Results 1 to 13 of 13
    Jan 2011
    Reset Racing Headset
    Hi,
    I just wondered if anyone knew of where i could obtain spares for a Reset Racing headset, or alternatively if they had any lying around they didn't need. The parts i require are the top 'wedge' ring that sits on the steerer tube against the top bearing race, and the top bearing cover.
    I'm aware that they're not that well known outside of Germany, despite their exceptional quality but i thought i'd ask.
    On the other hand, if i can't get hold of these parts someone may want the parts i do have. Which is everything but the above. It's in good condition with super-smooth bearings and just a couple of cosmetic scratches.
    Reputation: rpm100's Avatar
    Email the factory. If they are unable to mail direct to you I'm sure they will put you in contact with a stockist.
    Failing that, just give the Nicolai factory a call. Bound to have some spares.
    What colour is it?
    Jan 2011
    The top is black
    Jan 2011
    I should also say that the bottom is silver
    Jan 2011
    Quote Originally Posted by rpm100
    Thanks for the advice rpm100, looks like Reset can supply the spares directly. I'm not sure why i didn't just contact them first!
    Ha, all these modern forms of communication, eh?
    Often best just to pick the phone up!
    Had 2-3 correspondence with them and they are very helpful, despite the language barrier.
    Great company. Not sure why they don't start supplying the big boys?!
    Do you the order headsets off Reset direct or a German reseller?
    Jan 2011
    Quote Originally Posted by wpuk
    I have ordered the parts i need from Reset direct. So you may be able to order complete headsets too.
    Thank you, did they deal with you via the phone or email?
    Jan 2011
    I just e-mailed them. Thankfully their English is much better than my German!
    Dankeschön
    Hi - I have a Reset headset installed on my bike as well but I'm not sure if it's adjusted properly. It feels like it's overly damped and doesn't float like any other headset I've ever used. Do you have any installation or set up instructions that you could share?
    Thanks.
