Results 1 to 33 of 33
    SRAM launch 650b using Nicolai's
    SRAM used Sea Otter to launch their new 650b wheelset fitted to Nicolai bikes, read here
    SRAM 650B Rise 40 Wheels - First Ride - Pinkbike.com
    Any one have more details of what frames they used?
    Found an image:
    Gallery: Video: SRAM, RockShox Back 650B Wheel Size - BikeRadar
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Damn.
    I knew I should have waited a little bit with Helius AM order...
    That AC looks pretty normal.
    On the other hand, maybe 26" 2.4 in the rear and 27.5" 2.35 in the front could be a very balanced setup. I was going to buy a new fork anyway.
    Something like 26" Fat Albert or Big Betty rear, 27.5 2.35" Nobby Nic front.
    Attached Thumbnails Attached Thumbnails SRAM launch 650b using Nicolai's-1334894614729-14k17hs8wvsp-800-75.jpg
    Simon, could you find out if this AC has stock angles or is it 650b specific?
    I think spécific, regarding BB height
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by cyril_88 View Post
    That makes sense...
    Do those bikes can clear the new Pacenti 2.4" 650B?? That one looks much larger than any other 650B out there. Like in... a real different wheel size and not a larger tyre trying to be a shorter size just to fit into small tyred frames.
    This quote is kinda funny, in the sense that it doesn't say much...
    " The package was new to us, but one thing quickly became very clear: the 650b wheels feel and handle more like standard 26'' wheels than 29'' wheels. While the impression is clearly going to differ from bike to bike, the new RISE 40 equipped Nicolai didn't give us the 'sitting in' feel that is associated with a well designed 29er, but rather felt very much like a standard mountain bike."
    You can especulate that the frame was not thought for 650B's or that the whole 650B makes not much advantage if any. Really it doesn't say a thing.
    Check my Site
    steep fast and loose :)
    If you want increased grip, drive, climb an bull doze, it simply has to be 29"...
    Seriously, unless you're not adult sized you're on the wrong wheel size....
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by The_Lecht_Rocks View Post
    No. There is no replacement for suspension travel, and fitting 29 wheels in a medium sized frame with a lot of travel is not the best solution. Same for XC bike with aggressive position.
    650b is a good size for long travel bikes.
    [QUOTE=Seriously, unless you're not adult sized you're on the wrong wheel size....[/QUOTE]
    I guess some of us are not. Explains why my grandfather worked in the coal mines... he fit.
    "El Whatever"
    Quote Originally Posted by trekfueler View Post
    Same here... I fit into small equipment manways, so I think I'd rather look elsewhere.
    Seriously, though, I think the various wheel sizes have different applications and according to the size of the individual. Just like toddlers ride 12", bigger kids 16" and so on.
    Why bicycles magically stopped at 26" for MTB's and 700c for road disregarding of size, I dunno.
    That said... why roadies aren't going 32" or 750?? I think you can't fool those guys as easily.
    Check my Site
    "Its All Good"
    Reputation: Whafe's Avatar
    Firstly, great for Nicolai that SRAM have used a Nicolai Frame to launch this...
    Is it all marketing BS... I mean if it isnt much different to 26 inch, why change....
    I tend to agree with TLR... You either stay on kiddie wheels or move to adults wheels, why an intermediate step to teenage wheels.... PPPFFFFFF
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by Whafe View Post
    No it is not. It is an easily noticeable difference. Do you notice the difference in traction between, say running 2.0" tires and running 2.4" tires? Going to 650b is about that or more.
    Bollocks. There is a benefit to a 5% larger wheel, and you can not fit 29" into long travel without a whole lot of compromises.
    Also, 29" inch wheel, equally constructed, is 10% heavier - and 40% less stiff.
    650b is a very nice compromise. Good time to revise the random confluence of events that led to the choice of 559mm bsd wheels in the first place as a standard.
    650B : for 29"curious riders or short arses who aren't adult enough to fit 29"..............?
    Axe
    Axe is offline
    Custom User Title
    Or for people who ride hard enough to use 160mm of travel and appreciate stiff wheels and throwing bike around.
    This whole rhetoric from 29r aficionados reeks of smug and insecurity.
    I agree with Axe and I think there is a place for all three wheel sizes at this time depending on what type of riding you are doing and how tall you are, but I suspect 650b might replace 26" in the long run. The feedback from 650b users has been very positve and even a number of WC XC pros have adopted the intermediate size and won WC events with them. Next I am sure we will see Enduro event riders adopting 650b. I think it is all very positive that there are new standards for us to use. I'm not knocking 29" I just think that the three wheel sizes can co-exist.
    im not sure 3 wheel sizes can co-exist tbh.
    i rode 26" for 25 years and was a complete 29" sceptic.
    i'm a complete convert and see little reason to reduce wheel size less than 29" for what i ride and where i ride.........
    What a creative and insightful comment. Thanks so much for sharing your obvious wisdom.
    Dec 2010
    I have to say I find TLR and Whafe's constant propagandising of the choice they made, and then disdain for the possibility others might like to try - or even ride - something different, a little sad.
    I ride 29er and i beleve in 650b i think it could be better for 140 to 160mm bikes.
    ...and the vertically challenged, such as myself
    like i said, i rode 26" for 25 years, and Im now a 29" convert..........
    i am however 6' tall and trail riding, not hucking or DH......
