Results 1 to 57 of 57
    Reputation: dipper's Avatar
    Jun 2005
    who's all running a CCDB on their FR?
    Curious as to how you're getting on with it in comparison to other shocks you've tried.
    having run numerous shocks now on FR's and AM's(Roco TSTr, DHX-C, Monarch and CCDB) I'm slowly coming to the conclusion that it's not all it's cracked up to be(at least on this application). Some aspects of it's performance are stunning. Mainly LS Comp and rebound. it pedals great, resists bottoming brilliantly, stays composed and flat through high G corners etc. The issues appear to be around HS events.
    Things got off to a rocky start as the factory settings were miles off. I then started backing off the HSR and things were much improved. At this point i thought I had it sussed and would soon be in shock nirvana. However, I'm now fully backed off on both HSR and HSC and it's still not as plush as any of the other shocks I've tried through the rough stuff.(I'm running over 30% sag by the way).
    Don't get me wrong, I'd still rate it higher than most other shocks for most of the riding I do as i do like a shock to have good control over LS events. I just reckon it shouldn't be as harsh through HS event type stuff. For a shock so adjustable i wouldn't expect to running at the extremes of the adjustment range either.
    any ideas?
    steep fast and loose :)
    revise the shim stack by getting it tuned by Stendec, get it footprinted and get a grip.
    the FR and the AM are known to need less platform and less mid stroke controllability due to their leverage ratio and Horst Link design. The CCDB still needs a fettle for your Clydesdale bulk.
    All you need is a well tuned RP23. And lose 4 stone too...That'll make the biggest difference
    'All over it!'
    Reputation: lornibear's Avatar
    I have a CCDB and have struggled to find the sweet spot from the moment I had it. I eventually got hold of Malcom from CC and discovered that the shock was over sprung for my 235lb bulk. He sent me a 650lb spring and am hoping that I will be able to wind in a bit of preload where as with the 700lb spring, it was almost loose it had that little preload.
    When I get it up and running, I will then start the process of fettling to find the sweet spot. I will probably be PMing you for your help!
    Jun 2005
    cheers for your helpful input Simon but as I've told you before. I've spent longer on a woman than you have on different shocks! Don't despair though I'm sure there's a forum somewhere that would benifit greatly from your knowledge and mechanical abilty...........just can't think of any off the top of my head
    like i've said on the forum before, for my Turner 6 Pack, the CCDB was a necessity.
    For a Helius AM or FR, the CCDB's a total non requirement. The Horst works so well that there's little need for a fully tuneable shock with excellent mid stroke control and adjustability.
    regarding spring weights, then I'd agree 50# less than normal for the CCDB allowing it to sit in the mid-stroke range during normal operation.
    as the linkage design of the FR / AM is so well though out and the leverage ratio is 2.8:1, then an air shock can control the action of the AM / FR no problem. It just depends on how heavy you are and the frequency you hit BIG square edged hits (Alps riders apply here, not UK based trail riders).......
    al imo of course.
    conclusion : the CCDB is wasted on the Helius.
    Jun 2005
    cheers Lorni. I'm probably @ 220lb geared up and am running a 550lb spring and over 30% sag. I do have a 500lb spring as well but can't see that helping. I'll maybe give it a whirl just to see. The issue appears to be spiking in the HS circuits. Like there's a lack of oil flow. Do you have an email address for Malcom at CC? I'll maybe drop him a mail to see what he says.
    in return. may i offer my sympathies to the women you've obviously smothered in your time too then dipper
    it's qualitative, not quantitative in my experience.....
    Jun 2005
    Simon. I'll give you a shot of the CCDB on your AM. I think you'll be well impressed(with everything other than the HS control!). I'm fairly sure that the pedal strike you've been suffering with the AM/monarch is down to the lack of LS control.
    I don't think looking at leverage ratios at one point of the stroke is relavent. The 6-Pack was also @ 3:1 and a horst but the suspension acted completely different to FR/AM Nicolais. yes the Nics have more midrange support than the Turner but are still prone to blowing through the travel on LS events if there isn't sufficient damping control.
    The CCDB is far from wasted on the Helius. Granted it's not a nessessity like it was on the 6-Pack but it does most things better than the other shocks. I just feel it needs more range of HS adjustment.
    'All over it!'
    Malcolms address is: malcolm@canecreek.com he is very prompt with his replies and very helpful, he sent me a new spring from the US free of charge, good luck and let us know what he advises.
