Results 1 to 3 of 3
    May 2012
    AIR 9 Front derailleur standard/cage length.
    I´m little confused which front derailleur I´m supposed to use if I´m going for a shimano 2x10 xt set for example.
    If I configure AIR 9 here on niner website it´s configured with: SHIMANO XT M786 10SP 34.9, DOWN SWING, DUAL PULL
    Configurator
    But if I look into Tech info about AIR 9 it says: High mount, top pull
    AIR 9
    And also, do I need Medium Cage for rear derailleur or can I use long/small cage ?
    And I need some sort of bb30 to hollowtech ii kit I guess.
    I have size L on my Air 9.
    Regards
    Reputation: yellowducman's Avatar
    You need a High Mount, Top Pull. The down swing duel pull is a high mount. The dual pull just means the cable can come from the bottom or the top. You can use a duel pull or a top pull, just not a bottom pull.
    For a 2 x 10 I would go with a medium cage. You can use a long cage if you would like but the medium cage is supposed to give you a little snappier shifting. You won't be able to use a short cage with a 2 x 10.
    May 2012
    @yellowducm
    Thanks for clearing this out! Helped me a lot.
  1. 1x10 and derailleur cage length
    By trhoppe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2013, 07:54 PM
  2. Derailleur cage length for 1x9 and 1x10
    By Whip Chop! in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-21-2012, 05:48 PM
  3. 1x9 what derailleur cage length
    By primestick in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-14-2012, 05:23 PM
  4. Newb? Derailleur cage length?
    By 220CROSSFIT in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-07-2011, 06:18 PM
  5. Chain length and short vs long cage derailleur
    By Cormac in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-25-2011, 11:38 AM
Hot Deals
Contests
Latest Mountain Bike Articles
