Results 1 to 5 of 5
    Nonius CC: some questions
    I've seen some pictures of the new Nonius (the one with the bridge between seat tube and top tube); the Nicolai web site has no informations about it. Do you know if the geometry has changed? Anyone who actually rode it?
    Thank you.
    "Its All Good"
    Reputation: Whafe's Avatar
    Hi greb - dumb question, but have you checked this thread out?
    Nicolai Nonius CC - Setup Database
    Yes, thank you. I read that thread and gave a glimpse to the pdf with the frame specifications (which is the same you can download from the Nicolai web site) but I've not understood if it refers to the new or the old model: it contains an image of the old frame while the geometry chart uses an Helius AM or simething like that.
    "Its All Good"
    Hear you on that one, whip an email off to Nicolai, am sure they will help you out.
    Hopefully some peeps with a new Nonius will post up...
    my nonius
    Hi.
    My nonius is 2009 the geometry has not changed, they just add the bridge.
    pdf=>http://whyexfiles.dbap.de/Public/NIC...nius_CC_09.pdf
    Ido
