Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 201 to 300 of 817
  1. #201
    steep fast and loose :)
    and measure your static BB height please
  2. #202
    frontier - any measurements yet
  3. #203
    Helius AM - Dizzy Urban Camo & Black
  4. #204
    * Rider height, weight, ride style e.g XC, endurance,trail, hucker etc
    Height 1.83m/6ft; Weight: 105kg/230lbs; Riding Style: Aggressive trail and most likely some DH.
    * Frame, Size, & Color: Helius AM, Large but with a medium seat tube customised to 30.9mm; custom cable routing to accommodate adjustable seat post; Dizzy Urban Camo front, black ano rear, black links and graphics, ISCG tabs.
    * Fork: RS Lyrik Coil
    * Shock, i2i, stroke: Cane Creek 200mm eye to eye, 57mm stroke; 600lb/inch RCS Ti Spring.
    * Brakes: Formula The One with 180mm rotors
    * Cranks: Shimano XT 165mm with the granny ring tabs ground off. Single e13 32t ring
    * Shifters: XTR
    * Front Derailleur: Nah.
    * Rear Derailleur: XTR
    * Pedals: Currently Shimano DX, awaiting some Point One Racing
    * Stem: Thomson X4 50mm
    * Handlebar: Burgtec Ride Wide, 750mm width, 40mm rise.
    * Seatpost: Crank Bros Joplin Remote
    * Saddle: Flite Ti
    * Bottom Bracket: Chris King
    * Cassette: XTR 11-34
    * Chain: SRAM 990
    * Headset: Reset Racing
    * Grips: Odi Ruffians
    * Front Tire: Maxxis Minnion DHF Single Ply Kevlar Bead
    * Front Rim/ Spokes: DT Swiss/Specialized Roval Traverse
    * Front Hub/Skewer: Maxle
    * Rear Tire: Maxxis Minnion DHF Single Ply Kevlar Bead
    * Rear Rim: DT Swiss/Specialized Roval Traverse
    * Rear Hub/Skewer:
    * Cables: Gore
    * Misc: Gamut P20 Chain device.
    * Overall Weight: Confirmed at 32lbs 8oz or 14.7kg
    Attached Thumbnails Attached Thumbnails Nicolai Helius AM - Setup Database-img_0811.jpg
  5. #205
    Dec 2005
    Now that is one seriously sweet AM! It looks unfamiliar with the shortened seattube, not in a negative way though. I so wish I asked for wire guides for an adjustable post!
  6. #206
    mmmmm..........dizzy urban looks just like every other dizzy urban - i'm put off it a bit now - i'm thinlking about anodized green next.....
    31.5lbs is a bit optimistic isn't it ? have you got an on-scales shot for proof ?
    cheers.
  7. #207
    Yeah might be optimistic. The wheels are the key, they are super light at 1450g. I wouldn't use the rear Roval in the Peak/Wales etc, I'd switch to a heavier item.
    Allowing for a few hundred grams of misc, my reckoning brings it in around 32lbs.
  8. #208
    'All over it!'
    Reputation: lornibear's Avatar
    A truely lovely ride there my friend...
  9. #209
    "Its All Good"
    Reputation: Whafe's Avatar
    Sick, looks absolutely hawt..... I am biased towards urban camo though.... TLR is it your time of the month, you love Urban Camo
    Will be great to hear your reviews on this baby...
  10. #210
    I have a similar problem on my intense with a cable routing issue. the gear/brake cable comes off the front end and in an S shape level with the linkage, then the next cable mount is about 100mm down the "seat stay" if you will, so it rubs on the edge.
    This is a technique we use on world rally cars (stolen idea from work)
    Essentially you cut a 5-10mm length of small diameter silicone hose (this is the same type as used to plumb the windscreen washers on most cars), put the cable tie through it so the hose sits at the clicky end, then wrap the cable tie around your frame where you want to create a mount, loop it back through the piece of house hose and then around your brake/gear outer
    and also i used it on my fork to keep the front hose tidy
  11. #211
    Reputation: thepimpmessiah's Avatar
    A new medium AM for drooling over.
    Dipper will recognise this... although it has now been built up.
    Note the new Marzocchi 55 Micro Ti Forks
    I really like this.
    EDIT - I should add that this is not mine. It belongs to a good friend and I AM VERY JEALOUS!
