Results 1 to 30 of 30
Thread: 2010 RIP vs WFO
    Reputation: noosa2's Avatar
    2010 RIP vs WFO
    After looking at the geometry for the RIP and the WFO (I was looking at the large specs) on the Niner website and trying to guess what a 140mm fork would do to the RIP's numbers it appears that they are almost identical (assuming both were running a fork with the same a2c). Other than the WFO being a bit beefier and having an inch more travel is there any difference in the geometry between the two frames?
    What is the weight difference between the 2 frames (large size)?
    What is the BB height of each with a 140mm travel fork?
    Underskilled
    Reputation: CaveGiant's Avatar
    The WFO can take a resevoir shock.
    If you had asked me two weeks ago I would also say the WFO was plusher, the rip a better pedler.
    After a nice chat to mojo, CVA (aka vpp) does not do anything for pedaling efficiency it is all done by the shock. They say this is a VERY good thing, let the frame do it's job, and the shock do the compression damping.
    Anyway, either frame can be tuned to ride like you want.
    My WFO now sprints as efficiently as my old XC race bike, but is strong enough that I can abuse it without fear of something breaking.
    My WFO is so much more fun now the shock is tuned.
    Why would I care about 150g of bike weight, I just ate 400g of cookies while reading this?
    Reputation: david8613's Avatar
    May 2005
    some time ago there was a guy who had pics of the rip and a wfo side by side, i dont remember who though?
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Quote Originally Posted by david8613
    2melow posted a photo like that to show the difference between the straight downtube of the RIP9 and the belly in the WFO downtube for piggyback shock clearance. Is that the one you're remembering? That one doesn't address any of the OP's questions, though. I'm not sure any side-by-side would show much in the way of minor differences in geometry.
    The WFO also has the ISG tabs for running a Hammerschmidt crank set, and a special front derailleur mount if you choose to go with multiple ring gears up front.
    I love my RIP.. But if I had it all to do over again id probably opt for the WFO. Having ISG tabs would be really sweet.
    Quote Originally Posted by CaveGiant
    I think CVA is a mini link bike like (or a copy of) DW link bikes. My understanding is that VPP bikes have links that rotate in opposite directions while DW link style frame have the links rotate in the same direction? I barely remember that part but am certain CVA isn't like VPP. You could feel VPP pedal feedback in the granny, I've never felt that on my Rip. I also don't think they rely on damping for efficiency.
    In regards to which bike I think you are on the right track. The geos with 140mm forks are darn similar. I have a Marz 44 on my Rip and wish I had gone all the way and gotten a WFO.
    2 wheels
    Underskilled
    My info was from one of the suspension guys at Mojo, he described it as a short link virtual pivot with a regressive stroke.
    Once he tuned my WFO it went from a divey, easy to bottom out, lousy pedaller to a bike that pedals as well as my old XC race bike.
    The results from his tune suggest he knew what he was talking about?
    He was exceptionally complimentary on the suspension design, but he thinks that no bikes frame designs add pedal efficiency, it is just marketing BS.
    He is an expert, and demonstrated his skill, so assuming there is some truth to it.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Sounds to me like he has very little idea what he is talking about,Not trying to pick on him but to make a statment like that he is full of BS
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    BMJ
    BMJ is offline
    "55 lbs and climbing!"
    Reputation: BMJ's Avatar
    Do the WFO, more to offer for less! ISCG tabs, direct mount front deraillier, piggyback shock ready, 1" more travel, 150mm rear option, more stable geometry.... oh, and it's almost $300- cheaper the the Rip blowout.
    First, it's nice that neither of us are going overboard with this, after all it is the internet.
    I am not an expert and have poor memory but the answer is on this board if you want to search. Of course it's a challenge that one can't search 'CVA' because it's only 3 letters.
    What did he do to tune your shock? I assume he took it apart or are we only talking air pressure and external dial changes?
    2 wheels
    May 2005
    i had a jet 9, skipped the rip, jumped on the wfo 9 very happy, alot of bike for the buck!
    I have taken a pavement spin on a large WFO with a 140mm fork and the bottom bracket seemed pretty low. With the chunk around my area I really would prefer something in the neighborhood of 14". Anyone got the BB height measurement?
    May 2005
    make sure the shock is pumped up for your wieght, when i first built mine up i felt the samething, after some adjustments all was good!
    Moderator Moderator
    Reputation: 2melow's Avatar
    Quote Originally Posted by artnshel
    CVA is far from "a copy of DW link bikes" as stated above. They work differently, and the instant center is pretty far from how DW and VPP designs work.
    Probably the best example I've seen of all the different mini link suspension designed doing their thing is in this post. Turner Aqcuiring Use of DWL
    Front Range Forum Moderator
    Underskilled
    rebuilt and re-shimmed damper, also advised reducing the air volume by part filling the the XV1 can (Which I admitted I had already done).
    I I cannot stress how much this affected the ride of the bike.
    So what he says about pedalling efficiency seems implausible, but hey, can't argue with results. Just to stress he said the CVA was a great design, but the efficiency should be done with the shock.
    It feels good and all settings on shock are now useful.
