Results 1 to 3 of 3
    Dec 2008
    150mm WFO, HS, SRAM 2x10...
    i know i read some somewhere it has been done, but am search challenged...
    any problems? what size rear der do i need?
    Underskilled
    Reputation: CaveGiant's Avatar
    just count the teeth you need, my guess would be short as the der only sees 1x10.
    Why would I care about 150g of bike weight, I just ate 400g of cookies while reading this?
    Oct 2010
    I just had a WFO 9 built last week and tested it out on the trails this weekend. I haven't ridden any bikers other than my old hardtail, but what a sweet ride! I had 2x10 gearing put on it with the 150mm hub, but I'm unable to use my small gear up front with the small gear in the back because the chain rubs on the next gear up. The guy in the shop said it would work with the 135mm. Other than it seems to work great. We just ordered a 3 ring up front, popped the big ring off, and put a bash guard on it. I rode one nice stretch where speed was my friend and didn't really see the need for the top end gears.