  12. #212
    Reputation: yetiman71's Avatar
    That looks lovely. Nice solid build.
  13. #213
    Awesome mate - very cool. Did you retire the Nucleon then? You'll be flying on the AM having spent so much time grinding around the hills on the Nucleon.
    Would very much like to hear your thoughts on the 55s. Are they the RC3 Ti ones?
  14. #214
    Quote Originally Posted by geetee1972
    Oops - sorry for the confusion. I added an EDIT above to say that it's not mine
    Yes the forks are RC3 Ti - First ride report is that they are good and not that heavy... maybe Dipper weighed them? The owner is a Marz lover so he really had no choice in what forks to put on this bike
    First ride report was very enthusiastic... but he always is
  15. #215
    Brian - whose is it ?
    one of the maniac's ?
    the NE of Scotland is slowly resonating with the sound of Nicolai through it's glens !
  16. #216
    The "Pocket Rocket" is certainly a maniac
  17. #217
    Nae Paddy.............?
  18. #218
    Quote Originally Posted by The_Lecht_Rocks
    nae him
    Another of our number has just ordered an AM though
  19. #219
    Aye - I Ken Far That Is !
  20. #220
    Reputation: # Oxygum #'s Avatar
    I've just received my frame yesterday … I miss the fork and my shock absorber but :
    * Rider :
    - height : 1,77 m
    - weight : 79/80 kg
    - ride style : All Mountain / Enduro ... some time DH light
    Frame, Size, & Color : Hélius AM - Taylor Made (such between S and M and more flat head angle) - Orange anodized for front and chainstay - bright white for seat stay - RD+FD+Hammer - white decals - 12 mm rear axe
    * Fork : Rock Shox Lyric Solo Air MC DH
    * Shock, i2i, stroke : DXH Air 5
    * Brakes : Hope Tech M4 180 mm rear and front
    * Cranks : KCNC
    * Shifters : Sram X0
    * Front Derailleur : Shimano XT
    * Rear Derailleur : Sram X0
    * Pedals : MSC Superflat Ti
    * Stem : Chromag 50 mm
    * Handlebar : Chromag OSX Chrome
    * Seatpost : Gravity Dropper Turbo
    * Saddle : Chromag Lynx Ti
    * Bottom Bracket : KCNC
    * Cassette : XT
    * Chain : Sram
    * Headset : Reset Racing 118 Hdal 2
    * Grips : Oury Lock On
    * Front Tire : Continental Rubber Queen UST 2.4
    * Front Rim/ Spokes : DT Aerolite + Mavix 819
    * Front Hub/Skewer: Chris King Silver
    * Rear Tire : Same as front
    * Rear Rim : same as Front
    * Rear Hub/Skewer : same as front with 12 mm axe
    * Cables : Goodridge kit
    * Misc :
    * Overall Weight : I don't know for the moment ...
    Some pictures (for help me to wait ) :
    >>> More Clowns on more bikes ... more often !
    >>> PTDR (Pump Track Digger and Rider)
  21. #221
    Man, that's THE dream frame! Exactly my color and even same tailoring that I had given it. Happy for you.
  22. #222
    Mar 2006
  23. #223
    You know I am not sure which I dig the most, the colour of the frame or that wallpaper!
    The frame is awesome; good choice to get the white seat stays as it backs off the intensity of the orange ano a bit and gives it a great contrast.
    Intersting about the tailoring. Did you just change the seat tube length with regard to the sizing or is the top tube and wheelbase also different (I know you've also changed the head angle so I guess that would also shorten the TT and lengthen the WB?)
    Come on man - details and buid pics!
  24. #224
    Thanks dudes
    My Tailor :
    - Top tube : 577 mm
    - Seat tube : 427 mm
    - Chainstay : 427 mm
    - Head angle : 67° with 545 mm fork ... but I will ride a 555 mm forck so the head angle will be 66,5° approximatly
    - For the rest : same geo as usual
  25. #225
    Nicolai
    Reputation: AttitudeBikes's Avatar
    this im sure, you are one of the first few owners of an Orange Nicolai...
  26. #226
    hohohohoohoho ! congratulations on orange ano my man - it's a nicolai sexfest at the moment
  27. #227
    now - what colour extra love for orange anodised ?
