Results 1 to 24 of 24
Thread: Steerer tube
    Nov 2013
    Steerer tube
    Hi everyone I may be being a massive idiot but I've just brought myself a nicolai helius for a build I've been wanting to do for ages, I got it home and noticed the size of the steerer tube I measured it with a vernier gauge and the inside diameter it around 2 inches just wondered where to get headsets for it and what forks I can use
    Many thanks
    Luke
    Nov 2013
    Steerer tube
    Sorry forgot to add some pics
    "El Whatever"
    Reputation: Warp's Avatar
    Any 1.5" headset, external cups is what you need.
    If your fork is 1 1/8" steerer, then you can use adapters.
    Not a real problem, just the hassle of sourcing and spending on parts.
    You can go for a 1.5" steerer fork. There are many nice ones to be had at discount prices.
    Check my Site
    Nov 2013
    Steerer tube
    Warp thank you very much thought I was in trouble
    Drink...sleep
    Reputation: Boozzz's Avatar
    Aug 2005
    If you run a 1 1/8" fork, or a tapered, you can also get an angleset, by Cane Creek or Works Components, to modernize that headangle a bit.
    Nov 2013
    Steerer tube
    Warp would this work?
    Nov 2013
    Steerer tube
    Quote Originally Posted by Boozzz View Post
    Thank you very much think this is going to be a long and hard build but I'm up for it I think
    Drink...sleep
    Aug 2005
    The headset you posted will work if you run a 1.5" steerer fork.
    If you've still got to buy a fork though, I'd recommend the angled headset approach, as the older Helius models had a bit of a steep headangle. I'm running a Works Components set myself. They're not adjustable like the Cane Creek, but more bomb-proof because of it, and a lot cheaper too.
    If you're getting a tapered fork, you could use this for a 1.5 degree change: Works Components 1 5 Degree ZS49 -EC49 - Tapered Steerer Tube Headset
    If you're using a classis 1 1/8" fork, you could even go as far a 2 degrees: 2 0 Degree ZS49 - EC49 - Traditional 1 5 Reducer Headset - External Lower Heacup
    Nov 2013
    Steerer tube
    Ok I'll have a look into it when I get home from work thank you very much for your help and there will probably be many more questions coming your way if you don't mind
    "El Whatever"
    Do you have a fork for your build? Which one if you have one?
    Check my Site
    Nov 2013
    Steerer tube
    Quote Originally Posted by Warp View Post
    No I haven't yet is was looking at rock shox totem maybe not sure yet
    "El Whatever"
    Quote Originally Posted by Lukesh View Post
    A little on the heavy side, but good choice. There are some in 1.5" floating around for peanuts.
    However, the suggestion made before about going with a tapered one with an angleset is spot on.
    A Lyrik in 170mm flavour or a Vengeance or even a Metric would be really cool too.
    Check my Site
    Nov 2013
    Steerer tube
    Yeah think I'm going to go for a tapered fork with the angleset just undecided on what fork as it's one of the biggest decisions along with wheels and crankset for which I'm think race face diablo if I can get hold of them
    Nov 2013
    Steerer tube
    While I'm on here anyone know what year the frame is
    Nov 2013
    Steerer tube
    Hi quick update on the fork situation I may have a set of 2010 rock shox bombers with 1 1/8 tube any thoughts of which is the best way to go with headset my frame has the internal diameter of 48.5mm or 1.910" any help would be much appreciated thanks
    Nov 2013
    Steerer tube
    Sorry bombers on the brain I meant boxxers
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Steerer tube
    I use Orbit E headset on Helius. It is a zero stack lower cup for 1.5" steerer (got a straight one). Allows for 170mm fork with the same ride height as 160 + external cup it is designed for.
    Reputation: Deerhill's Avatar
    Dec 2009
    Quote Originally Posted by Axe View Post
    Do you go through bearings or has it been a non issue?
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by Deerhill View Post
    I clean them up proactively, and it is not very muddy around here. Had not been an issue. I will buy another one if this blows. Not sure - maybe I could swap upper bearing down if lower get pitted.
    Dec 2009
    Same here, think it was the only option when I was looking @2010 with that low stack/taper feature . May have to try it next, bearings in my CC seem pretty big and I've only blasted/dented the rim a couple times
    That frame looks crazy, never seen a seat tube like that
    Axe
    Axe is offline
    Custom User Title
    Steerer tube
    Looks like an older version. Mine is straight. Older ones could benefit from slacker front I think, looking at geometry figures. They slackened it up in 2011.
    Nov 2013
    Steerer tube
    Finally managed to get it sorted over xmas just got it fitted today thanks guys for all the help
    Nov 2013
    Steerer tube
    Coming together now most bits have been ordered just waiting for delivery
    Thanks for all the help guys
    Nov 2013
    Steerer tube
    Quick update on the build if anyone is interested got a few bits in the post today still waiting for the final bits
    Let me know if anyone is interest in seeing more build pics
  1. 1 1/8 Straight Steerer tube To 1.5 Tapered tube Fork Conversion
    By xOffxThexLipx in forum General Discussion
    Last Post: 03-06-2014, 09:25 PM
  2. Steerer Tube Diameter / Stem Steerer Diameter?
    By cirruslk in forum Urban/DJ/Park
    Last Post: 08-27-2013, 03:47 PM
  3. Steerer Tube?
    By Freyzen in forum Shocks and Suspension
    Last Post: 07-13-2013, 07:11 PM
  4. steerer tube extension options for 1.5" steerer
    By bigfoot_mt in forum General Discussion
    Last Post: 12-10-2011, 04:58 PM
  5. 1.5 steerer tube vs. tapered steerer
    By Bikin' Bric in forum 29er Bikes
    Last Post: 06-17-2011, 08:21 AM
