Results 1 to 7 of 7
    Reputation: velocanman's Avatar
    Oct 2007
    Smile 2010 Jet 9 BB Spacer?
    I've been riding my replacement 2010 Jet 9 XL and loving it. Great bike for a big guy.
    I've experienced a few times, with enough chain slap, that the chain can get caught between the now-beefier chain stay and the big ring. Should I put a spacer on the BB drive side?
    You can see some scraping on the chain stay behind the BB in the attached photo. And yes, I know I have THREE quick links on my chain.
    Canman
    Attached Thumbnails Attached Thumbnails 2010 Jet 9 BB Spacer?-46641_1516498072233_1227925311_31578903_8377616_n.jpg
    Oct 2007
    BTW, I did a search for "jet" and "jet 9" and I get no results. Ever. Need to email the administrator b/c search seems broken.
    30-ton War Machine
    Reputation: edgerat's Avatar
    I ran two on mine and that solved the problem.
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    Methinks that the bb is 68mm? Which means 2 spacers driveside, 1 spacer non-driveside for most brands. Or one spacer each side for SRAM bottom brackets.
    Might not solve the scuffing but should greatly improve your chainline.
    JMH
    Enki loves you
    Reputation: gravedoja's Avatar
    Dec 2005
    I see you have one of those new spokeless wheels, how you finding it? how does it work, mag lev? ;-)
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by acanfield
    Canman
    Et tu, JET 9? Crankset clearance issues....
    Dec 2008
    I have an XL frame and I get my chain stuck in there too. The best advice I heard is when it gets jammed, just compress your suspension and it will work free without having to stop and get off the bike. That trick has saved me a couple of times, including in the first mile of a race where I would have been passed by the entire class if I had to stop.
    In another thread Niner blamed it on improper setup/spacing, but I know I am using the proper spacing. It is just a flaw with the frame.
