Results 1 to 3 of 3
    rear end off set
    Hello,
    Is the rear end of a nicolai helius FR offset? my seat stays seem to be. If I unload all the bearing they sit nicely. however when I preload the bottom bearning of the link the seat stays seem to move so the left hand one is about half/1 mm or so closer to the seat tube.
    somethings wrong isn't it?
    Distributor
    Reputation: nicolai-uk's Avatar
    They can be. The rear wheel is aligned perfectly with the front - that's what you need for the bike to run true - but that doesn't mean the rear triangle will appear to be perfectly aligned with the seat tube.
    Simon Still
    Momentum Distribution
    www.nicolai-uk.com
    Hi Simon
    Thanks for the speedy responce.
    for example, so long as the shock can move to differnet travel settings on the link freely I shouldn't worry.
  1. Replies: 5
    Last Post: 04-08-2011, 07:09 PM
  2. Replies: 2
    Last Post: 12-14-2007, 11:53 AM
  3. Replies: 11
    Last Post: 07-17-2006, 12:44 PM
  4. Replies: 0
    Last Post: 11-12-2005, 08:47 AM
  5. Replies: 5
    Last Post: 03-31-2004, 06:58 AM
