Results 1 to 32 of 32
    steep fast and loose :)
    Opinion : Air shock fitment to 6" plus travel frameset.
    Tim Flooks told me today that air shocks simply cannot work on a 6" plus frameset
    All to do with the spring rate curve being exceeded onto the ramp up point after 70% of stroke.
    Apparently, higher volume air cans will suffer even greater mid stroke blow through than normal volume cans, as they have less capacity for mid stroke damping than smaller reservoir canisters.
    Of course, he suggests a PUSH Ind. kit will assist in the stroke control [RP23, no Monarch kit just yet] as it replaces the flexible stroke washer internally with a more robust 'shim'...
    To be fair, he made a valid point about the mid stroke blow through being in conjunction with air shocks' inability to provide sufficient high speed rebound control. The lack of rebound ability means that most air shocks fitted to 6" travel plus bikes, irrespective of leverage ratio, simply causes pack down and the subsequent effects of such.
    Thoughts ?
    Castron BTT Crew
    I completely agree. In fact, I've sold my DHX Air and bought a DHX5 coil, just looking for more compression damping and avoid the mid stroke blow. I will tell the results in few weeks, but looking to other guys in my group which have switched from air to coil in LT bikes, the coil shocks give more robust mid stroke and stability in rough terrains.
    Just to finish, this mid stroke blow would be much more marked in clydesdales about 220lb, like me.
    And please, excuse my english. I'm learning a lot of technical words!
    Reputation: dipper's Avatar
    Jun 2005
    I've got nothing but respect for TF and his knowledge and experience so I guess he's right(with his busy job does he get to ride as much as us though or is this all dyno testing assumptions?). However, I struggle to see the difference most of the time. The HV monarch and the DHX-C feel very similar on the FR. Both suffer excessive blow through of the mid range. Both are very plush. The air can is easier to tune for climbing etc.Not to mention the air can weighs the same as an empty packet of crisps!
    I do feel rebound control is a struggle for those(me included) requiring more spring rate but I have the same issue on my RocoTSTR coil.
    Is TF just talking about ultimate performance for WC DH or is this a general statement that covers trail riding?
    Jun 2005
    Simon
    Why don't we arm ourselves with some spanners and a pile of shocks and go find out for ourselves? We have Monarch Hi and Lo volume shocks, dereks HV RP23 on the air front, Coils we have DHX-C, Roco TSTR and CCDB currently at our disposal.
    I guess the key point here is whether air cans on work on 6" plus bikes. 6" is a lot of travel and it's a reasonable assumption that at this point, you're not just taking a walk in the park but rather tackling some pretty extreme terrain. I've ridden all over the UK and frankly we don't have trails that can't be handled by 5" travel bikes. Heck even most UK DH courses can be ridden competitively on 6" bikes (although that doesn't stop us wanting World Cup DH rigs ).
    Perhaps what TF is saying is that the performance of a 6" bike is seriously hampered by an air can, assuming you're riding it for what it was designed for.
    Jun 2005
    hence my point above
    "Is TF just talking about ultimate performance for WC DH or is this a general statement that covers trail riding?"
    For the riding I do air shocks are sometimes a better proposition. eg. I had no end of grief running a DHXcoil on a turner 6-Pack. Changed to the DHX-A, much the same story. Then to the RP23 and it was a revalation. Horses for courses I think.
    from 0 - sideways 3.2 sec
    Reputation: derekr's Avatar
    My rp23 is great, get a grip and stop trying to fix what isnt actually broken.
    Maybe if you had the ultimate shock setup you'd make yourself what 5 secs faster down the hill?
    I dont race so if it feels good who gives a flying F^%$!!!!
    I do recall your statement Simon "You cant run a coil shock on the AM" So just get a RP23 and bin that RS pooooop, job done...
    I think Richard is right TF are prob making a statement based on ultimate performace for racing downhill.
    Just my 2p worth
    Visit - www.gravity-sports.co.uk - Exclusive high end MTB Products
    Jun 2005
    TLR in 'Not knowing what he wants' shocker
    Jun 2005
    I do know what he needs though!
    derekr - i'm trying to fix the mid stroke blow through , which is broken.
    there's little damping control in the mid stroke, hence the issues with pedal strike and stroke wallow, especially when pro-pedal is off.
    i don't race, but have spent a fortune on the rig, hence a desire to tune it so that it works optimally.
    dipper - he's talking about optimisation for trail riding, not racing. he is categoric that air shocks are wrong for 150mm plus framesets. they cannot deliver mid stroke control due to their construction. coil inc. shim stacks are the only controlling method he's proven to be tuneable and workable. understandably. lets take those spanners up the hill and find out my good man
    Do you know how to use a spanner?
    I get what your saying, I find the AM+RP23 a great combo planted and works well but i am ofcourse easier pleased than you! I'm sure some other combo is even better but i'd rather concentrate on riding the thing and getting used to it than changing it every week (Actually I may have changed alot too ) But i'm happy now!
    That is if Nicolai ever get a mech hanger out to me!!!!!
    Again, it sounds like what TF is saying is that if you have an air shock on a 150mm+ bike, then it won't be working properly, although that may not be a problem.
    My suggestion was that if it's not working properly and you can't tell the difference, then you don't need 150mm+ in the first place and you may as well run a lighter bike with less travel.
    Of course the beauty of the AM is that you can do that without having to replace the frame.
    i'm with you geetee - if it ain't working, why have it ? ! ?
    however, me and dipper have planned to hit the hill, spanners and shocks in back-packs and spend a day fettling and taking notes. should happen in a week or so
    "TF too busy to ride?"
    He's the Enduro National Champion 2008 at the night ride three weeks ago he blew me away on his ti single speed and he's 50!
    I have a DHX on my AM and I am finding the same as TLR hence ordered a Stoy off Tim.
