Results 1 to 44 of 44
    Question about Helius ST size
    Dear All,
    It is so that I em going to order a Helius ST frame from Nicolai in a near soon as a complement to my Helius FR. This bike should be used for pure FR and some DH races. Why a Helius ST when I have a Helius FR? This is of the reason that I em very satisfied with my Helius FR but it feel a liltle bit too large for freeride application.
    My heigh is 185 cm (6' 1") and my Helius FR 2006 is in size L and this size is perfectly for AM-rides. But for freeride it feels a litle bit too large as I mentoined before so I wonder what you guys think about size M for the Helius ST? I need some shorter top tube and a higher front part. This frame should be equiped with MZ 888, MZ ROCCO and probably with a Rohloff.
    Thanks and all the best.
    Miche
    I've just replaced my Medium FR with a Medium ST and the sizing seems spot on for me at 6' 0"
    The new ST certainly feels shorted and higher; but will be just right for DH / FR
    'All over it!'
    Reputation: lornibear's Avatar
    Hi Miche, I am collecting my Helius FR next week in XL and am hoping to build it up to about 35lb. I am just under 6ft 4 and decided on the XL for an all round bike. The frame size seemed a little large intially, but it's only 10mm longer in the HT than my Yeti 575 size large. So I am sure I will be stoked with the slightly larger proportions of the XL.
    Although my FR is not even built yet, I am also contamplating an ST project for late next year. I have the same dilemna. Should I go for a L or an XL? I know Whafe is about my height and he chose the FR in L. I am sure he will give his impressions on here soon.
    If you know the geometry you want, then why not have Niclolai build you a custom frame?
    Oct 2007
    I'm 186cm and the Helius ST in size M feels perfect. L would be too large for my taste.
    I am just under 6'4" and feel that my L FR is correct on the top tube but seat tube is too long. Kinda wish I had got custom geometry and should be something you should consider.
    Err
    Err is offline
    Calm like a bomb
    Reputation: Err's Avatar
    Mar 2005
    I'm 5'8" and rode a Med Helius-ST for the past two seasons. I had no problem with the top tube length, but the seat tube was a little long for my taste. If I ordered another one, I'd opt for as short of a seat tube as I could get away with while still maintaining the ability to get full leg extension with the seat post raised. I'd go with the size Med top-tube again.
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    Quote Originally Posted by Err
    Err, any news on the PM I sent you a while ago?
    I've been looking at this frame and would order a large TT with a small seat tube. Now is it true what I read about the design of these frames that the stand-over stays the same on all models and you really only get a shorter seat tube? I can understand the design of the suspension would have to be altered to get lower stand-over. What if I wanted to order a Helius ST that had a 14 inch BB with a 565mm axel to crown fork. (likely a Totem or 66)
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
    a tight kick sound
    Reputation: boone's Avatar
    Yo Cliffy,
    You could get pretty damn close to a 14" BB with the UFO. Use some big tires, and jack the shock mounts all the way back. I bet you would be around 13.8-14. The thing rides soo sweet I have only ever found one time that I wanted more BB height and even then I stayed out of trouble
    You may even want to ask for a longer TT than the large for a UFO. I am not sure what you like but If I were to get anouther UFO I would want a large for myself. I could see you needing an XL but with a shorter seat tube. Daaaaamn that would be hot!
    Quote Originally Posted by boone
    Yo Cliffy,
    Yeah, I've thought about it. That's my problem. I think too much.
    The design of the UFO ST does allow more flexability for custom geometry, but I'm thinking 4-bar and not SP... Mostly because of the braking benefits of the Horst link. I've also applied my ideas to the Helius FR, but I think my 66 may be too much fork, and it's a bit too enduro for the bike I'm envisioning. Also, I think the stand over would be a little taller than I'd like.
    Here's my dream bike in a nutshell: 180mm travel, 14inch BB, 66 h-angle 45.5 inch WB, 16.5-17 inch C-stays and seat tube size... 28 inch stand-over. I'm used to about a 600mm ETT.
    I'm ready to start my own bike company at this point. The Bottlerocket is close to all these numbers, but I want another inch of travel, better braking performance, and a better constructed frame. (Non-Tai) IS THAT TOO MUCH TO ASK?
    a tight kick sound
    Quote Originally Posted by Uncle Cliffy
    I don't think that is too much to ask at all!
