Results 1 to 2 of 2
    Hope X-post Revelation (Dual Air) lower leg removal
    X-post, not really Nicolai related apart from its fitted to me bike
    Following these guides
    http://www.enduroforkseals.com/siteb..._dual_air3.pdf
    http://www.sram.com/_media/pdf/rocks...rs/TM_MY10.pdf
    Having trouble removing the lower legs,
    step 13 on the top link
    and
    same step (but) 5 on 2nd link
    doesnt make sense to me as the 5mm nut/bolt is screwed into the lower leg housing, surely if you tap it you risk stripping the threads on the leg housing????
    Do i just remove the 5mm nut and use a drift down the hole?
    Cancel my last, I was just being overly cautious, its not threaded into the lower leg housing
