Results 1 to 8 of 8
    NICOLAI: New Tech Sheets and Manuals
    steep fast and loose :)
    excellent - already had the info, but at least it's all colated in one area now - thanks
    Fat & Single
    Reputation: ozzybmx's Avatar
    thanks Wilhelm , most of its new info to me
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Drink...sleep
    Reputation: Boozzz's Avatar
    Aug 2005
    Wow, you have to use the top hole on the FR to get 167mm travel! Didn't know that, always thought it was for a 50mm air shock and not for a 57mm stroke coil. Karl just confirmed this to me as well. So I've always ridden it in 150mm mode...
    boooz - no, the top hole on a 57mm shock gives 172mm........hence the benefit of running a TOTEM on the FR
    Drink...sleep
    Aug 2005
    Yeah, will change it to the top hole this weekend. Means a slightly higher leverage rate though, so hopefully it doesn't mess too much with the spring I need; titanium is expensive to replace.
    Reputation: dipper's Avatar
    Jun 2005
    boozzz - check the tyre/seattube clearance in the top hole before giving it a try.
    Wilhelm, thanks for posting. It's great to have the new more comprehensive and well laid out tech. info...well done Nicolai.
