Results 1 to 14 of 14
    Reputation: eurospek's Avatar
    Nicolai @ Euro Bike 2012
    Pics & content Euro Bike 2012 - Nicolai Ion 16, Helius series and argon AM:
    <iframe src="http://videos.mtb-news.de/embed/player/23275" width="512" height="288" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe><p><a href="http://videos.mtb-news.de/videos/view/23275" target="_blank">Eurobike 2012 - Nicolai Ion 16, Helius-Serie und Argon AM</a> von <a href="http://videos.mtb-news.de/user/view/1173" target="_blank">Tobias</a> - mehr <a href="http://videos.mtb-news.de/" target="_blank">Mountainbike-Videos</a></p>
    konahonzo
    "Its All Good"
    Reputation: Whafe's Avatar
    Thanks for sharing.... Vincent has been spending a heap of time at the gym I think..
    Distributor
    Reputation: nicolai-uk's Avatar
    Simon Still
    Momentum Distribution
    www.nicolai-uk.com
    Feb 2007
    Sorry if this the wrong section. What will be the 2013 Helius TB min-max fork travel?
    Will i be able to customise the TB to accommodate a 150-160 fork?
    Quote Originally Posted by Tazil View Post
    Recommended fork travel for the all-new 2013 Helius TB is 130mm. 160mm is exactly the figure for the 2013 Helius AC 26er and 650B (Helius AC 29" is 140mm).
    Feb 2007
    Quote Originally Posted by Wilhelm6 View Post
    Will there be a 2013 Pinion Helius AC 26er?
    Distributor
    Pinion is available as an option on Argon and Helius frames in all wheel sizes. I've not confirmed with the factory but someone said they'd been told you could NOT have a Pinion on the Ion 16 (though it is possible on the Ion 18 and there are pics on here to prove it)
    Simon Still
    www.nicolai-uk.com
    Of course there will! When you ´re looking in the thread "Anyone got a Helius Pinion AM yet?" you can see that Helius AC PINION 26er (2012 specs) units already have been delivered. Furthermore, the linked poster in my previous post shows a 2013 Helius AC PINION 26er inside the 2013 model range.
    Quote Originally Posted by nicolai-uk View Post
    Ion 16 PINION: Read this post.
    Feb 2007
    I thought the 2013 Helius AC Pinion 26er only hand two travel adjustment 140mm-150 and not four?
    In this thread yes Anyone got a Helius Pinion AM yet?
    You are right (2 travel options for 2013), but mind all of the Helius AC PINION units in that thread have been made still according 2012 (not yet 2013) specs.
    "El Whatever"
    Reputation: Warp's Avatar
    The Helius AC Pinion 2013 really makes my wallet to tremble... Dang, it's soooo sexy!
    The little devil on my shoulder whispers to me "get it, get it!!"...
    Check my Site
    Feb 2007
    So 2013 rocker plate will have 2 travel option over ( 4 travel options) 2012 so that should shave off a little weight yes? Anywhere else on the 2013 Heilus AC 26er losing weight?
    Reason i ask because i wonder if it is possible to build one of those 2013 Helius AC 26er between
    33lbs-28lbs? With adjustable post and 160mm fork and of course Pinion?
    "El Whatever"
    Yes, but we're talking a very few grams. The loss in weight comes from the steel pin being shorter... but you have to use a bit more material to get the rockers close to the shock's eyelet (in aluminum, though).
    Nope. Published weights for the 2013 are 3.18kg (6.99#). The Helius AC 2010/2012 was 2.8kg without shock. So, same weight.
    Yes... somebody did an AM Pinion dead on 33#...
    It has a coil over and no dropper, but you can go the other way around and use a dropper and an air shock.
    Mind you, you'll end up closer to the 33# than the 28#. The weight difference between the AC and AM is roughly a pound.
    Check my Site
