Results 1 to 5 of 5
    Air 9 Carbon frame size??
    Hi,
    This is my first message to the forum.
    And this is my first decent mtb-frame.
    I'm interested of A9C frame. Could anyone recommended right frame size to me?
    Standing height is 5 feet 11 21⁄32 inches (182cm)
    Inseam lenght is 2 feet 10¼ inches (87cm)
    Thanks to all.
    You are about .75 inches taller than me and our inseams are almost exactly the same and I am VERY happy on my size large A9C. Running a 90 stem I believe with a 10 downward angle with a 5 mm spacer between the stem and headset top cap.
    Hope that helps.
    Reputation: Boxer's Avatar
    Mar 2005
    I think the XL starts at 6'2" as reccomended by Niner so a Large would be spot on for you. The 90mm stem should be correct too.
    Pedal Dammit!
    COTA member
    Reputation: Dry Side's Avatar
    I am 5'11" and find the large A9C fits great. Running an 80mm stem.
    Thanks to all of you.
    Problem solved, and the frame is in the order.
  1. Chinese 29er carbon frame size
    By jarango in forum 29er Bikes
    Last Post: 07-26-2013, 12:21 PM
  2. XTC29er carbon frame BB size
    By mtrhead in forum Giant
    Last Post: 02-01-2013, 09:48 PM
  3. Replies: 5
    Last Post: 09-08-2012, 07:40 AM
  4. Carbon frame or........ the 'correct' size.....
    By RockyRoad2Dublin in forum Bike and Frame discussion
    Last Post: 02-08-2012, 09:21 AM
  5. Sette phantom carbon frame 1080g Size m
    By xcatax in forum Weight Weenies
    Last Post: 02-02-2012, 10:49 AM