    Couple options: Knolly delerium T with a bigger shock, Canfield Lucky (you prolly already thought about these). OR
    Talk to your boys down there that build frames and ask them to make a FS frame for you
    I dunno...I think half the fun is thinking about all these little bits. Only thing I cannot comment on is the SP vs HL. I think they each have their benfits, I believe it is personal preference and what type of susp you like for diff riding conditions you have.
    Hi All,
    And thanks for the all answears. As I can see from your heigh a Medium would match me best. Some of you point out that the Seat Tube (ST) is too tall for you guys, it is same for my Helius FR there I can feel that the ST is too tall. So, when I place an order on a Helius ST frame I will use the option for approximately 5 cm (2") shorter ST.
    lornibear: I know your dilemma. I my case I would have a litle bit smaller frame for Freeride, Huck and Downhill. And reason for that is to have a better control over the bike in steep descending sections and in air. To AM and enduro riding my Helius FR in size L is perfect, both in climbing sections and in more friendly descending sections (it also works in steep descending sections with a lower speed).
    For a being heigh from 5' 8" = 173 cm to 6' 1" = 186 cm a M size is recommended for a Helius ST as I can see above.
    I found picture over the Helius ST frame at Nicolai-DSK site and here below I add a picure of my Helius FR in the background. Here I can see that the features what I em looking for would be fulfiled. But can ony one tell what size the Helius ST is in? Its looks lika a M but im not sure. My Helius FR is in size L.
    From the picture below I can also see that the Seat Tube is too tall and here I should opt for a smaller one. This experience is based from my Helius FR where could be approximately 5 cm (~2") shorter.
    Thanks and all the best, Miche
    Last edited by Miche72; 01-02-2008 at 06:03 PM. Reason: Adding a picure, some new questions and some conclusions
    Err
    Err is offline
    Calm like a bomb
    Mar 2005
    No momentum at this time on the Helius-SS. I'm riding the 6.6 SS for the time being as it had the exact geometry I wanted, just VPP instead of Horst-Link. So far, I'm in love. I think a Nicolai frame with the geo of the 6.6 SS or a UFO-ST with a Horst-Link rear would be the ultimate for me.
    I'd imagine you could have a Helius-ST at or very close to those numbers. The stocker should come in around 14.15" with a Totem. If you ran a CCDB you could run a bit of extra sag to drop your BB a bit more.
    "Its All Good"
    Reputation: Whafe's Avatar
    I am ever so slightly over 6'3".... I am stoked I went for the Large Helius FR, I have built this bike to be aggresive trail and AM, to Light FR dare I say, it is going perfect for me.
    For sure if I wanted to do 8 hour all day epics, I would have got an XL...
    You may well be better with the medium, you sound like you wish to build a real throw around ST...
    The BB height on my FR with tyres on etc is 37.3 cm, feels good, this thing rails on corners... Me loving it...
    Could be good to talk to Falco at Nicolai, he rides an ST and is around my height, be good to hear his thoughts on sizing too....
    Best of luck
    That's the fork (and shock) I'm thinking of... Now, on the large, I've noticed a 47 inch wheelbase. I'm used to 45.5. The front center measurement seems a bit longer than I like. I'm assuming 30 inches where i'm partial to 29 max... I'm wondering if a shorter top tube would be in order to keep the wheelbase in check? Or maybe a degree steeper head angle?
    This frame uses 135mm spacing in the rear right?
    I am just going through the whole sizing issue myself before I order a Helius ST. I am 6ft 4in and ride an XL size FR which I find perfect with a 90mm stem. Some people have said that going up in travel may result in the next size down being better, but I am not sure? Simon, at Nicolai UK thinks like for like is the way to go, so this is probably what I will do, but run a 60mm stem instead. After Whafe kindly posted a photo of Falco's bike, I have sent Falco an e-mail for his comments and will let you know the answer.
    'All over it!'
    Hey Ryates, any answer on the frame sizes from Germany? I too am interested in this as my FR is an XL. I am definately having an ST next year and am thinking L or XL.
    Hi lornibear, glad you asked because I am really stuck on this issue. I have e-mailed Falco at the factory and asked him to comment. By my rough calculations the slacker seat angle of the ST will result in the seat being 65mm further back with only a post extension of 150mm. This could be partly be offset by using a much shorter stem, but it is still a lot of extra length. Also the top tube length of the XL ST is 5mm longer. The combined effect maybe that it is too long? I am now considering the large. What do you think? I will post Falco's comments when I have them.