    Jun 2005
    I've emailed Malcom now so will see what he says.
    Reputation: Karve's Avatar
    Mar 2006
    Mar 2006
    Quote Originally Posted by dipper
    any ideas?
    I think you need to run a bit more sag thus maybe a lighter spring.. if its not as supple as you like with all the compression off it would imply you are oversprung. Im running 35% sag and its supple on the little stuff and I use the HSC to control the big hits
    Jun 2005
    Cheers Karve. I'd forgotten about those threads.
    are you still running stock HSC and R settings?
    Mar 2006
    Nah my setting have changed since then (ill let you know what they are if i get a chance to measure them over the weekend)... im running a bit more rebound as I like a nice slow return on large big hits... and a little more compression.. I jack it up if im doing big drops and loosen it off if im trail riding..
    The criteria I use are
    If I pop a jump do I get to far over the bars - less LSR
    If I pop a jump am I landing too back first - more LSR
    Is the shock bobbing when pedalling - more LSC
    Is the shock not bobbing - Less LSC until it does a little
    Am I getting bucked off on big hits - More HSR
    Is the back end packing up on repeated big hits - Less HSR
    Am I bottoming out on big drops - More HSC
    Is the ride a bit harsh - Less HSC
    If you stick to those I think you get a pretty good ride with the shock
    Sounds like your issues are not fixed my winding out the HSC so the next step to to lighten off the spring. I do think that winding out the HSR will be making it feel harsher than it should however... only adjust one at a time. Try adding some HSR back and see if that helps... should deaden the big hits a little.
    Do all of you run over 30% sag or is that only when running a ccdb.
    I havent a nicolai helius fr but i want one,and will very soon and was wondering what shock to run, i was thinking of a dxh coil due to my slender 240lbs riding weight but i coould be intersted in a ccdb.
    Jun 2005
    you may be onto something with the HSR. I started with that and ended up with it backed right off. i then did the same with the HSC. Both helped but I never thought to start slowing up the HSR again as maybe the original harshness was mainly from the HSC being too slow and now it's the overly fast HSR. Can't see it being the spring as i'm already over 30% sag but I'll try that also as I should have a 500lb lying about.
    Oddly, on every other shock I've tried I have the opposite issue. I reckon at 220lb geared up I'm on the limit of stock shock tuning. I usually need to run rebound damn near maxed out(closed) to control the heavier spring rates required.
    Norcosam
    The Nicolai FR and AM both allow you to run 30% sag using pretty much any shock while still remaining easy to pedal. The CCDB, being better controlled at low shaft speeds allows greater sag without wallowing and sagging all over the place. I've yet to try more than 35% sag but I know there are those that run 40% with the CCDB. I'm not entirely sure there's a benefit in this but I'll maybe give it a go just to be sure.
    Mar 2006
    Give it a go.. that back end pinging back after every big hit will make it feel harsher than if you allow the bike to return with some rebound control! Let us know how it feels.
    from 0 - sideways 3.2 sec
    Reputation: derekr's Avatar
    Some interesting stuff, i must say when i had the CCDB on it wasnt tuned for me atall but it did still feel good. I'd love to try it again setup for my weight etc.
    I'm loving the RP23 at the moment which i thought i never would!
    Visit - www.gravity-sports.co.uk - Exclusive high end MTB Products
    Just to add to the mix I was considering a CCDB but instead chose to plump for a BOS S**Toy instead as its equal in quality and can get it service 4 miles from my house @ TFTuned.
    Still waiting for it to arrive at the moment ordered it in November but Olivier Bossard was concentrating on all of the Paris Dakar shocks for the rally cars before Christmas so couldn't get the Bike Shocks made and dyno'd.
    Can't imagine why he would concentrate on dozens of 5,000 pound shocks rather than my little'un........
    Full report will follow when it arrives
    Nice one Garry, will be interested to hear the results
    Mar 2006
    yea deffo interested to hear how that works out... are you the first to run one of those on a Nic?
    Smile BOS STOY / TFTuned
    It looks like it! TFTuned will prepare it for the AM and my weight / riding style.
    Can't wait, I have briefly ridden a Stoy which belonged to one of the guys from TFTuned and it was very, very nice although I suppose it should be seeing as the guy is a tuner!
