Results 1 to 13 of 13
    Dec 2005
    Nicolai "Hammerschmidt" welded ISCG tabs, Old or 05?
    Am into the business of buying a new chain guide, but do I have ISCG 05 or Old?
    I chose the welded Hammerschmidt compatible ISCG tabs to my frame, so I do not use the Nicolai Adapter used otherwise.
    I think the ISCG hammershmidt on a Nicolai frame is Old/03
    Reputation: rpm100's Avatar
    I specced my AM the same....
    Mine fits ISCG 03.
    There are N-frames with both ISCG-mounts. Depending what has been ordered. Mine are -05.
    It`s easy to check; measure distance between two holes and check from this
    Dec 2005
    pergamonx, thank you very much, it's really strange though!
    Dec 2005
    I had the ISCG old.
    Reputation: dipper's Avatar
    Jun 2005
    if you specced HS mounts it'll be iscg old(03). it differs from normal iscg old though in that it'll be flush mounted with the bb
    www.gravity-sports.co.uk
    flash bikes for flash gits
    Quote Originally Posted by dipper
    Forgiving ignorance, but does that have any impact on mounting chain devices and such?
    No - at least on mine I have quite happily fitted a Gamut P20 and an e13 LG1+
    Jun 2005
    you might need a bb spacer but thats about it
    If you have any doubt on ISCG type :
    explanation from E13 components web site
    EDIT : ISCG03/old on the left, ISCG05 on the right
    Just curious, why the different standards?
    Mmm, to make us buy more and more?