    Tim was also one of the original 'back in the day' pro riders. I remember him at the NEMBA races in the very early 90s
    Jun 2005
    like I said, I've got nothing but respect for TF. I send stuff to him regularly. He is a busy boy though, and riding a SS hardly gives him experience of 6" + trail bikes!
    I'm not saying he's wrong. I just think it's too much of a sweeping statement when there's fat too many variables to generalise. I run coil myself but have nothing against a well set up air shock.
    Anyway, I've got a pile of shocks here and all the time in the world to ride so I'll be doing some testing over the next month to see what works best on the FR(for my application)
    Jun 2005
    Garry
    Do you know if Tim is a distributor of BOS gear? If they're as good as the hype I may be interested in selling them myself.
    Maybe we could do a swap for a week or so some time.
    Tf is the importer/distributor in the uk
    Quote Originally Posted by The_Lecht_Rocks
    Thoughts ?
    Why, in contrast to the above comments, newer DH forks for World Cup racing use like the ROCK SHOX "Boxxer World Cup" (http://www.sram.com/en/rockshox/downhill/boxxer/#tab1) make no longer use of coil springs but air as their suspension medium for saving weight, and they seem to be indeed able to control > 6" of travel (tbh 200mm = 7 7/8”) without failure in mid stroke damping? Besides, the "leverage ratio" in the case of a fork is 1:1.
    This is a good point but there are two comments to make in response.
    The first is that if you talk to TF or indeed anyone else professionally involved in DH, about improving the performance of the air Boxxer, they all say that the best way to improve performance is to put a coil in. Now the performance gains may be very much more marginal in a fork than a rear damper, but there is no doubt that it is there.
    The second point, which explains why the performance gain is more marginal in a fork than a rear damper, is that the volume of air being used in fork spring is many times greater than that used in a rear damper. This greater volume of air makes a number of differences.
    First, the increased volume gives better management of heat build up, i.e. there is more air to absorb the heat generated by bump absorption so the overall temperature of the air spring is relatively unchanged.
    Second, the greater volume of air means that the change in spring rate is less progressive.
    The thing with air is that the equations governing the relationship between temperature, pressure, volume etc are not linear. Now I'm not a physics expert, so in simple terms it works like, but perhaps not exactly like, this - if you halve the volume you increase pressure by a factor of four, not a factor of two. If you have a very small air chamber already at very high pressure, then the net effect of a change in volume is far greater than if the original volume were three of four times larger.
    This is also the reason why rear air shocks have a much harder time with heat build up - the heat causes the air to expand and increase pressure, thus changing the spring rate.
    All of these problems can be countered by compression damping, but in a rear shock, you just don't have enough space to control all the variables.
    Quote Originally Posted by geetee1972
    I agree. May be that the "air bladder" technology, patented by CONTINENTAL Automotive, may be helpful in solving some of the above issues (air volume, linearity, heat convection) sometimes in the future. However, besides the constrained capabilities of adjustability, this technology is not ready for MTB DH use yet, and MAGURA will sell the "MX" rear shock exclusively to bike manufacturers and it will not be available in the aftermarket at this time (http://www.magura.com/english/produk...federbein.htm#, see also: http://www.ridemonkey.com/forums/sho...ghlight=Magura).
    Replying to Dippers Q a few responses back. Tim is the UK importer of BOS and it would be good to do a proper back to back test. Saying that I'm still waiting for mine to arrive.
    geetee - i reckon you've nailed the issue regarding heat build up and lack of compression volume control.
    Nice of you to suggest so TLR but I was just regurgitating some one else's brain work ;o)
    Jun 2005
    "I was just regurgitating some one else's brain work"
    now you've spoiled it! I was impressed for a minute there
    well, i'd suggest there'll be advancement in the air shock world , possibly the utilisation of an 'external' higher volume chamber for blow-off and heat dissipation , a la Fox DHX Air, but better construed in the near future.........
    or should i say, i'd like to see advancement........
    Just a thought but what is stopping the manufacturers using part / all of one of the frame tubes as a secondary air can as this space is available for little extra weight and as much volume as required. (ps. patent pending!)
    I think I'll speak to a friend .
    Have any of you guys ridden a Foes with their Curnut high volume air shock? It looks interesting.
    Gary I think there are some designs on the market or perhaps close to being brought to market that do just this. The Maverick is one example but I'm sure I've seen others, Balfa I think had/have one. In those executions, the damper was located inside the main tubes rather than using the tubes themselves as an air damper.
    I think there are a number of challenges with the design, the obvious one being the inaccessibility for servicing, although given that some cars come with air sprung suspension, there must be some way of making it impervious to the elements. The other very real problem is perception - I have a feeling that the MTB community is quite attached to their external damper that they can see, feel, fettle, shim, tune etc. Speaking personally, I think the Maverick looks like a dogs dinner and reminds me of the first raft of (crap) suspension designs using squidgy elastomers or URT approaches which just didn't work. That's irrational I know, but I think we've become very attached to our after market/OEM damper manufacturers like Fox, RS, Manitou and Marzocchi.
    Geetee what I was suggesting was keeping all of the valving and damping in a standard looking unit but this being connected via a very short hose to the tube it is located next to then the air in the frame acts as the spring volume but the standard type telescoping damer does the damping work.
    ps. I agree the maverick looks like a dogs dinner at best!
    I've tried the CCDB on the FR and CC. I like it a lot. I recommend it.
    FWIW, this post should be merged with the Linkage Rate post.
    Moderators - Is this possible ?
    Reason being, the leverage rate issue suggests that the design of the linkage and the action of said linkage marries with the natural characteristic of an air shock.
    This therby suggests it's preferential to run the Monarch or RP23, etc, on the AM..............................
