Results 1 to 2 of 2
    09 EMD - largest middle ring clearance - 34t?
    I need to replace my CRs on my race face crank and plan to just use a Blackspire 24t and 34t but I'm not sure the 34 will fit - my 32t is pretty close to the stays.. what have you fit in the middle ring position?
    TIA
    Reputation: 5H2O's Avatar
    I run a 1x9 set-up using XT cranks with a 34 in the middle position, and have a good 1/4"
    gap to the chainstay,
    You should be fine.
    Doug
