Results 1 to 25 of 25
    2010 RIP 9 creaking help.
    I'm getting some some creaking from the BB area of my 2010 RIP 9 on left side pedal down strokes and im having a hard time diagnosing the source.
    So far ive:
    -removed/inspected/tightend to spec the BB/cranks/pedals
    -checked for play in the shock mounting points
    Any other ideas?
    Reputation: Spinning Lizard's Avatar
    Just went through the same thing, ended up being the rear hub. Regreased the freehub, noise gone. I swore it was the crankset, removed and re-checked 3 times.
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    Quote Originally Posted by skeltah
    So far ive:
    Any other ideas?
    Rear skewer/hub is a common culprit, weirdest source I have found is the front derailleur bolt. Damned mountain bikes and their creaking... 20 years of MTB and I still can't find creaks sometimes.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Had some raceface cranks & it was the LH crank arm loose on the shaft that goes through the botton bracket.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    agreed the crank/bb always gets blamed but more times than not it is elsewhere. skewers are the first place I check. One time a smart guy showed me that grit between crossed spokes was causing the problem.
    Thanks a bunch.
    COMBO - President
    Reputation: FASTK's Avatar
    Just had my BB area pivot bearings replaced, creak is not gone. Had replaced the BB but that did not cure the creak.
    The creak is gone! good call JMH on the derailleur bolt... That would have been the last place I checked.
    Reputation: fire_strom's Avatar
    That's just weird. I guess I'll start there though, I have the same issue as the OP.
    Thanks, I'd have never, ever thought to check that.
    Scott
    JMH
    JMH is offline
    Sugary Exoskeleton
    Feb 2005
    Quote Originally Posted by fire_strom
    Scott
    It doesn't take long to put a wrench on every bolt on your bike... if it makes a "tic" when you give it a push in either direction, it's almost certainly the culprit.
    Glad you found your noise! I had a seatpost earlier this season that was creaking deep inside the frame, I cut an inch off the end and it stopped.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    My bike's creaking seems to come and go like the rheumatis. Same with brake squeal.
    I pretty much clean my bike after every ride, an Atomic Blue RIP. So far, the only thing that squeaks ever on it is wet brake pads/rotors. I have had slightly loose skewers on my AIR 9 drive me crazy, until I found the culprit.
    RBlackwood
    Guest
    I had an identical creak/click in my bottom bracket that drove me nuts. I tightened my rear axel and it instantly disappeared. Weird how the rear axel makes it sound like the bottom bracket is the issue.
    Try the Chainring bolts also. Took my chain rings apart and put a llittle lub on the bolts and stoped my creaking.
    Closekids.com
    Reputation: BoomingSooner's Avatar
    I'm cursed by wanting a quiet ride....
    Me to my riding buddy, "Want to ride this afternoon?"
    Him, "I can't. I have to chop this guys foot off at 2".
    My bottom linkage pivot bolts on my WFO wouldn't stop creaking after torquing them to 65 inch lbs. Took it up to 75 in pounds, backed them off, then reset to 65 inch pounds. Solved the creak, for good.
    Reputation: subspd's Avatar
    My WFO creaking is driving me insane! I had the shop pull the headset and relube at the same time they checked the BB, about 30min into the ride after that the creaking came right back. I am going to check the rear derail bolt but I am at a loss.
    Anyone know how to service the bearings on the linkage on these? Is it as easy as pulling the caps lubing the bearings and then re tighten to spec?
    Reputation: Nickbm3's Avatar
    There was a thread where someone had a great writeup on how to take apart all the pivots and press out the bearings, etc, if i find it I'll post a link... Maybe someone else can link to it too. I get creaks from the lower pivots every couple of months, I pull out the axles and linkage (usually just lower, once in a while ill do the upper) and wipe down and clean everything, even the cone shaped washers that go between the bearing and linkage. When its all apart I spin the bearings with my finger, I'll only remove/lube the bearings if they are gritty, otherwise I just brush the gunk out from around them and clean the surrounding areas (not spraying any cleaner ON the bearing). I clean the axles well, and then put a light coat of grease on them and re-assemble, nice and quiet for a few more months!
    "That's a niiiiiiiice biiike boy! That a Huffy!?"
    Reputation: wmbarace's Avatar
    Sep 2004
    I have a RIP 9 with about a year and half on it. I had been chasing a creek for much fo the summer and fall. I replaced the bearing ans still had the creek. A week ago I took the shock off placed it in a vise and had play inthe bottom DU bushing. replaced the bushing and the credk went away. Check your DU bushings.
    CM
    Quote Originally Posted by wmbarace View Post
    CM
    For some reason a DU bushing is not registering. Help me out, what is a DU bushing? Where did you get a new one?
    Dec 2010
    the DU bushing is apart of the shock. you need special fox tools to press them in and out correctly. yes you can do it with a vise but its not worth the risk of damaging the new parts. Your shop should have the tool though.
    MoJo Moto
    Reputation: motopail's Avatar
    Check the hardware on your rear dropouts......
    Ride Hard or Ride Home Alone.
    Thank you, thank you, thank you. Rear dropout hardware! I surely removed every bolt on the bike and that was the one. I would have never thought of that. I've had this creak since last summer and this spring just couldn't stand the thought of another summer with this creak on an otherwise flawless machine.
    Loser
    Reputation: Jisch's Avatar
    I have had the same issue with my '10 RIP9 - I can silence it for 3 months at a time by taking off the dropouts and greasing them. I've tried marine grease, silicone grease and anti-seize compound - none has lasted more than that 3 month period. If someone finds a permanent fix, I'd love to hear it! Its not that big of a deal, but it would be nice to be rid of it once and for all.
    This thread saved my sanity! I had a ton of creaking when pedaling and swore it was the crank. I swapped out my crank and BB to no avail. Was ready to remove my pivots when I found this thread. Tightened the drop out screws and the noise is gone. Thank you, thank you!!!!