    All of the guys from TFTuned are members of our club the Black Canon Collective, last month I had my TALAS 36's out for the first time and Neil asked me for the bike gave the forks a tweek and gave it back saying 'it was almost there!' a compliment I think.
    Having had a conversation with Tim Flooks over a pint (after a night ride) the consensus was that the CCDB gives 99% of riders more too mess up, whereas what is needed is consumer adjustability within the bounds of good tuning. Not the option to ruin a good thing.
    Dipper it would be good to do a back to back test if we meet up as there is not a single one on the internet! Only people guessing.
    We will see but I think if the truth be known it would take Steve Peat to see the difference!
    Jun 2005
    That would be great Garry but I'm an hour north of Aberdeen! I'm sure we could come to some arrangement though!
    I think everyone can benifit from quality/well set up suspension. Not just the pro's. I'm sure Peaty and the likes could ride any old crap faster than us but if your suspensions working for you as opposed to against you it's one less thing for you to worry about.
    It's true you can make shocks like the CCDB feel like a dogs dinner and I certainly wouldn't reccomend one to everyone. However, if you've even got the slightest understanding of what a shock does then it's fairly easy to get it in the right ball park. It's just the last wee bit I'm struggling with.
    I've got plenty customers on flash bikes with fully adjustable suspension that have no idea or no interest in setting them up properly. The most common things I see are no rebound damping on forks, too much or too little sag on shocks and forks that are way to big for the bike. All these cock ups can be done with or without fully adjustable suspension.
    The snag with suspension 'operating within the bounds of good tuning' is that if you're required spring rate is above or below the manufacturers damping range, you're screwed. You then need it custom tuned. This obviously suits Tim Flooks though I'm guessing it was probably custom tuning he was getting at in which case I agree with his sentiments.
    Jun 2005
    Malcom from Cane Creek has been in touch. he's sure we can sort it out. Chances are it's just me not having a clue.(my words, not his!) He's offered to send another spring direct from the states so thats the customer service box ticked! I'm feeling happier with the shock already
    Won't get to test his advice for another week yet unfortunately
    TF makes a fair point, but there are riders out here that understand the range of shock tuning required to suit varying terrrain / locations and therefore the wider span needed for adjustment, rather than just a narrow band of range.
    HI TLR, Dipper, the BOS doesn't have a narrow amount of adjustment it just doesn't let you stray into the completely wrong territory, the shock is set up to one of three brackets for your weight and style then within these there is a good range of adjustment.
    Dipper you were correct in picking me up on the 'bounds of good tuning' I pressume that anybody spending that much money on a shock gets an expert to tune and set it up for them. Then its up to the rider to adjust that base setting for the conditions once they've understood what the adjustments do, I am getting there after a lot of reading and talking to experts at the club.
    To my mind the BOS and CCDB are pretty much equals (both have rallying pedigree) the thing that swayed me was ease of getting the shock serviced.
    p.s. Dipper I've been promising the wife a trip up to Scotland for years
    Hey Gary,
    As we discussed last year, i may also have a trip down your way later in the year so worst case i could always pinch a shot of dipper CCDB
    Problem is im scared i like it hehehe
    The best thing i've added to my AM thus fas is by far the 823 wheelset, its just transformed the bike imho.
    Derek
    Sounds like a plan Derek!
    "Its All Good"
    Reputation: Whafe's Avatar
    Well I love my CCDB on my Helius FR, set and TOTALLY forget......... Yeah Ha
    Jun 2005
    Just a quick update for those that may be interested.
    malcom at CC kindly sent me a 500lb spring free of charge and has been offering some advice. Excellent customer service from CC I have to say.
    I'm now running 40% sag. i can't say I'm overly comfortable with that. It just seems wrong for the type of riding i do. However, it still pedals perfectly and I'm not suffering pedal strike or any unwanted handling issues with the lower BB.
    I'm running the HSR and HSC wide open. whereas I have a lot of LSR and LSC dialled in. It feels very slow and pretty dead in a carpark test but works a treat on the hill. In fact I've started dialling my forks in in a similar fashion as it works so well(currently running 66ATA's)
    The result is a very compliant shock that pedals well, doesn't wallow, bottom out or bounce me off the bike. I'd maybe even go as far as to say, it's stunning!
