Results 1 to 10 of 10
    "Its All Good"
    Reputation: Whafe's Avatar
    Nicolai Argon FR - Setup Database
    Nicolai Argon FR owners please post your setups.
    Potential owners view, compare, drool & gain insight etc!
    Nicolai Linky
    Also "no flames please" you can do that on other posts or create a new one if you need to vent, let this be an information data base to assist not to attack or hinder. We can hopefully build a great source of valuable information.
    Post pictures of your build also......
    Riding terrain conditions:
    * Rider height, weight, ride style e.g XC, endurance,trail, hucker etc
    * Frame, Size, & Color:
    * Fork:
    * Shock, i2i, stroke
    * Brakes:
    * Cranks:
    * Shifters:
    * Front Derailleur:
    * Rear Derailleur:
    * Pedals:
    * Stem:
    * Handlebar:
    * Seatpost:
    * Saddle:
    * Bottom Bracket:
    * Cassette:
    * Chain:
    * Headset:
    * Grips:
    * Front Tire:
    * Front Rim/ Spokes:
    * Front Hub/Skewer:
    * Rear Tire:
    * Rear Rim:
    * Rear Hub/Skewer:
    * Cables:
    * Misc:
    * Overall Weight:
    Nov 2006
    * Frame, Size, & Color: Argon FR, Medium in Ano Bronze
    * Fork: RS revelations Dual air
    * Brakes: Avid Juicy 5
    * Cranks: Shimano Deore
    * Shifters: Alfine
    * Rear Derailleur: Alfine gears
    * Pedals: Shimano SPD
    * Stem: Easton EA50
    * Handlebar: Easton EA50
    * Seatpost: Thomson
    * Saddle: WTB
    * Bottom Bracket: Shimano Octalink
    * Chain: SRAM singlespeed
    * Headset: FSA XL11
    * Grips: Lizard skin lock on
    * Front Tire: Trailraker when muddy, cinder when dry.
    * Front Rim/ Spokes: Mavic XM719
    * Front Hub/Skewer: Hope pro11
    * Rear Tire: Normally Bonty Mud X
    * Rear Rim: Dt 5.1
    * Rear Hub/Skewer: Alfine
    Reputation: yetiman71's Avatar
    Very nice Seagull. Interesting spec. How are you getting on with the Alfine hub?
    Nov 2006
    The hub is ideal for me, its lighter than Rohloff, shifts well and has enough gears for what I want.
    I have an issue where it gets pulled out of the driveside under force though. I've asked Nicolai for some advice, looks like it might need longer dropouts.
    Reputation: Stupordave's Avatar
    Jan 2003
    Argon FR w/Gates Carbon Drive
    Argon FR w/Gates Carbon Drive.
    Attached Thumbnails Attached Thumbnails Nicolai Argon FR - Setup Database-carbon-drive-argon-fr1.jpg
    Reputation: rpm100's Avatar
    very nice. What does she weigh?
    Jan 2003
    No scale...but it's under 30. Feels like most of the weight is in the rear when you pick it up, but you can't feel it when riding or jumping.
    Reputation: akdmonsters's Avatar
    Here is the built of mine, that will be finish in a month:
    * Frame Size: Large
    * Frame Weight: 2.4kg (5.3lb)
    * Color: Black ano. with Red glossy and Black shadow stickers
    * Fork: Bos Deville 140 TRC
    * Brakes: Shimano XT
    * Cranks: Shimano XT
    * Shifters: Shimano XT 9spd.
    * No front derailleur
    * Rear Derailleur: Shimano XTR Shadow
    * Pedals: Crank Brothers candy 1
    * Stem: Easton Haven 55mm
    * Handlebar: Answer Pro Taper AM
    * Seatpost: Specialized Blacklite 2012
    * Saddle: SDG Bel Air
    * Bottom Bracket: Shimano XT
    * Crankset: Shimano XT 34
    * Bash: Straitline red ano
    * Chain Guide: E-13
    * Cassette: Shimano XT 9spd.
    * Chain: Shimano XTR
    * Headset: Chris King
    * Grips: Lizard Skins Peaty
    * Front Tire: Maxxis HR 2.35
    * Front Wheel: Mavic Crossmax ST 2012
    * Rear Tire: Maxxis Larsen TT 2.35
    * Rear Wheel: Mavic Crossmax ST 2012
    * Cables: Gore Ride On
    * Overall Weight: ~12kg (26.45lb.) I hope
    Here are some pictures of my frame:
    After one year...
    * Frame Size: Large
    * Front derrailleur: Shimano XT
    * Pedals: Crank Brothers candy 2
    * Handlebar: Easton Havoc DH Carbon
    * Seatpost: Cannondale G2
    * Crankset: Shimano XT 24-34
    * Chain Guide: E-13
    * Front Tire: Schwalbe Nobby Nic TR 2.25
    * Front Wheel: Mavic XM819/DT Revolution/Hope
    * Rear Tire: Maxxis Larsen TT UST 2.1
    * Rear Wheel: Mavic XM819/DT Revolution/Hope
    * Cables: Jagwire
    * Overall Weight: ~12.4kg - 27,34lbs.
    Nicolai
    Reputation: AttitudeBikes's Avatar
    Nicolai Argon AM Pinion
    Write up:-
    Nicolai Argon AM Pinion 650B ? Green Menace II. |
    * Rider 168cm, weight 75kg, ride style e.g Singapore Trail, Commute.
    * Frame, Size, & Color: Nicolai Argon AM, tailored 650B, Anodized black
    * Fork: 160mm RockShox Pike RCT3, Custom Decals
    * Brakes: Magura Marta SL, Black/grey
    * Pedals: DMR Vault
    * Stem: Atomlab Pimplite 53mm
    * Handlebar: Enve RSR bar
    * Seatpost: Thomson Elite 31.6mm
    * Saddle: Prologo
    * Chain: Gates Carbon Drive Belt System for Pinion
    * Headset: Reset Racing
    * Grips: Inspired Lock Ons, Shorten on Pinion Shifter side.
    * Front Tire: Schwalbe Racing Ralph
    * Front Rim/ Spokes:Atomlab Suprelite SL 650B, Philwood 14G
    * Front Hub/Skewer:Chrisking ISO
    * Rear Tire: Schwalbe Racing Ralph
    * Rear Rim/ Spokes:Atomlab Suprelite SL 650B, Philwood 14G
    * Cables: Pinion
    * misc: Custom Chrome Green Decals
    * Overall Weight:13.8kg