  28. #228
    Reputation: Karve's Avatar
    Mar 2006
    WOW = what is going on - new nics left right and centre - that is a super sweet colour combo for sure.
  29. #229
    Nicolai
    TLR,
    try green or blue...
  30. #230
    "Its All Good"
    FOCK ME, that is stunning in colour... Build that puppy, she is going to be stunning....
  31. #231
    Reputation: dipper's Avatar
    Jun 2005
    love the ano orange as well. wouldn't have thought of white to go with it but it works really well. green extra love would be stunning as well
    www.gravity-sports.co.uk
    flash bikes for flash gits
  32. #232
    orange and green like a packet of tic-tacs! loving the colour, orange/white is stunning.
  33. #233
    Dec 2005
    Quote Originally Posted by # Oxygum #
    Thanks dudes
    My Tailor :
    - Top tube : 577 mm
    Will not the 555mm fork void warranty? Sweet bike, the white seatstay makes a great combination to the orange.
  34. #234
    # Oxygum # - have you built it up yet ?
    pictures ! i need to see it built !!!!
  35. #235
    @pimpy - have a word with your mate - his front brake hose routing is shoddy [and liable to fail in a crash] !
  36. #236
    Sorry man ... I didn't receive my fork and my shock
  37. #237
    when are they due ?
  38. #238
    when are they due ?
    No date for the fork (grrrrrrrrr) ... i'm waiting a date ...
  39. #239
    Orange anodized is getting me aroused
    That is amazing.
    Please build it and send it to me for testing
  40. #240
    @xoy - keep us updated - i reckon ano red and orange are simply stunning options
  41. #241
    That looks fantastic although I'm not sold on the white stays. Looking forward to seeing this one built.
  42. #242
    from 0 - sideways 3.2 sec
    Reputation: derekr's Avatar
    Looks great, cant wait to see it built up.
    Visit - www.gravity-sports.co.uk - Exclusive high end MTB Products
  43. #243
    agree with you yetimeister - i'd prefer full ano, but the rear stays are an extra €200 in ano alone .
    however, it's a small cost compared to the overall build cost so can easily be "lost" / "justified" [delete as appropriate]
  44. #244
    TLR - Justification isn't the problem, it's trying to find crumpled bank notes from the furthest reaches of my wallet and pound coins from behind the sofa to pay for the damn stuff
  45. #245
    Fat & Single
    Reputation: ozzybmx's Avatar
    Quote Originally Posted by yetiman71
    The best reason of all
    That orange ano looks unreal !!!!!! Very very nice
    Im good with the white chainstays too , when its built the white will add to the Awsomeness Its good to be different !
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  46. #246
    Reputation: rpm100's Avatar
    So how much extra for the new ano finishes then?
  47. #247
    Mar 2006
    According to the order-generator it's 400 €.
  48. #248
    Yeah - €400 Is Expensive, Especially Considering Ano Black Is A No Cost Option ! ? !
  49. #249
    I was looking at the ano blue but 400 euro?
    not being overly familiar with anodizing what would they have to change to anodize something blue instead of black? Tool change? paintshop setup?
  50. #250
    Fat & Single
    its getting a case of ... how good can you afford your nicolai to look ....
    Its not as if they have to go to a bit of hassle to do a camo paintwork....as said before - black or bronze ano is free .... whats with the 400euro charge for any other colour ?
    I think it looks awesome .... but they can stuff it up their ass !
    NICOLAI ... we buy your frames coz we love the build and the ride , they are awesome , dont rip us off mate !!!!!!
    Anodised is anoidised ...... ask Mr Raceface who doesnt seem to have different prices for his colours . His black is the same as red .
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  51. #251
    400 euros.........,
    I believe that to be a lot of money.
    Is the high price, perhaps because Nicolai have to get this finish done by an outside company and they are simply just passing on the cost + a bit for the bother.
    I wouldn't be surprised if the whole coloured ano thing came about because of a one off special request. Having sourced a supplier and fulfilled the order, they have now decided to offer the finish to anyone with enough folded/enthusiasm.
  52. #252
    Been covered on another thread - coloured ano costs extra because it has to be done elsewhere - hence additional costs to cover shipping and out side work.
    If you want it, pay it, if you don't, don't.