    It got probably the ultimate test today at Pitfichie DH track. It's a boulder strewn minefield and I was concerned about twatting the pedals/BB off rocks but it handled it no problem. It did feel a bit soft off the final jump(for those that know the track) but it still didn't bottom out
    All in all, i'm very happy with it and feel i understand it a lot better. You do need to rethink your methods when setting this shock up compared to other shocks. Normally i'd set the sag, then dial in damping to control the spring. With the CCDB, you still set the sag(just more of it) but as you're essentially running the shock on the damping circuits and not the spring, you set it up to control the terrain if that makes sense? Maybe not but I know what i mean! maybe Malcom can explain it better.
    Mar 2006
    Yep that is exactly it - the dampening does all the work the spring just holds your weight and put the shock shaft in the right position to work.
    Nov 2008
    I ordered a CCDB this week, im going to have to learn how to fettle now!! cant wait
    Hi Dipper
    read your comments with interest. I'd like to know what's the theory behind your new settings....no HSC and R and lots of LSC and R, and why it works?
    Jun 2005
    can't say theres a theory as such ryates. just trial and error. I'm by no means where I want to be yet but it is working very well.
    Due to running so deep in the travel(not ideal I don't think. but this may just be psychological!)) I have to run large amounts of LS damping to stop bottoming/wallowing through berms, drops etc. This works very well. pedalling is still XC like and I'm not twatting pedals everywhere which I thought I would.
    On the HS side, things are very smooth and active. Not so much so that I'm being kicked out the seat or bottoing out too easily. However my next plan is to play with these to see if I can get even more control without sacrificing compliance.
    I'm also going to bolt in a Roco TSTR to compare it against.
    Ideally I'd like the shock to work as well as it is at 35% sag as opposed to 40 but as I've said I suspect thats just in my head.
    Not a 5 minute job but it keeps me occupied!
    'All over it!'
    Not wishing to hijack this thread, but whilst we are on the subject of the CCDB, can anybody give me some step by step instructions on how to replace the spring. I am going to try the 650lb spring sent over from Malcom at CC but haven't a clue how to get the existing 700lb off. Does the shock need to be on the bike or can you do it with it removed?
    Mar 2006
    Undo the mounting nearest the front of the bike so the shock dangles free
    The shock is still attached to the rocker
    Loosen of preload collar as far as you can to take the tension off the spring
    Pull the front spring cap off - see how it has a gap in it to allow you to do this
    The spring then just falls off the shock shaft
    Do in reverse to mount it up....
    Super easy bro! takes like 10 mins
    'All over it!'
    Many thanks Jon, will have a bash when I get home on friday, can you do it with the shock off the bike? Only reason I ask is I don't get my frame back until next tuesday
    Mar 2006
    its easier with the shock off mate!
    guys - what %ge sag are you running the CCDB's ?
    I'm at 35% sag on a 500# spring on the AM.
    we're trying the CCDB to see if it alleviates the monstrous pedal strike i'm suffering.
    i'm still keen to try a 57mm stroke RP23 however, back to back with the CCDB.
    TIA
    fwiw, my opinion on the CCDB has now 'adjusted' due to Dipper dialling in some peculiar (HSR / HSC wide open) settings to the CCDB.
    i'm now looking forward to getting the ride height [correctly] sorted, and seeing if the mid stroke can be better controlled
    Jun 2005
    peculiar how?
    peculiar as there's NO HSR / HSR circuitry enabled, but LOADS of LSC / LSR (too much LSR I reckon).
    Hey if it works then dosent really matter
    Jun 2005
    "(too much LSR I reckon)"
    tell me that the next time you case a double and get punted into the trees!
    better on the 500# spring - taughter, better controlled, better SA, need to back of the LSR though...lots and lots of dialling in required - it's a dirty job, etc...........
    just had word from Malcolm at Cane Creek - He recommends a minimum of 30% sag to max 35% sag for riding duties - i'll post further info once he recommends base settings for the AM / FR.
    He suggests shuttled runs, (Alps / Whistler, etc) should utilise 40% sag as 40% is inefficient for trail riding, but not DH'ing.
    spoke to malclm again, at length, regarding shock option and settings - he's an absolute professional - passionate, knowledgeable and helpful........a perfect example of how to support and back up a top end product.
    so what does he say.....?
    still waiting for base settings, but he's suggested previously to open the HSR/HSC circuitry and dial in LSC to begin with, which is my starting point - once he gets some base settings (still waiting for the AM leverage rates) he'll advise !
