2013 Air 9 Carbon - Predictions???
With the new SIR 9 recently announced I'm curious if the Air 9 Carbon will see some changes such as 12x142, direct mount FD, geometry changes, etc... Any ideas?
I'm new to Niner and do not know if they put out new models based on the year or if they only make changes when needed like Ibis.
Bottom line; should I get an Air 9 Carbon SS now or wait for the next version of the frame? Any thoughts on when the next version will be out?
They don't do model years, though that frame is about due for an update. It is a really badass singlespeed frame as-is, though. I can't see what they could change that'd make me want to offload mine and make an upgrade. The RDO tubing was downsized a bit for weight and compliance, but I honestly can't tell much difference between the two.
I would bet on a 12x142 rear axle at least
I would hope that they incorporate the internal cable routing from the Air 9 RDO (versus the current system). That seems to be a little more user-friendly as opposed to the current A9C, which seems to be a bit of a pain.
+1 on the ability to run full length housings
- You may not post replies
- You may not edit your posts
Forum Rules