    Hey CG, you should get rid of the RP23 and upgrade to the DHX air. I have had no complaints in 4 months of thrasing on it and it mirrors the Dorado in "plushness". All I did was set the air to my weight plus my pack and it was a done deal.
    As far a Niners CVA is concerned, I feel it is nothing like DW or VPP because it has the lower link is going under the BB and no other suspension design (that I know of) does this.
    It works different and definately feels more plush than the other two without affecting pedaling performance as far as I can tell. BTW I owned a blur lt and demoed a DW link bike for a week.
    Underskilled
    It was recommended by Niner that I try the DHX, but I have read too many reviews on here to consider it.
    Thankfully since the mod the RP23 seems perfect, I am yet to try it for heavy DH, which was my plan for this weekend (before the person I was going with inconsiderately got a kidney infection) so have to get back to you on that.
    I'd say if you ride out of the norm, or weigh out of the norm for the bike you are on, by all means, see a professional suspension tuner, to get the most out of your bike. The average rider won't notice it, a skilled rider at the advanced intermediate to above levels will notice the difference instantly. It has a huge effect on your ride.
    They didn't have WFO's when I bought my RIP, but there are serious deals to be had out there right now on either models right now.
    Quote Originally Posted by noosa2
    Bump - anyone got the BB height of a WFO (and RIP) with a 140 mm reba (or similar) and the weight of each frame in the large size?
    Quote Originally Posted by RandyBoy
    bikebling is one, have you found any other online that you can link?
    and a noob question, but I couldn't verify it somewhere. is the shock for the WFO 200/50?
    Laker and a Trail Blazer
    Reputation: Broncstad's Avatar
    I started riding 1.5 years ago on a 04 giant FS NRS3. I bought it used and it is a large. I'm 6'4" 210, and lrg is way to small. So I'm looking at these two. I keep going back and forth between these bikes. What's the difference in weight?
    Carbon & Ti rule
    Quote Originally Posted by Broncstad
    Hi not a big amount in frame weight really, not enough to take ithe WFO off the shoping list,its more that the people that build the WFO up put heaver parts on them.
    I have always told people if you have to ask the question wfo or rip9 you are a rip9 rider they can handle heaps.
    I think of a wfo rider as being the 1 in the group that is always talking every one into doing stuff they are not sure about & a WFO rider knows they are part nutter.
    But thats just 2c so you have asked the question so Rip9 with 140mm reba it is for you Bike sorted nice & easy.
    Why is RIP more money than WFO?
    Deals? I seen bike bling has wfo frame for $999.00, do these deals get better? Or am I going to be pissed that I didn't pull the trigger?
    BMJ
    BMJ is offline
    They may have made more WFO's than the public is interested in or they have some significant changes coming out at InterBike in September. RIP's a bigger seller, retains it's value more I would suspect.
    After paying $1,800 for mine, I wish this deal was around 10 months ago! $999- is a no brainer!!!
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    A few dimensions that may be of interest:
    WFO with Dorado:
    A-C = 580mm
    BB = 14.125" with Dissent 2.5 tires
    RIP with 140mm Reba
    A-C = 550mm
    BB = 13.5" with Ardent 2.4 tires
    Doing some calculations (bear with me, I suck at teh mathz) - If I put the 140mm Reba on my WFO, I could expect the BB to drop by about 2/5ths of the difference in fork height since the bb sits at about 2/5ths of the wheelbase (close enough for our purposes). Taking some liberties with rounding since this isn't an exact science says a fork that's 1.2" shorter will lower my bb by .48" or let's just call it 13.625 or 13-5/8"
    Or in other words, my RIP BB with a 140mm Reba is only about 1/8" lower than my WFO would be with a 140mm Reba. But also this doesn't count tire height differences between the Dissent and the Ardent, so let's just say:
    Yeah, the BB height is about the same!
    Does that help at all?
    JMH
    May 2005
    that deal is even better than the wfo party that i got when i got mine, you can have a whole bike built with some nice parts with that deal on that wfo frame and what i paid for the party pack! i say go for it!
    Quote Originally Posted by JMH
    ... If I put the 140mm Reba on my WFO...
    JMH
    Thanks for doing that JMH - it does help. Given that the WFO should be setup with more sag I bet the BB would be lower on the WFO with a rider onboard.
    I bet the HA are very close too.
    JMH
    JMH is offline
    Sugary Exoskeleton
    Feb 2005
    BTW... after two rides now on my RIP with the 140mm Reba, I won't be going back. Fantastic! A little more front end wag on steep climbs, but the flat cornering traction has improved a small amount and the bike doesn't deflect quite as much in the rough, allowing me to carry more speed. Win!
    JMH
    JMH
    I hear ya... but after riding a WFO equipped with a Dorado and the DHX... I'm really leaning to building up a more AM type WFO. It's pluuuuuuuuuuuuuuuush! And it climbs damn good too.
    Maybe build it up with a 135mm rear end, and put a Hadley SS rear hubbed wheel on there, so it's dishless and strong on both sides, run it 2 x 6, and call it good. We will see, the darn economy and the stock market has been sketchy this whole year.