    "Its All Good"
    With your comments ryates, i would for sure go with a Large. The ST will move your riding to a different area and realm for sure. Will your FR be more your AM all day ride bike?
    I am absolutely stoked as I said above that I went with a large, along with a 65mm Stem and no spacers under the headstem, some would say it looks slightly small for me. But I assure you it is perfect.
    This last weekend I was in the US of A for work, so took the FR and rode with some peeps in San Diego, we did a huge ride pretty much with loads of climbing, which really hit home that the bike is as perfect as a bike I have had... The Talas fork lowered to 100mm was awesome for climbing... So am peaking in case you hadnt noticed...
    Am not at all saying Simon at Nicolai is wrong at all, just am not of the same opinion. The FR and ST are vastly different in there use factors. You want something that you can throw around in the air, move forward and get your weight up front for cornering etc and probly will not ride it on 8 hour all day epics so to speak...
    Keep us updated, this is an interesting one...
    'All over it!'
    I have just had a brief look at the geometry for the Helius ST. By the figures stated, the comparison between my XL FR to an XL ST are:
    Seat Angle FR - 72.9
    Seat Angle ST - 67.2
    Top Tube FR - 625 + (70mm Stem) 695 effective length
    Top Tube ST - 630 + (45mm Stem) 675 effective length
    For me, the current effective length on the FR is fine. As Whafe quite rightly states, great for all day rides as well as the bike park. With the ST on the other hand, with only 20mm difference between the two, I am not sure the effective length of the ST is good for jumps/freeride/downhill use.
    If I went for a large ST with a top tube length of (610 + 45mm Stem), this on paper would be better numbers with an effective length of 655mm - some 45mm less than my FR.
    So on paper, the ST in large for my height of 6ft 4 (ish) would be better suited for FR/downhilling. What do you all think?
    "Its All Good"
    Lorni - Think you have hit the nail on the head. Would for sure go with a large as opposed to an XL...
    Shorter frame allows for more playing....
    'All over it!'
    Nice pics Whafe, that FR is looking good.
    Falco's comments about his ST:
    I'm 186 an I ride a Helius ST in size M. I mainlly use it for bikepark, dirts, northshore trails and stuff like that. For tours riding or DH racing I would prefer the longer size L frame. For you it's the decision between L and XL.
    Best regards, Falco
    "Its All Good"
    Am still in favour or thinking the Large is the way to go for an ST......... decision decisions
    'All over it!'
    Hey Whafe, I have just spent two days on our local bike park and have just changed the 100mm stem out for a 70mm. What a difference it makes. I have been hitting some jumps which have propelled me and my heft up nearly 4ft to flat and the FR just ate them up. Opted for a little more sag on the CCDB and even on the mini DH runs it was loving it, as was I. Next is some larger volume tyres and I am there.
    On the performance of the FR in XL, I would like to know adjust my views that I posted on here previously concerning the ST. I have put a lot of thought into this and have decided that for me at nearly 6ft 4, the XL ST could be the way ahead. With a 50mm stem, the ST would rock having an effective TT length of 680mm, still some 15mm shorter than my XL FR.
    I have also looked into the Knolly VTach, but am now thinking with a effective TT of 660mm (with 50mm stem), this may be too short for me.
    I had the pleasure of trying a Rocky Mountain RMX size large on the bikepark the other day with a 65mm stem and I can honestly say, for me, it was too short. My knees were not far off the bars and this was with an effective TT of 675mm. It was a lovely plush ride, as you would expect with 203mm of rear travel, but too small for me. So, for me, until someone changes my mind, the ST in XL it will be.
    Hi Lornibear, I think I read somewhere that you said that you would now prefer the FR in large? Have I got this wrong? I am the same height as you (6ft 4in, 1930mm) and currently ride an 05 FR in XL with a top tube of 615mm, compared to the current model which is 625mm in XL or 605mm in large. Your advice would be appreciated since I am now considering an new FR (with extra strengthening for 66 or Totem). As a consequence of the new models, the ST I believe might be discontinued in the near future? Thanks
    'All over it!'
    Ryates, I currently own the XL with a TT of 625mm, which I find comfortable. I was thinking that with the FR stuff I do an ST would have been a nice addition, however now I believe the FR is bad enough for both jobs.