    Jun 2005
    'HSR/HSC circuitry and dial in LSC to begin with'
    isnt that what I suggested and you called it "peculiar"?
    I'm not just a pretty face you know!
    'All over it!'
    Hey dipper, I hope you don't mind me asking, but I am taking my CCDB back to basics now I have a lighter spring. I am hoping to get my nice new white FR built up next week and really want to dial my shock. Can I ask what settings you run at the moment to give me some indication of where I should be with it? I was never happy with it until I found that that the spring rate was too high. Any advice woud be great
    Jun 2005
    my current settings are based on running 40% sag so may change if I can get it back to around 35%
    I can't remember the LS settings exactly and can't check them as TLR is demoing it(and probably made a hash of it so I'll be back to square one also!). Essentially, I had both HS circuits wide open and had a quite a few clicks more than stock on both LS circuits.
    Even with slightly less sag I guess I'd still run the HS circuits wide open but may back off a fraction on the LSC circuit.
    If it feels too soft and slow in the car park you're probably not far off! the only thing I find with lots of LS damping is that it can feel a bit 'jiggly' at slow speeds. I'm talking trail speed here as oppossed to shaft speed. Although shaft speed and bike/trail speed shouldn't be confused i suspect there has to be a relationship there. Hit a 2" bump at walking pace will produce a LS event at the shock. Whereas, hit the same bump at mach2 will produce a HS event at the shock. Feel free to correct me if i'm talking bollocks but I don't think everythings as black and white as we like to think. The circuits may be separate but there has to be some crossover between HS and LS events on the trail. Just as I suspect there is some correlation between bike speed and damper speed in certain situations.
    For example. I've not quite sussed properly what circuits control drop offs. I suspect it's a bit of both HS and LS. Certainly, adding LSC prevents the shock bottoming. So does dialling in more HSC but you then suffer in the rough stuff so i prefer to control it with LSC.
    Less LS damping provides greater traction and a softer feel while doing techy climbs(which also happens to be low trail speed). We don't have a huge amount of techy climbs so this doesn't bother me and rather have a load of LS damping to 'catch' me if i cock up. ie. case a double, land a drop badly etc.
    I've by no means finalised my opinions on what all it does for me so I reserve the right to change my mind on a whim if i like. Although it's good to discuss settings, there is the risk of taking advice from someone who has no idea what they're on about! Even if I never fully understand it I'd rather ride and fiddle till it feels the way I want than bark up the wrong tree(or get punted up the wrong tree!) with someone elses settings.
    Hope that helps some
    doubt you'll get anywhere near 35% sag, as there ain't a spring with enough rate for your mass
    power back on then ?
    fwiw, i use the LSC to dial in the reduction of pedal bob, and the LSR controls the rebound dependant on the LSC setting.
    i am however countering sag with increased spring rate, as i hate a mushy back end (a la dipper) and am now @ 30% sag statically. With a static 30% delivered by the spring, this should allow me to open the LSC and increase the LSR and i'll leave the HSC and HSR where they are for now until i can get some speed up on the rock, when the snow melts !
    whatever, the CCDB is a barrel of laughs (pun intended) if you like to fiddle and are searching for the perfect ride.
    don't forget the FR / AM Horst link provides a great base on which to tune the suspension settings anyway
    i'm at 30% sag with the potential to increase sag by winding out a bit of preload, which gives me a bit wider scope.
    i'm 85kg kited running a 550# spring on the AM.
    i think the AM leverage rate is greater than the FR at the front end of stroke (makes sense as the FR is intended for bigger hits whereas the AM is a better trail bike) so this lends the AM a requirement to run more preload / spring rate than the FR for the same sag..........
    great fun
    Jun 2005
    sounds good in theory simon but you need to get it out on the trails! I'm sure you'll find the shock feels so much better with a lot of sag
    'All over it!'
    Many thanks dipper. Once I get the bike built, I will bear your thoughts and settings in mind. Now just waiting for the snow to melt here in the midlands so I can work with the shock at Chicksands and hopefully find a medium where I can virtually set and forget.
    i had way too much sag last weekend on the 450# spring. AM no more, more like a chopper
    the 500# spring felt better on monday night, but it was too snowy to get some fast rock into the run.
    i'll be taking the 500 and 550 up to kirkers tomorrow - will experiment on LSC / LSR and preload all morning..
