    shock size Helius AC
    Anyone could confirm the shock size of the Helius AC. Is 7.875 - 2.000 correct?? (for an 2011 Fox Float RP2).
    Thanks to all
    7,875 * 2,00 is correct and recommended size. You can use shock with longer stroke too, quite many uses (7,875" * ) 2,25" shocks, inc. me ... If using 2,25" shock, there`s need to do a clearance check (because of potential risk for rubbing seat tube) when using big rear-tyres and the top hole mount with shock.
    Quote Originally Posted by pergamonx
    Thanks again, Pergamonx!! Best to you
    "El Whatever"
    Reputation: Warp's Avatar
    What he said... I use both also. And unless you're on really skinny tryes (1.9"), avoid the upper hole with the 2.25.
    Check anyways when using the middle hole and the 2.25.
    Check my Site
