• 07-12-2010
    raschaa
    HA and BB height will vary depending on fork A2C dimension and the position of the rear damper sled which can be moved in (I believe it was) 4mm increments...
    If I knew how to get a fairly accurate HA reading I'd measure my L Ion with the Boxxer but I'm not really sure how to go about it...
  • 07-31-2010
    bill34di
    it would be nice at least to measure how much bb height change difference when moving the shock sled lowest to highest.
  • 08-10-2010
    norcosam
    Riding terrain conditions:
    * Rider height, weight, ride style e.g XC, endurance,trail, hucker etc-
    6ft2", 225lbs Dh/Freeride
    * Frame, Size, & Color:ION-st 2008.Large Raw, Red extras
    * Fork:2008 Fox 40 RC2 with 2009 Upper crown
    * Shock, i2i, stroke- Rockshox Vivid 500lbs x 2.75 steel spring
    * Brakes:Avid elixir cr carbon 203mm Fr/Rr
    * Cranks:deity Vendetta
    * Shifter:sram X0
    * Rear Derailleur:sram XO
    * Pedals:Shimano dx spd
    * Stem:Straitline direct mount
    * Handlebar:Easton Monkeylite carbon dh
    * Seatpost: Thomson
    * Saddle:SDG grand prix
    * Bottom Bracket:deity
    * Cassette:Xt 11-32
    * Chain:sram
    * Headset:Chris King steel
    * Grips:ODI lockons with Straitline end caps
    * Front Tire:Maxxis Minnion 2.5 dh st
    * Front Rim/ Spokes:Mavic 823
    * Front Hub/Skewer:Hadley 20mm
    * Rear Tire:Maxxix Minnion 2.5 dh st
    * Rear Rim:Mavic 823
    * Rear Hub/Skewer:Hadley 12x150
    * Cables:
    * Misc:
    * Overall Weight:40+ lbs
  • 09-05-2010
    HeadofaHessian
    How long did it take to get your frames from the time you ordered it to when you had it in your hands?
  • 09-23-2010
    Smirnof
    the black horse..
    steep slopes with rocks, roots and mud, wild trails in the forests... never seen a bikepark:madman:
    * Rider height, weight, ride style: I'm 1,76m, 72 kg, Dh/Freeride, sometimes allmountain.
    * Frame, Size, & Color: Nicolai Ion ST 2009, Small, Black anodised, Red extras
    * Fork: 2009 RockShox Boxxer World Cup with tall upper crown
    * Shock, Marzocchi Roco World Cup RC 350lbs x 3.00 Fox steel spring
    * Brakes:203mm disc- Shimano Saint front, 180mmdisc- Avid Juicy 3 rear
    * Cranks:Shimano Saint
    * Shifter: Shimano Deore
    * Rear Derailleur: Shimano Saint
    * Pedals: Echo red
    * Stem: DaBomb, Boxxer direct mount, white
    * Handlebar: Sunline V1 Limited Edition blue
    * Seatpost: Truvativ XR
    * Saddle:WTB
    * Bottom Bracket: Shimano Saint
    * Cassette: SRAM 11-23
    * Chain: SRAM PG 951
    * Headset: Reset Racing 118 HDAL-2
    * Grips: Prodigy black
    * Front Tire: Intense 909 EX 2 ISO 2.3
    * Front Rim/ Spokes: Sun Ringle Single Track/ DT Swiss
    * Front Hub/Skewer: Novatec 20mm
    * Rear Tire: Maxxis High Roller 2.5
    * Rear Rim/ Spokes: Mavic 325/ DT Swiss
    * Rear Hub/Skewer: Shimano Saint 12x150
    * Cables: -
    * Misc: helicopter tape 3M under cable route
    * Overall Weight: ~ 17.8 kg or less...
  • 09-24-2010
    Whafe
    The ION is still one of the sickest looking DH bikes one can perve at....
    Looks sweet smirnof and welcome to the forums, bombard us with action shots in the monthly action pics thread....
  • 09-24-2010
    Smirnof
    Hey Whafe, why here on MTBR are no reviews about the Ion ST, only quick ratings?
    The frame is too good to be reviewed, I supose...:D
  • 09-24-2010
    norcosam
    Smirnof,That is very nice mate,Love my ION,Have you ridden it yet?
  • 09-27-2010
    Smirnof
    Yeap... i'm riding it since May (but not a single ride in June because it has been raining all month :madman: ), with different pedals and different handlebars. The bike is in a continuous upgrade, so... I change its configuration permanently. Next I'm looking for a titanium spring, a new seatpost/ saddle and for sure a Shimano Saint rear brake, because the Juicy 3 with a 180 mm disc is tired enough from such abuse :rolleyes: .