    I have recently put a 50mm stem on the XL and it now feels really nice, albiet it will take time to get used to. I am really on the fence with this sizing, sometimes I feel the L would have been a better option, as Whafe has but then I like the XL and often think a L would be too small. For me, it's either the XL with 50mm stem, or the L with a 70mm stem. Considering my FR is used for everything from long days in the saddle to FR on the bike park I would say for me the XL.
    The XL is good in the air, good on long rides and generally very stiff, very strong and it really does do everything and soaks it all up. For me, the FR is the better bike over the ST. If I decide to change anything now, it may well be swapping the coil Lyriks for a set of Coil Totems. I love my FR and am now totally happy with it, even if I am still hankering after a 1.5inch headset. Go for the FR with a good shock and you have an awesome all round bike that will do pretty much anything.
    Lornibear, thanks, that was very useful info. I will go for XL with 50 or 70 stem , 1.5 headset and 12mm bolt-through and CCDB. What do you think about using Marz. 66 air or 66 coil instead of Totems? Has anybody had any experience of using the 66's with the FR? They are meant to be very plush? And what would be the best model to go for in the 66 range? Any recommendations would be appreciated.
    Also has anybody taken delivery of the new FR with strengthened headset or have any photos they could post?
    "Its All Good"
    Hi ryates.... I am 6'4 and ride a Large FR with a 65mm stem, it rocks, absolutely love it....
    You mention the strengthened headset, are you meaning a 1.5HS... If so, yes I have the 1.5 HS Helius FR with a 1.5 HS Fox 36 Talas, great all round...
    'All over it!'
    Nice ride.....
    Ryates, Whafe indeed has a beautiful example of the FR in size large with the 1.5 headset. I think for guys our height, it is a toss up between the two sizes. I have long wondered if I should have gone for the L but am very happy with the XL as Whafe is with his large.
    So, it all depends on fit and I would reccomend trying before buying. Either way, you will have a nice sized cockpit and one of the best sized FR bikes on the market.
    As for the Marz forks, I have never had any dealings and I am sure there are many people who love them. For myself, the RS forks in my opinion are the best. I run coil lyriks and Whafe runs Fox TALAS with great results, but not many run the totems. I am planning on running the coil totems at 180mm, as from experience, the FR can handle it. Many run the Knolly Dellirum T with 180mm totems so I can't really see a problem with the FR. I understand one of the guys on here plans to run the totem air at 170mm, could be an interesting topic.
    Overall, the FR is so capable with a nice shock, I can' t see any reason why anybody would want to run a dual ring ST at 180mm, but thats just my opinion, many might disagree. Happy hunting
    Hi Whafe and Lornibear, as I understand there is a new version of the FR coming out that incorporates some changes in tube sizing and strengthening around the head gusset. This has been done because of the increasing demand for using 180mm forks. This move will probably make the ST redundant in the long term ( coupled with the arrival of the Ion ST) and enables Nicolai to introduce two further shorter travel Helius models. Sizing has generally changed for 08 with the top tube increasing in length and is now more in line with Turner's sizing I believe?
    Reputation: Karve's Avatar
    Mar 2006
    The Ion St is 230mm and is more of a downhill sledge
    The ST does have 200mm of rear end travel.. the FR even running a 180 fork is a way off that
    I think they will up the front end of the FR to handle a 180 fork (simply because both RS and Marz FR forks are 180 currently) but keep the rear at 170
    Introduce a 150-155 lightweight FR
    The CC will stay at about 130
    It would be nice to see the Fr go to 180mm on the rear and still keep is as pedal friendly as it is but i don't think that running a 2.4 - 2,6 tyre with the current tube configuration you could squeeze much more travel out of the rear end?
    Nice to see the line up continuing to evelove however
    Phaps we should start a new thread for requests and thoughts for improvements to the current line up and or new models
    I have followed all discussions, comments and so on above in this thread and it has been very intressting reading. Thank you guys!
    Now, I em going to place an order on an Helius ST frame in size M with custom seat tube that is 5 - 8 cm shorter (I have to discuss this with Nicolai about the shortening) as soon as possible.
    This frame should be equiped with a MZ 888 in front and MZ ROCO as a rear suspension. And should be used for Huck, FR and some local DH.
    Now to my question, do I need 1.5 steering head? Ufo ST have a 1.5 steering head as default. Is there some one who has some experince about Fett Set?
    Michael N.
    I think the Fett Set is 1 1/8"only. I would go 1.5 and use liners if required.
    'All over it!'
