Does one of you run a "standard" quick release 5mm RADO with a 10 speed Shimano rear derailleur (shadow, GS) and a 40 teeth sprocket?
I wonder if the clearance between sprocket and upper pulley is big enough. As the clearance depends not only on the derailleur but also on the hangar, I post this here rather than on the general discussion board.
