Results 1 to 13 of 13
    Reputation: hammers79's Avatar
    Stripping powder coat from frame
    Has anyone done this? Any tips? Any reasons I shouldn't do it?
    Thanks in advance!
    *Sad face*
    Does anyone want to speculate on how doing this may impact on the warranty, whether the frame would need to be treated to prevent rust?
    It's an Argon CC frame, if this helps in any way.
    Err
    Err is offline
    Calm like a bomb
    Reputation: Err's Avatar
    Mar 2005
    I've done this a few times. You want to completely tear the frame down, remove all bearings, etc. Use a chemical stripper. NO SANDBLASTING!!! This process can be a total PITA, esp with high-quality, well bonded powdercoat. On my last frame, I paid someone to do it. It ran me about $125 for a full suspension DH frame.
    I can't think of any good reason that it would impact the warranty but you'd probably want to ask to be sure.
    Reputation: Midgetman's Avatar
    Nicolai sells raw, i.e. non-coated, non-anodized, frames, so in principle there should not be a problem. Why don't you just call them (or send them an email)?
    Drink...sleep
    Reputation: Boozzz's Avatar
    Aug 2005
    I stripped my Nicolai frame of its powdercoat this summer. Like Err says, a hell of a lot of work, but the result is very nice. Used almost three cans of chemical paint stripper, the kind that you brush on.
    Check out Lightening up the Helius FR for a work in progress pic and New life for the old Helius FR for the end result.
    Thanks for the responses!
    Boozzz - that's pretty much what I'm wanting to do with mine. I hope my frame would look that good stripped. Did you use standard chemical paint stripper, or is there a specific type? Do you have any issues with the frame surface now it's bare?
    Drink...sleep
    Aug 2005
    No issues with the frame surface at all. Give it a light polish every once in a while, and it'll stay nice and shiny. I used the cheapest paint stripper I could find, hardware store's own brand, nothing special. Since the powdercoat is so thick, you have to repeat the process a couple of times. Good luck, wear rubber gloves, and be prepared for a couple of days work
    Cheers for your replies, chaps - they've really helpful, particularly Boozzz's. I'll post up some pics when I'm done!
    The GOAT
    Sep 2012
    I had a frame bead blasted last year and it was a fantastic finish..
    TheDoctor46 - Do you have pictures of the finished product? How much did it cost you? Where did you have it done?
    The GOAT
    Sep 2012
    Cost me £50,00 and some good friends at RnR Powder Coating in Tanfield, Ripon did it for me i will dig out some pictures. If you want me to get it done for you just shout can send frame buy courier and i will take it through and over see its done correctly for you and take pictures
    I've finally finished stripping and rebuilding. I decided to have a go myself in the end. I used nitromers, a wire brush and LOTS of perseverance.
    The majority of the powder coat came off pretty easily (I’d advise to put another coat of nitromers on after the first and wait for visible bubbling of the paint before attempting to get any of it off), but there were some stubborn bits that ended up taking up to 8 coats.
    ‘Before’ photo –
    ‘After’ photo –
    I think it’s worked well. It's pretty bright, but I'm hoping that will fade a bit with exposure to the elements. Thanks to everyone for their advice!
    Good work!! What a difference.
    I wish i could do mine but it's black ano.