  • 09-27-2010
    Whafe
    Check out the 2011 Codes, had a wee ride on a mates Knolly yesterday that have a new set on, very nice indeed... In my short ride, better than the Saints, of which are really good..... Me though, am hooked on Magura brakes... Best feel in my book of any brakes....
  • 10-22-2010
    sikocycles
    Thinking of getting on of these frames. How do they ride?
  • 10-22-2010
    geetee1972
    Sikocycles
    They are very neutral, nicely balanced, predictable and easy to get along with. They come up short for their size, so a medium is equivalent to some manufacturers small, but in terms of proportion, they are short back and long front. In many respects it felt a lot like the original Spesh Demo 8, which had a long front centre mated to a super short rear end.
    The suspension is completely unfussy; it just works in the background without making its presence felt. It's not the best of big square edged hits but it's more than good enough. It's at its best over fast, medium sized hits and it ramps up nicely.
  • 10-29-2010
    Smirnof
    Sikocycles, a few words...
    geetee is just right...
    But I would say a few more words.:D The ride on the Ion is quite unique: the short rear offers a more hardtail-ish feeling, and lets you control the front wheel much better, even on steep slopes. In the air is also maneuvrable (altough I'm not a jumper- I prefer staying as much as I can glued to the ground). The 4 bars system is also very well designed so you can pedal up very-very well, even uphill. Again a hardtail-ish feeling. This frame doesn't get you tired even after several descents. But what do I like most of all about this frame? it's the Astonishing Rigidity:eekster: : like walking on a string, you are able to follow up your lines with great accuracy in rock gardens, off-camber sections, wet roots, slippery sections, you'll name it. You can always feel the bike and follow YOUR line, not the gravitational/ inertia line of the bike down the track. It's like holding a surgery knife. All depends on you. :cool: It's so good that you can't even drift with the bike. That's why it's a fast one. When I start drifting, I know for sure it's due to improper tires or excessive/ hard braking.
    And there are so much many things to say...;)
  • 01-10-2011
    northernwig
    Hi all,
    My apologies if this isn't the correct thread for this query, but i'm looking for a little info on the suspension settings. Having just bought an Ion St i'm unsure as to what the different settings do to the suspension. In particular the difference in the two shock positions on the linkage and the effect of moving the shock on the front mounts?
    Any advice would be very mucha appreciated!
    P.S. As soon as i've completed the build i'll post a full spec and photo
  • 01-10-2011
    geetee1972
    Hi Northernwig,
    The top hole gives just over 200mm of travel while the bottom hole gives around 230mm of travel.
    Most people, including the Nicolai World Cup team, run the bikes in the shorter travel setting as the bike is more responsive and gives more feedback this way.
    The effect of travel reduction is acheived by increasing the leverage force on the shock (and therefore reducing the leverage ratio), i.e. more leverage means the rear wheel will move a greater amount through it's travel for each mm of travel on the shock.
    This means you will need to change the spring between the two settings in order to keep the right spring weight.
    The shuttle mounts are not designed for adjusting the geometry of the bike, but moving the shuttle fore or aft, will have this effect.
    Moving the mounts forwards, will raise the rear wheel, drop the bottom bracket and slacken the head angle. However, it may also cause the rear wheel to collide with the seat tube, so doing this is done at your own discrection and you should check to see if the wheel does interfere with the ST or not.
    I doubt you'd need/want to do it though. The bike rides just fine as it is.
  • 01-10-2011
    northernwig
    Originally Posted by geetee1972
    Hi Northernwig,
    Thanks geetee1972, that's just what i was after. :thumbsup:
  • 01-10-2011
    raschaa
    Hey all,
    it's actually 197mm/217mm as stated in the official techsheet. why the hell they say 200/230 on their website probably only Kalle himself knows (I'll try to remember to ask him next time we meet)...
    I myself along with quite a few others in our club (we have 21 Ions going at the moment :eekster: ) have had nice results with the hi-travel position. Depends a lot on riding style, track and weather conditions. The Gates-Nicolai Team Riders do use the 217mm position as well, we get to race with them regularly here in Germany and I tend to keep an eye on things like that ;) Most people can use the same spring with both positions unless your on the very border from one spring rate to another to begin with.
    Yeah, moving the shuttle can be used to vary geo and I used to know the increments by how much the BB height and head angle would change per hole... but alas I have forgotten, that starts to happen when getting close to 50 :D Anyways the default setting is for sure the way to go and as far as I can recollect all that have messed with the shuttle have reverted to default because it is just fine that way!
    Just build it on up and ride it and do some testing of your own....
