Page 11 of 12 FirstFirst ... 7 8 9 10 11 12 LastLast
Results 251 to 275 of 292
  1. #251
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by Testmaen
    The new "C"-lever can be retrofitted.
    Might as well get one. I already have a 50mm and 57mm shocks on hand.
    Decisions, decisions...
    Check my Site
  2. #252
    Quote Originally Posted by Warp
    Dont think i would bother if i had a "B" lever,run it in the next hole down and be happy with that,Its only 2mm travel difference.
  3. #253
    "El Whatever"
    Quote Originally Posted by norcosam
    Mine is an "A" with the plugged top hole. At any rate, the higher leverages fit better my meager weight.
    Check my Site
  4. #254
    Could you not just drop it to the next hole down from where you run it now.It does depend if you are a heavier rider.
  5. #255
    Mar 2006
    Nick-o-lai,
    have you built it up yet?
  6. #256
    Testmaen - sorry, no not yet!
    Am waiting for some new parts and a new set of wheels (ordered, parts in, not built yet). Planning on going 10 speed so am just waiting to get hold of the X0 stuff, which I don't think will be until October.
    Will post up some frame pics on the weekend. Still haven't had a chance to take any yet.
  7. #257
    Reputation: 5c0tty's Avatar
    Here is the spec on mine...
    Nicolai Helius AC - Setup Database
    Riding terrain conditions: Surrey Hills, Wales and Scotland trail centres, XC, Single Track and much more..
    * Rider info: Height 5ft11 Weight 12.6 stone.
    * Frame: Helius AC Medium in Kawagrun
    * Fork: Fox 32 Float 150mm Custom Kawagrun
    * Shock: Fox RP23
    * Brakes: 2011 XTR Race
    * Cranks: 2011 XTR Tripple
    * Shifters: 2011 XTR
    * Front Derailleur: 2011 XTR
    * Rear Derailleur: 2011 XTR
    * Cassette: 2011 XTR 10 Speed
    * Chain: 2011 XTR
    * Pedals: 2011 XTR SPD
    * Stem: Thompson 50mm
    * Handlebar: Easton EC70 MonkeyLite CNT XC Riser
    * Seatpost: Thompson layback
    * Saddle: SDG Bel Air RL Ti Rail
    * Bottom Bracket: Chris King Black
    * Headset: Chris King satin black
    * Grips: ODI X-Trainer Lock-On Lime green
    * Wheels etc: Roval Traverse EL Disc Wheelset
    * Front Tyre: Bontrager XR4 TLR Team Issue 26x2.2
    * Rear Tyre: Bontrager XR4 TLR Team Issue 26x2.2
    * Inner Tubes: Bontrager Race X Lite 26x1.90-2.125
    * Cables: Shimano XTR
    * Overall Weight: 12.4kg or 27.3lbs
    <a href="http://www.flickr.com/photos/5c0tty/5233878149/" title="P1020895 by redhotgtir, on Flickr"><img src="http://farm6.static.flickr.com/5287/5233878149_3e7a30eab2_b.jpg" width="1024" height="576" alt="P1020895" /></a>
    Nicolai Bikes in the South of England head to..
    http://www.head-for-the-hills.co.uk
  8. #258
    Dec 2010
    I see a lot of different variations here in this thread, almost all of which I am unqualified to assess right now, but would take too long to test, let alone think about much.
    So as a shortcut to thinking much, what do people think of the "default" complete bikes offered on the Nicolai website? Any obvious stuff to avoid or upgrade? Or better off getting the frame and suspension and going from there yourself?
    EDIT: Forgot the link - http://www.nicolai.net/46-1-Helius+AC+kompl.html
  9. #259
    "El Whatever"
    Quote Originally Posted by tantrumizer
    At 4K+ Euro, you'd be better off putting the bike together yourself, IMHO with your own choice of components.
    The complete bikes from Nicolai have solid specs (maybe a little weak at the wheels in the Pro and Elite versions) and I personally would go for the Hope version even when I prefer Magura brakes (for no other reason that I have been using Maguras for over 6yrs now) if I had that kind of money.
