Results 1 to 2 of 2
    air9 and shimano external bb spacer setup
    I have an air9 alloy and am not sure how to set up the spacers with my xtr m980 external bearing bb.
    Now the shell on the air9 is 73mm but the flanges on the inserts bring the width out to about 76mm.
    The bb is designed for a 73mm shell with a 2.5mm spacer on the drive side.
    So should I use the spacer or not?
    If I use it the effective bb shell is wider than specified. If I don't it seems the crankset will be offset 2.5mm to the non-drive side (which is how I have it set up now, and does appear to be offset).
    Reputation: Mr_Clean's Avatar
    Oct 2010
    If it matters, I am running a 2x10 XTR crank. Just like you, I had alignment and chainline issues. Instead of using one 2.5 spacer, I used 2 on the drive side. I know this is off spec, but it cured both alignment and chainline issues.
  1. Replies: 5
    Last Post: 02-24-2013, 11:53 AM
  2. 456 + hollowtech II: crank spacer setup?
    By svalgis in forum All Mountain
    Last Post: 11-05-2012, 12:57 AM
  3. Are shimano external BB compatible with other brands
    By gonzo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2012, 08:11 AM
  4. Cleaning Shimano external bering BB.
    By Nocturnus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2011, 05:06 AM
  5. 1x10 Setup with chainguide...BB spacer question
    By cyrjm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2011, 06:39 AM
