Results 1 to 7 of 7
    Jun 2014
    2014 lg rip 9 reverb
    looking at a used reverb, would a 420mm be too long for this frame or the 380 be better fit?
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by PUZZLE View Post
    No it's not to long, for the bike, What seat height do you run.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Jun 2014
    from middle of crank to seat rail about 28.5
    Carbon & Ti rule
    How tall are you ?
    Do you have the right size bike for you ??
    I'm 6ft & have my seat 75mm higher than you, I have the 125mm drop Reverb 380mm.
    I could only drop my post into the frame another 55mm before the top nut part of the reverb would touch the seat post clamp, You look like you would need to go 75mm, So you may need to go to a 100mm drop & not the 125mm to make it work.
    This can change depending on how high your seat is from the rails to the top of the padding, Seats can be almost 20mm difference as well.
    Jun 2014
    im 6ft as well, the large fits pretty good, 28.5 inches from middle of crank to the seat rails, re measured it
    Carbon & Ti rule
    Ok I was talking seat height not Rail, Sorry I missed that you went to the rails ( My mistake ) so that makes another 55mm difference.
    You should ( Just ) be ok with 420mm, I would go 380mm though.
    Jun 2014
    i got the 420mm and had about a half inch before it bottomed out, so it will work for me
  1. Replies: 56
    Last Post: 06-27-2014, 10:16 PM
  2. Replies: 107
    Last Post: 06-24-2014, 05:19 AM
  3. Replies: 0
    Last Post: 05-05-2014, 07:26 AM
  4. Replies: 3
    Last Post: 03-29-2014, 07:10 PM
  5. Rock Shox Reverb / Reverb Stealth
    By WorldIRC in forum Trek
    Last Post: 07-01-2013, 07:12 PM
