Air 9 Carbon w/niner fork XT brakes rubbing
So, I have an Air 9 carbon XL frame and a Niner carbon QR fork and I installed Ice Tech Rotors on Industry 9 hubs. The Rotors are new and the XT BR-M785 brakes are used. The old non ice tech rotors didn't rub but when I put these on with new pads, bled and then tried to center the calibers I couldn't slide them 'in' enough. So if you are standing over the bike the calipers need to move in towards the hub but there is no more adjustment on the calipers. I don't really want to put a washer between the hub and rotor to push the rotors 'out' towards the caliper. The wheels spin but do slightly rub, enough that I am posting about it.
Thoughts?
Thanks,
Ken
Why not put a washer between the rotor and hub? I think that is why "they" make rotor spacers...
 Originally Posted by meltingfeather
If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
I've had a similar issue on the rear on my A9C and it does not seem to be hub related as I've tried a few different ones. I think the Avid brakes have a lot more room for adjustment as I didn't have this issue until switching from Avids to Shimano.
Thanks! That's why I was posting. It made sense just wasn't sure what my options were.
Ken
King hubs and Formula brakes I always needed 2 or 3 rotor shims on each of the three Air 9 Carbon frames I used to have. Never needed a spacer on the front wheel with a Niner fork, though.
I had to add the shim or washers with my xt brakes and I9 wheels.
By Turduckenator in forum Tooltime
Last Post: 06-07-2013, 11:01 AM
By shackleton47 in forum 29er Bikes
Last Post: 09-01-2012, 06:24 AM
By nuckingfuts2 in forum 29er Bikes
Last Post: 07-20-2011, 09:11 PM
By 120 in forum 29er Bikes
Last Post: 05-28-2011, 12:40 PM
By Kamil in forum Beginner's Corner
Last Post: 05-23-2011, 08:37 PM
- You may not post replies
- You may not edit your posts
Forum Rules