    You may see a lot of variation here, but the central theme is the same. A trailbike of ~150mm travel with a mix of sturdy and light parts. It comes down to personal preference.
    Some people put more emphasis on suspension, others in light weight, some prefer Rohloff drivetrains, etc.
    I personally think that the AC is a very versatile bike that is rather easy to build right. But you have to also consider that the average Nicolai rider is someone who has spent some time on other bikes and knows what he/she wants from the bike.
    Check my Site
  10. #260
    Reputation: dipper's Avatar
    Jun 2005
    Complete bikes from nicolai are not available here in the uk qnd suspect further afield. hence they're all custom built.
    As warp says, I don't think they're hard to get right. Biggest decision would be coil or air and sturdy wheels versus light wheels.
    If it's a trail bike you're after I'd err on the side of sturdy as it'll be more fun.
    www.gravity-sports.co.uk
    flash bikes for flash gits
  11. #261
    To add some confusion I took delivery of my 2011 AC and it came with a "B" lever. This is a large frame and after the very helpful importer contacted Nicolai they stated that all 2011 take a 57mm stroke by Large and above have a "B" level and not a "C", good luck finding that on Nicolai's web site!
  12. #262
    Reputation: sdr08's Avatar
    Quote Originally Posted by smh151
    Hi, The link below has been posted on here before by someone else and it clearly shows on the last page that the small and medium frames are fitted with 'C' type levers where the large and XL frames are fitted with 'B' type levers for 2011. Hope this helps.
    http://www.nicolai.net/files/federweg-he-ac-2011.pdf
    Hope this link works.
  13. #263
    Jun 2005
    Unless it's a 29er in which case the small and large use a b and the medium uses a c!
  14. #264
    "B " lever in second hole with a 57mm stroke will be close to a "C" in the top hole.
    Why have they done that
  15. #265
    It's also nice that the small and large have 147mm and the medium and extra large have 146mm. I know its a millimeter so not important its more that they know this and publish it, well if you can find the document anyway. Not many manufactures do this but then they also make it far less confusing as well when ordering a frame and wondering if your shock will fit.
  16. #266
    * Rider height, weight, ride style e.g XC, endurance,trail, hucker etc
    * Frame, Size, & Color:Large,Ano Black,with Red extras
    * Fork:Bos Deville 140mm
    * Shock, i2i, stroke,CCDB 200x57mm Ti spring
    * Brakes:Avid X0 Red--203mm front 183mm rear,with hope floating rotors
    * Cranks:Sram X0,2x10,26-39.175mm,Red
    * Shifters:Sram X0 2x10,red
    * Front Derailleur:XX 2sp,high clamp bottom pull
    * Rear Derailleur:X0 2x10.36
    * Pedals:xtr
    * Stem:Thomson 70mm
    * Handlebar:Truvativ Noir Carbon
    * Seatpost:Thomson Masterpiece
    * Saddle:SDG Bel-air TI
    * Bottom Bracket:Chris king Red
    * Cassette:XX 11-36
    * Chain:Sram 10sp hollow pin
    * Headset:Chris King red
    * Grips:Odo lock on,Ano red clamps
    * Front Tire:Nobby nic 2.25 tubeless
    * Front Rim/ Spokes:Mavic SX
    * Front Hub/Skewer:Mavic SX
    * Rear Tire:Nobby nic 2.25 tubeless
    * Rear Rim:Mavic SX
    * Rear Hub/Skewer:Mavic SX
    * Cables:Black
    * Misc:
    * Overall Weight:Just below 30lbs
  17. #267
    - 22C in last week ...
    Attached Thumbnails Attached Thumbnails Nicolai Helius AC - Setup Database-sivuprofiili.jpg
  18. #268
    "El Whatever"
    Quote Originally Posted by pergamonx
    Sweet... how's the Van doing??
    Check my Site
  19. #269
    2 nice ac's
  20. #270
    VAN is ok. Have not yet had chance to test it in normal temps - allways less or more minus degrees. Changed oil to smoother ones. Perfect for winter conditions, at least that can I say.
    Like those angles now.
