Results 1 to 6 of 6
    Rohloff any good for AC 29?
    Dear all,
    I plan to finally get an AC29 to have a full-suss companion for my Niner steel hardtail. I have a NoTubes Flow-wheelset with Rohloff hub on the Niner and Im thinking about moving it to the Nicolai. However, Im wondering wether the weight of the Rohloff might have an impact on the characteristics of the rear wheel damping? Also, I would have to go with normal 10mm rear ends instead of 12mm. So what do you think, Rohloff any good on the Nicolai or should I rather go with a normal drive train?
    thanks
    Bjrn
    get your AC fitted with a pinion gearbox =)
    well the idea is that I have the Rohloff already...
    yet another stupid german
    Reputation: raschaa's Avatar
    imho I wouldn't weigh down the rear of such a nimble trail rocket with the extra grams. if you want a gearbox drop the coin on a pinion. otherwise go xx1 or 2x10...
    Distributor
    Reputation: nicolai-uk's Avatar
    Quote Originally Posted by brettsportler View Post
    Dear all,
    I've run Rohloff's on Helius frames for years and it works fine. Moving to a Helius AC Pinion I'd say that I definitely notice the back end being lighter and the change in the weight balance but if you like Rohloff gearing (and I do) then go for it. It does increase the unsprung mass, which, in theory will have a negative effect on the suspension, but the additional weight you're talking about is comparable to a heavy rim and DH tyre combo - no one says the suspension doesn't work on DH bikes.
    Get cable stops to allow you to run conventional gears as well so that you can try both. The only "disadvantage" then becomes the 10mm rear end. However, even DH bikes were using QR rears until recently and no-one died. The rear end on the AC is stiff enough that I doubt anyone can detect a difference. Locating the wheel on a 135mm bolt through rear is a pain as well.
    Simon Still
    Momentum Distribution
    www.nicolai-uk.com
    thanks for your replies. I`m currently checking out the XX1 drivetrain which seems to fit nicely...Ill keep you posted!
  1. My Rohloff is slipping. HELP
    By moose2008 in forum Internal Gear Hubs
    Last Post: 01-18-2018, 06:14 AM
  2. Rohloff 142 x 12
    By TraxFactory in forum Internal Gear Hubs
    Last Post: 11-17-2015, 07:41 AM
  3. Good price on a new Rohloff
    By hunter006 in forum Internal Gear Hubs
    Last Post: 02-12-2013, 05:42 AM
  4. New Rohloff Speedhub
    By justilew in forum Internal Gear Hubs
    Last Post: 02-15-2012, 04:10 PM
  5. Rohloff tensioner
    By ☻☻☻ in forum Weight Weenies
    Last Post: 12-12-2011, 07:35 AM