    650 will suit those not tall enough for 29".
    I am openminded enough that people should ride what they like and suits. I am awaiting 29er for the high speed cornering benefits and small trail chatter smoothing. I am in the 135-145mm travel bracket and don't think there are many compromises to be honest.
    650b size is close to what I have been riding for a while if with a normal tyre. I have always used big 2.4-2.6 tyres, easily equivalent of a 650b 2.1 or small 2.25.
    If you want to run tyres of 2.5 on a 650b then won't similar compromises to those on a longer travel 29er start to exist?
    But generally, live and let live.
    Aka chainline...
    If you do enough reading on this forum or any other "The_Lecht_Rocks" has made posts on, you'll find some of his early posts say how amazing his 26" AM was, read on alittle more and he's getting annoyed with pedal strike, now he's built a 29" bike, which unsurprisingly he loves.
    Im not knocking him, spending a few thousand quid on a bike is a large investment for many. Its understandable that after doing that ones judgement may not be all that objective.
    So i suggest that you don't take what people say about their bikes too seriously. As the "The_Lecht_Rocks" experiences show, at first a new bike is amazing, but then you decide its not so.
    Your fitness and skill play a far bigger part in what a bike will or will not do well. Marketing's job is to make you believe otherwise.
    "Its All Good"
    Axe, you have not quite as yet got my Kiwi sense of Humour. I caught fish with no hook or bait even
    The length of time in which I have had a 29er, it is far from smugness or insecurity. Am very secure in my skin.... I could also say that to make a comment such as: Or for people who ride hard enough to use 160mm of travel and appreciate stiff wheels and throwing bike around...... That reeks of insecurity... My 29er wheels on the Monster Truck are more than stiff, in fact "stiffer than a honeymooners chopper"
    Quote Originally Posted by Axe View Post
    "Its All Good"
    Am sorry if I have come across with "constant propagandising"..... Not the intention at all, for sure it is each to their own... However I feel that an industry tooling up for 3 different wheel sizes will pose some challenges... And also that a 26 inch wheel with a 2.4+ size tyre is pretty close to a 650B size wheel...
    I for sure am the first to give someone that knocks a 29er without having even ridden one... Thats human nature, "don't knock it till you have tried it" Agree ?????
    Quote Originally Posted by tantrumizer View Post
    "Its All Good"
    niknakuk, you make some interesting points, TLR is a crazy Scotsman . Having read a good many of his posts over the years, I would suggest that he is comfortabel enough in his own skin to say straight out if he didnt like his 29er experience...
    Let us not get all that precious over wheel size...
    And agree totally, fitness & skill play a HUGE part...
    Axe
    Axe is offline
    Custom User Title
    It is not about height. For an endurance racing bike with skinny tires, 29" will be perfect for me (I would have ordered RC29 right now for that purpose if it was available and with geometry like El Rey).
    But there is really no replacement for suspension travel. New 160mm 650b Fox would fit nicely on Helius.
    Reputation: dipper's Avatar
    Jun 2005
    TLR is English not Scottish. We only let him stay here out of sympathy for the rest of the English otherwise he'd have been deported long ago!
    www.gravity-sports.co.uk
    flash bikes for flash gits
    Jun 2005
    The 29er ac does a damn good job of feeling like it has more than 120mm of travel but I agree that a long travel 650b sounds perfect for pretty much everything other than maybe long endurance racing which the 29er excels at. Thatll be 4 of us wanting an rc29er now then! Me, you, whafe and pilot. Can't see why it can't be done. Maybe we should start pestering them more
    "Its All Good"
    Quote Originally Posted by dipper View Post
    Whoops my bad, a HUGE sorry to the Scottish.... Anyway, hoping I made my point....
    Am pretty certain if you put an order into Kalle for an RC29er, he would do it. dipper, you would have to give him the geo & numbers etc and am certain it would happen... I have pleaded for 2 different frames now, your turn
    Distributor
    Reputation: nicolai-uk's Avatar
    We have discussed this - the problem is lighter=weaker. Building a longer travel version of something is (relatively) easy, especially if you don't mind a little overbuilding to be on the safe side. Taking an existing frame and shaving weight, even if you're reducing the travel, without compromising strength and rigidity, is not trivial.
    Simon Still
    Momentum Distribution
    www.nicolai-uk.com
    Seems Fox are taking 650b seriously even if TLR and Whafe aren't.
    Quote from 650b Palace:
    Fox add 2 650B Models to Their Line-up
    Fox has finally released information regarding their much anticipated 650B fork. Lucky for us they have given mid-wheel riders 2 flavor to pick from. Both boasting 160mm worth of travel as well as their FIT technology and the new CTD technology (Climb-Trail-Decend) .
    34 Float 650B 160 FIT CTD: 1,990g (4.38lb)
    34 TALAS 650B 160 FIT CTD: 2,070g (4.57lb)
    With only 80g separating their weight you'll be sure to see these on some stellar longish travel trail bikes. Makes me wish I had some real mountain in these parts. Looks like I'll be doing some traveling in 2013.
    "Its All Good"
    Great to hear Fox are taking 650B seriously.... There is not a sh!t show that any long travel single crown 29er forks will be coming through now..... loamyR and Axe will be stoked
    Its all good, its like a huge 3 some of wheel sizes.....
    You will all grow up at some stage and move to adults wheels (Thats a joke in case you didnt click )