    I'm happy to pay money for improved performance or longevity - hence buying a Nicolai
    But I ain't no poser so the fancy colour ways are not for me
  53. #253
    This is the thread that has covered the question previously, pretty rational answer,
    if you cntrl F search word cost it'll give you the jist of the answers (the threads not primarily about ano cost)
    First 2 Anodized 2010 frames arrive at my door!
  54. #254
    Whilst we are on about colour anyone come across a picture of a made up bike thats been sprayed Sky Blue
  55. #255
    Looking through the thread and thinking about adjustable seatposts, seems about 2/3rd dont run one, what do you guys think about them,
    when i get out on the bike it tends to be for all day rides, lots of miles, lots of ups and downs, is the weight penalty offset by having greater utility?
  56. #256
    they're great, but imo [joplin r] very pernickity regarding maintenance.
    i like the idea, just not the hassles.
    i've also broken 2 clamps on mine, but the importer [2pure] have been fantastic with their service.
  57. #257
    Am interested how the Joplin4 turns out, the i950r is the other contender
  58. #258
    My AM is now being built and the only missing part is the seatpost. I decided to go for the i950 for various reasons (mostly due to no side play and colour choices) but it seems they are out of stock for the moment.
    Aesthetically the new Joplin is the best IMO but my LBS just received one and the side play is very noticeable out of the box, so it's immediately out of consideration.
    I will get a thompson elite for now, and I will keep it as a spare when I finally install the i950 since you can never be sure of their reliability.
  59. #259
    Mar 2006
    Quote Originally Posted by wpuk
    FYI
    When / where can I get a KS i950-R adjustable seatpost?
  60. #260
    Reputation: samwell's Avatar
    Mar 2006
    I have a KS i950 for one year on my all day rides bike, and I can't ride without it anymore. If you are tall, don't hesitate and take the KS because it has 125mm of travel, I would even need a bit more. The 400g more are really worth it !
    Never enough singletracks !
  61. #261
    Setup Database Update.
    New Easton CNT DH bars coming next week.
    New 2010 Fox 36 Float R's fitted last weekend.
    Ardent's on CK + 5.1D's.
    Weighing in at 30.8lbs.
    Looking now to reduce the weight to less than 30lbs.
    Full Spec to follow.
    What weight are your AM's ?
  62. #262
    TLR- Ardents i had were excellent trail center tyres but disintegrated on my local rocky descents.
    Thats a good weight
  63. #263
    ardents un-tested properly so far - lots and lots of snow here..........
    hoping to break 30lbs in the next month.
  64. #264
    Jun 2005
    ztr flows run tubeless should get you nearly there. longer storke shock and Ti spring will take you all the way there(assuming you're still on the CCDB?)
  65. #265
    not on the CCDB - Monarch 200 x 51 currently fitted........
  66. #266
    How does it ride with the Monarch.
    Thinking of having a monarch on my AC when i order one.
  67. #267
    Jun 2005
    then yer screwed! to get that last few grams will cost loads and I know how skint you are
  68. #268
    monarch's a great shock. loses small bump sensitivity tho to gain compliance c/f a coil however.
  69. #269
    What Tune is it running?
  70. #270
    that's on a Tune 'A'.
  71. #271
    TLR mine was 29.5lb when I first bought it equipment list is on page 1 of this thread.
  72. #272
    Here you go TLR - a weight weenie tastic 12.6kg (27.8lbs in old money)
    Perfect spec for tiptoe-ing round the trails.
    NOTE - This is not mine. Picture stolen from another forum.
  73. #273
    Quote Originally Posted by thepimpmessiah
    Nice, like the highlights, can you post the spec mate
  74. #274
    I just don't get this weight weenie business.
    Especially on an all mountain bike.
  75. #275
    @rpm - it's about getting strong AND light, irrespective of cost.
    i like a bike to ride agile, with feedback and that's not possible on a kikkassa.
  76. #276
    Putting my first choice build into competitive-cyclist its coming out at 28.5lbs and i would say it compromises on nothing for the riding i do
  77. #277
    should add that at 30.8lbs, mine isn't compromised, but would like to get sub 30lb for full psychological delight
  78. #278
    Jun 2005
    Speaking of pschological delight, it will also make kicking your arse up the hill on my 40 pounder all the sweeter
  79. #279
    Quote Originally Posted by dipper
    HA HA sweet
  80. #280
    Enjoy Dipper!
    Only kick it though........