    Hey Ryates, have you made any decision on your frame? Can I ask where you heard that the FR might be altered and when It is likely to be available? I would imagine 2009 but I would be up for one of those
    Hi Lornibear, the FR2 can be ordered now. I believe it comes with 1.5 as standard. I am considering this as an alternative to the ST, fitted withTotems or 66's. If I fitted Totem Solo Airs I think the build weight would come out at around 32lb, which is amazingly
    light for this type of bike. However, I think I will probably go for coils for plushness with
    a slight weight penalty. I know somebody with the Totem Solo Airs and he really rates them. Says they are plush and only weigh 5.5lbs? Most people I have met say go for the
    Totems, but I am still considering the Marz 66's. The 66 airs have the benefit of adjustable travel and I have also read good things about these.????
    Mar 2006
    Quote Originally Posted by ryates
    Where did u hear that? Specs? Pics? Geo?
    Bugga i had to pay extra coin for mine!
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    @ ryates
    Please any Info´s about the "FR2"!!!
    I´ve talked with Falco Mille last week for optionally customize my Helius FR, and there was nothing mentioned in this direction.
    You can now order the new Helius AM, but FR2
    Greetings from Cologne, Germany
    NoStyle
    Mar 2006
    Quote Originally Posted by NoStyle
    can you? Any info on that one lol?
    "Its All Good"
    When I visited Nicolai, there were more or less no 1.5 HS frames being made for Europe, it wasnt seen as an advantage... I see this thinking changing, as with what I am hearing that the 1.5 is becoming more standard...
    I think this is where the strengthening etc is coming from, I very much doubt that big changes to the FR will occur for 09, the changes for 08 were vast, it is a totally different bike to 07, so I say mostly it will be in the Headset size.......
    Hard funkin´ Kraut
    May 2005
    Quote Originally Posted by Falco Mille View Post
    Da wir das Helius FR auf vielfachen Wunsch nun noch stärker gemacht haben, um es mit Freeridegabeln wie Totem oder 66 fahren zu können, ist die Lücke zwischen Helius FR und CC sogar noch größer geworden. Das neue Modell, das diese Lücke schließen soll, wird Helius AM heißen und ab April lieferbar sein. Die ersten Bestellungen für Blind Dates haben wir bereits entgegengenommen. Die Geometrie wird dem Helius FR ähneln, Federweg 140 bis 160 mm, ebenso die kompatiblen Gabelfederwege, bzw. Längen. Das angepeilte Gewicht incl. Dämpfer liegt bei 3,5 kg. Das Bike wird ein long-travel All-Mountain. Für den Freeride Einsatz ist es nicht freigegen. Das Helius AM wird unser Rahmen für alpine Tourer und Vielfahrer ohne Wettkampf Ambitionen. Als All Mountain wird das Helius AM sehr ausgewogenen sein und bergauf genau so gut gehen, wie bergab. Sicherheit und Komfort spielen eine wichtige Rolle, aber auch Leichtfüßigkeit und Effizienz. Das Helius AM ist auch nicht einfach eine ausgedünntes FR oder ein verstärktes CC, sondern ein komplett neu konstruierter Rahmen, bei dem jedes Frästeil neu designt und aufwendig berechnet wird.
    Und fragt mir jetzt bitte keine Löcher in den Bauch. Sobald es weitere Infos gibt, werde ich diese hier veröffentlichen.
    Grüße, Falco
    Hi Karve,
    the new Helius AM should be available in April and Nicolai has received already "blind orders".
    NoStyle
    Hard funkin´ Kraut
    May 2005
    Yes, I agree, think it would be nice to have 1.5 HS and 135 mm Maxle Rear as Standard for the Helius FR in 09, like the Ufo ST, and not for extra charge.
    Greetings
    NoStyle
    Dear all,
    As I understod from your discussion above about the Nicolai Helius bike family there would be a new Helius available in april named Helius AM. Does anyone heard if there would be a new Helius ST also available in april with new and another properties? Should I wait with ordering of a Helius ST frame to april?
    Michael N
    Hard funkin´ Kraut
    May 2005
    Hi Michael,
    I think there is no need to wait! Actually there is no Info from Nicolai refining the ST - at least Eurobike or Interbike will show.
    NoStyle
    NOT Team Sanchez
    Reputation: wasea04's Avatar
    I'm 5'11" and a medium fits me great for Free Ride but a little tight for pedaling on the AM stuff.
    I like bikes.
