Results 1 to 15 of 15
    Ride or Die!
    Reputation: CasinoKiD's Avatar
    2010 RIP Niner build
    I'm building my Rip up with new XT Dyna-sys cranks. I was wondering if I need to use any spacers on the BB?
    Stock width is 73mm on the frames bottom bracket, so no, unlikely spacers are needed.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    1 on the drive side.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    PVNEMBA vee pee
    What muzzanic said. One 2.5mm spacer on the drive side -- unless the directions that come with the crank indicate otherwise.
    - Chris
    Ride or Die!
    Thx fellas. I'll post pics when I'm done.
    Ride or Die!
    Here she is...
    Reputation: single-trac-mind's Avatar
    very nice ...enjoy
    biking makes it better
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    Beautiful!!!
    Now ride the f*** out of it!!!
    Santa Cruz Hightower LT
    EVIL Following
    Ride or Die!
    Quote Originally Posted by LCW
    Beautiful!!!
    I've been riding the pi$$ out of it. Man what a bike I love it!
    Ride or Die!
    My RIP frame came with a XT front derailleur model number M-771. The XT Dyn-Sys group I ordered came with what looks like the same FD except the model number is M-771-10. Does anyone know what the difference is or if there is even a difference?
    Carbon & Ti rule
    Quote Originally Posted by CasinoKiD
    Yes they look the same but the cable throw is not the same the new 10 sp stuff only works with the new 10 sp stuff.
    Ride or Die!
    Quote Originally Posted by muzzanic
    The whole xt group I bought is the Dyna-Sys 10 speed stuff.
    Carbon & Ti rule
    I put the XT 10 speed on 1 of my Rip's & it worked well but have to say the Sram X9, 2x10
    suits my riding better,
    I also just took the 10speed XT off my wifes bike & fitted 2 x 10 on her bike but that was more to keep her out of the big ring & get her spinning more,not because she didn't like it.
    I think the 10 sp XT is a big step up form the old 9 speed & I have 3 friends with it to & they like it alot to.
    The Hutch
    Reputation: rob1208lv's Avatar
    Did you need the Spacers?
    Also building the same bike.... But
    I may go with 9spd crank front d and front shifter... with a 10spd rear d cassette rear shifter and chain.
    Will this work?
    Carbon & Ti rule
    Quote Originally Posted by rob1208lv
    Will this work?
    Yes it will work, but If you go with the XT 10 speed cranks it gives you a 42 big ring & that is much better on the Rip9 than the 44