  21. #271
    steep fast and loose :)
    pergamonx - it looks really well thought out - when will we get a full ride report ?
    are they the carbon haven wheelset ?
  22. #272
    Quote Originally Posted by The_Lecht_Rocks
    Let`s see
    Wheelset are normal Havens, not carbon ones. Pick those because wanted one lighter set, other three wheelsets are all between 1900g - 2100g. Tyres are not ultralight ones, there`s FA 2,4 TLR Trailstar in front and NN 2,25 TLR Pacestar in rear.
  23. #273
    * Pedals:xtr
    * Stem:Thomson 70mm
    * Cassette:XX 11-36
    * Rear Rim:Mavic SX
    * Cables:Black
    * Misc:
    NICE!
  24. #274
    Dec 2010
    OK, I'll play too.
    * Rider 186cm, c. 87kg, ride style - don't know yet, this and that
    * Frame, Size, & Color: Large, Ano Black,with Red extra love and white decal
    * Fork: Fox 32 Float FIT 150mm RLC
    * Shock: DT Swiss XM 180
    * Brakes: Shimano SLX 180/180
    * Cranks: Hammerschmidt FR (24t)
    * Shifters: Sram X9 2x10
    * Front Derailleur: Must have fallen off somewhere
    * Rear Derailleur: Sram X9
    * Pedals: Kona Wah Wah
    * Stem: Trutativ Stylo
    * Handlebar: Trutativ Stylo
    * Seatpost: Rock Shox Reverb 420mm
    * Saddle: Selle Italia - el cheapo
    * Bottom Bracket: Hammerschmidt
    * Cassette: Shimano SLX 11-34
    * Chain: HG-X
    * Headset: Acros AH07 red
    * Grips: Ergon GA-1
    * Front Tire: Fat Albert Snake Skin
    * Front Rim/ Spokes: Notubes Flow/DT Swiss Aerolite
    * Front Hub/Skewer: Shimano XTR
    * Rear Tire: Fat Albert Snake Skin
    * Rear Rim: Notubes Flow
    * Rear Hub/Skewer: Shimano XTR with the axle from a Saint
    * Cables: ?
    * Misc: I didn't expect to be sent an FR Hammerschmidt (expected the AM), but I couldn't be bothered changing it in the end, due to the raft of logistical hassles it would present. Also, Hammerschmidt pimpkit in red.
    * Overall Weight: I don't know. I don't want to know. It would just make me want to change things.
    This is my first MTB. It's probably totally extravagant for a first bike, but I was swung by someone's signature saying life's too short to ride bad bikes. And why should I ride around my 1500 EUR Cube for 2 years, all the while waiting for my Nicolai? I happily admit I now have all the gear and no idea.
    I wanted a Nicolai, because it was something different (in looks, approach, being not made in Taiwan, no yearly model "updates"), they focus on MTBs, they are German and I like Germany, they have a reputation for durability and the reviews were good. And they can take a Hammerschmidt, the reason I first came across them.
    I wanted an AC because 90% of the time I'll be riding to and in my local hills (not too drastically steep up or terrifying down, 500 vertical metres max) and the rest of the time I'll take it to the Alps and ride lifts up.... and I wanted a single bike for that. I tried an AM and it felt like a smooth-rolling tank. Pretty cool, but probably not needed so much here.
    Being a first bike, I'll be useless for ride reporting, so I won't bother. Suffice to say, unlike all the other bikes I've ridden (from friends, demos or hire), it's the only one that really felt like "my bike". I'm happy.
    The purchase process was frankly a bit of a nightmare. I'm not sure I would buy another Nicolai. I'll have to at least wait until I've forgotten about it.
    Here's a pic from the first ride. Friendly advice welcome on obvious setup mistakes. I asked an LBS to build it and maybe they've missed something. We have to do some work on the cabling soon (shorten brake cables and reroute a couple with some different cable guides).
    Attached Thumbnails Attached Thumbnails Nicolai Helius AC - Setup Database-nic_af.jpg
  25. #275
    Finally Got a Shot of my AC
    Looks bigger in the picture than it really is, although it is a large.