  81. #281
    Is that why you roll on an afr dipper? So it hurts TLR that little bit more when you mow him over..
  82. #282
    lol @ dipper.
    as everybody knows, it's going down that counts
  83. #283
    All this weight weenie talk is infectious
    Please keep it to yourselves and try not to spread it around
    sub 30lb with a purposeful trail build is possible.
    thinking stans flows in place of 5.1D's and tubes.
    would that lose 1lb ?
  85. #285
    Why?
  86. #286
    Just try to think back to the reason you spent all that money going tubeless in the first place!
  87. #287
    i'm tubeless on my Hummer and Ti456.
  88. #288
    oxygum - build pics ?
  89. #289
    TLR - Flows with rim strips are just under a 1lb lighter than my 823's so I doubt you'd save that much changing from the 5.1 rims. A couple hundred grams at most maybe.
  90. #290
    "Its All Good"
    Just saying, but 200 grams in ones wheels is HUGE....
  91. #291
    Why go with the Flow? Why not go for arch or some of those really funcy carbon AM rims that are starting to appear?
    RaceFace SIXC Carbon Cranks are lighter than XTR.
  92. #292
    "Its All Good"
    Yeah be interesting to see how those Fulcrum Carbon Wheelsets, 3,600 USD (FOCK)
    What about the The Hive Fifteen.G cranks, weigh in at 711 grams.....
  93. #293
    I've been using the Stans Flow rim for several years now and they are excellent for a number of reasons. First, when used tubeless with Maxxis tyres the interface is brilliant - zero problem with getting them inflated and zero problem blowing the tyre off the rim (which can't be said for other rims I've used including the Spesh Roval Traverse).
    Second, the Flow rim is super tough, tough enough to be used competitively for DH racing on relatively tame courses, although they would have a much shorter life than say an 823 if used regularly. For general trail riding, they are about the strongest rim you are ever likely to need IMO.
    They weigh 470g vs. 575g (I think) for DT 5.1d, so yes, 200g saving plus net saving on going tubeless is on offer and as Wharfe says, is huge when saved on wheels. I think you'll also find the Flow tougher than the DT Swiss Cheese rims, which seem to ding at the smallest pebble.
    If you're light, smooth and ride less aggressively, then I'd say the Flow is probably a little overkill and the Arch, which is only about 50g lighter (still a useful saving), would be ideal.
    Bear in mind if you're considering the Mavic 819 that while the weight is 450g, this does not include the heavier external nipples you need. Also the internal width of this rim is less than that of the Flow.
  94. #294
    Second that. Have Flows on CK hubs on the Argon, and they take a battering. Any weight loss though due to tubeless negated by the supertacky Swampthings am running at the moment though! Just had I9's built onto Arch rims, so will be interested to see how they compare. Plus, given how the prices on Stan's rims have come down recently, all in all a very good option.
  95. #295
    Flow's are not indestructable, I've bent a flow rim on the front of my hardtail
    I was doing something silly at the time and probably would have bent anything... I'm obviously a nutter of the highest order
    It's a wee bit buckled but still holding up okay so Flow rims still get my
    These wheels will be transfering across to my AM when it arrives
  96. #296
    sounds like either flow or arch once my 5.1D's die then.
    keeping my XTR cranks on as they're lightish and very strong. i'm happier with the extraction than TRace Face too !
  97. #297
    Simon,
    Have you broken/bucled any 5.1's.
    I went through a lot of them when i had my I9's.
  98. #298
    couple of dings - nowt major.
    i do ride light however being a hartail rider.
  99. #299
    "Its All Good"
    I have seriously beaten the fock out of a few sets of 5.1 rims, never had an issue.... I must be smooth...
    No seriously I have had an awesome run with 5.1's.... In saying that, both by 29ers run Flow rims and they have been awesome, given my wheels on the Jones more of a beating, but am giving the I9 wheelset on Flows a hard time on the Helius AC 29er....
  100. #300
    Feb 2010
    Hello to all - being my first post on here...
    Been out of buying wheels for quite a long time as simply put, my mavic 719s/hope bulbs have held up to years of reasonably hard going trail riding. Are Mavic variants no longer in vogue as such? I chose the 719s purely on a strength/weight ratio and used schwalbe 2.35s - worked very well for me and has kept the weight down. Interested to broaden the topic, without blatantly hijacking the thread (ok so I already have)