    Here a pic from our season kick off 2010:
    I can hardly wait for the snow to melt here...
  • 01-10-2011
    samwell
    Just to add my point of view, I've changed the shuttle on the front to lower the BB and I can't get back to the initial setting, it's just too good withe the low BB and the new head angle.
    So my advice is to try and choose what you prefer according to your riding style ! I rode the bike in 230mm, then 200mm and now i'm back since a few months to 230mm. For competition 200 is a bit faster but a bit more physical to control.
  • 01-10-2011
    northernwig
    Thanks all, i guess it's a lot about personal preference, as always! Just a quick question, that's probably obvious, but what is the default position for the shuttle? Is that just when it's aligned with the frame?
  • 01-10-2011
    Karve
    wow look at all those NICs awsome
  • 01-10-2011
    raschaa
    Yepp, in the end its all about what works for you. Default position depends on frame size... what do you have?
    nice huh? that was about 2,5 months in to our sponsorship deal with Kalle. First order was 8 Ion St, 2 Ion G-BoxxII, 1 BMXTB, 1 Helius AM. Recently at our Christmas/Years End Party we totaled 21 Ion ST! plus 3 AFR. Sum suggested retail was 85.000,- Euros :eek: Team Gravity Pilots - Extra Love had top 10 finishers in almost all classes in German and European Downhill Cup. I'll post a pic of the 2011 season kick-off should be about 30 NICs by then :D
  • 01-11-2011
    northernwig
    I have a Medium size frame raschaa.
  • 01-11-2011
    raschaa
    to make things simple here is a pic of an M frame in default position:
  • 01-11-2011
    northernwig
    Thanks raschaa, thats very helpful. Nice colour scheme too!
  • 01-30-2011
    norcosam
    Ion-st
    Few changes.
    Saint cranks,Thomson seatpost,few more red bits
  • 01-30-2011
    ianpinder
    Nice, where did you get the coloured saint bolt from
  • 01-30-2011
    norcosam
    Had the standard gold one re-anodised red.
  • 01-30-2011
    Whafe
    30 Nicolai's that is like music to ones ears.. AWESOME
    So must get us a photo of 30 Nicolai's lined up......
  • 01-30-2011
    Whafe
    Few changes.
    Oh yeah, yumminess
  • 01-30-2011
    raschaa
    will do, if we manage to get all of them together at the same time ;)
    and since we all love looking at Nics, a few pics to whet your appetite:
    (Pics link to german mtb-news.de, klick on "groß" below pic for max resolution)
    The RAW Brigade ;)
  • 02-17-2011
    rpm100
    The most amazing bike I have ever owned. It breaks my heart that its for sale, due to a new project. :(
    PM me if interested.
  • 02-17-2011
    Karve
    whats the new project mate?
  • 02-20-2011
    Leehead3
    Pictures really dont do the bike any justice, i have one sat in my kitchen right now , will post pictures and spec later
  • 04-12-2011
    rpm100
    Sorry if you guys are bored of this bike but a new owner means new bits and bobs! Mainly wider bars (atlas Fr uncut) and new V2's, ti spring to follow.
  • 04-12-2011
    geetee1972
    LOL that really is the MTBR Nicolai User Group 'Bike' isn't it.
    For those who did not either grow up in the UK or if you did, didn't go to a comprehensive secondary school, a 'bike' is a slang term for someone, usually female, who is liberal with he favours, i.e. everyone's had a ride....
  • 05-13-2011
    raschaa
    As promised... from our 2011 season kick-off meeting
    sorry the pic doesn't do all the bikes justice, 24 IonST, 1 IonGB, 1 AFR, 1 AM (another 7 Ion, 2 AM, 1 BMXTB owners couldn't make it)
  • 05-13-2011
    Whafe
    Fantastic shot, more please, cant get enough of those... That is for sure the best pose of Nicolai on the planet all in one spot....
    Thanks for sharing
  • 05-14-2011
    ianpinder
    The best thing about nicolai is that there are 27 nicolais there, and not onr is the same
  • 05-15-2011
    raschaa
    at our club meetings it's like Nic's all over the place :D
  • 05-21-2011
    raschaa
    got some more for ya!
    if you want to see more details klick the pic and choose the max resolution...
    let me know if this is to much "spamming"...
  • 12-24-2012
    samwell
    Here is the last and final update of my Ion, it is now for sale, and I will have to post my new bike in a few moths on another nicolai thread :-)
  • 01-22-2013
    samwell
    Paid spam : if anyone is interested, I created an ad : Nicolai Ion ST size L - Buy and Sell and Review Mountain Bikes and Accessories
