2012
    Ok. I called Jenson back. The BB I posted above is wrong. You were correct People. The Jenson rep made a mistake. They hooked me up with the right BB and gave me free overnight shipping to make up for the the mistake which I thought was pretty cool of them. Its a race face BB and he said he contacted a niner rep to confirm it would work. Here is the link.
    Race Face 2013
  1. Shimano XT crank requires Shimano Chain? SRAM rear compatibility
    By LookerBob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2013, 02:05 PM
  2. Moving from a SR Suntour crank to a Shimano crank...
    By Tsetse in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-01-2013, 05:47 PM
  3. Help upgrading Shimano 8spd IG crank to 9spd HG crank.
    By kryten in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-29-2013, 05:40 PM
  4. Shimano XT (M760) crank users, what chainrings (Other than shimano) are you using?
    By HighLife420 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-21-2011, 11:24 AM
  5. Sram XO (2007) vs Shimano XT (2011) AND raceface deus (2007) vs Shimano slx crank
    By xtremgirl in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2011, 12:41 AM
