Results 1 to 46 of 46
    Reputation: Midgetman's Avatar
    Why not Arch rims? Might be a good compromise.
    I don't buy Schwalbe tires anymore. They wear down too fast and I've had some that weren't really round (resulting in unstable handling).
    Instead of the short stem I'd buy a bar with more backsweep (Truvativ Noir T30/Stylo Singlespeed/Syntace). It's more comfortable for the wrists, especially with the wide bars often used on 29er bikes.
    steep fast and loose :)
    Help me spec my AC29er
    its due late february.
    so far going for XTR drivetrain [2x10 trail] and Crest or Flows on Nobby Nics.
    Carbon Havoc or Haven bars.
    Thomson 50mm stem.
    Hope Evo Tech X2 Ltd Edition brakes.
    Thomson Post + SDG Edge Flex Ti saddle [my personal fave].
    Thoughts / opinion / recommendations - Your thoughts will be encompassed [probably].....
    I have Flow rims on my Ac 26"er.been good so far.Running I9 hubs and spokes.
    I have Carbon truvativ bars on mine,been no problems but would like slightly wider.
    I have King BB and headset. If buying the King BB i would buy the grease tool aswell,It makes it much easier.I grease mine every 2-3 months.
    Thomson posts are excellent,running a masterpiece on mine,I have a Reverb on order.Will give it a go.
    Adds about 300g though.
    Running Xtr pedals,which were excellent until i clipped a rock with them this afternoon and have managed to damage the spd mechanism.
    Thomson stem--They are the best. Sdg saddles-i have Bel airs.been good to me.
    I think Arch for the Rims and Havoc Carbone for the bar it's a good choice.
    thanks folks - indeed the Arch Ex 29 rim is the choice for me. wider than previous arch and stronger BST....
    any more advice ?
    Dec 2005
    How about some custom made 140mm crank arms?
    What fork you plan to use ?
    Reputation: qbert2000's Avatar
    Quote Originally Posted by mikael_nr1 View Post
    lol, nice
    Fork Fox Float F29 RLC Kashima [of course]....
    165mm is my XTR selection for arm length...........just in case...........
    Dippers demo suffered ZERO strikes, luckily......The AC29 really sits up well, little mid stroke dive, just taught and accurate stroke control - Impressive !
    out with the old........
    in with the new.........
    AM departs tonight........AC due in February
    build's taking shape.
    Confirmed Arch EX on Hope Pro Evo's. Nobby Nic 2.25" Tubeless.
    Confirmed XTR drivetrain.
    Confirmed Hope Evo X2 Special Edition 180/160mm f/r. Floating or Fixed Rotors though ? Wanna keep weight as low as possible....
    Fork still TBC. Looking now at either 34mm Float or TALAS RLC.
    Confirmed Fox RP23 Kashima.
    Carbon Havoc bars although on 34mm fox forks, what flat wide carbon option do I have ? Enve ?
    Tapered Headset TBC - Looking at Hope, but unsure if bottom race should be inset or external....especially if i go for the taller 34mm float although the 34mm float may only be tapered steerer....
    May go 60/70mm on [Hope] stem length..will keep the 50mm thomson for steep / tech days..
    I think the Hope headset doesn't fit. It cannot be inserted deep enough, it's flange is only 10mm and Nicolai asks for at least 12mm insert iirc. I think I'll take a Reset Konan headset for my Argon 29: RESET Steuersaetze
    The Crank Bros. Iodine C headset might also fit, but I'm not sure whether the bearings are a match for those of the Reset headset.
    Bar: Truvativ Noir T30 10S or are 700mm too narrow?
    MTB B'dos
    Reputation: LyNx's Avatar
    Have you considered the RS Monarch PLUS RC3 shock? If my budget was open, for sure I'd get one of those for my Prime, as is it comes with a DHX5.
    Yes, the new Fox F34 series is only offered in a taperd steerer, no straight steerers.
    Quote Originally Posted by The_Lecht_Rocks View Post
    lynx - not really although my old Monarch 4.2 was a brilliant shock - as good as an RP23 if not better at the time......
    dipper - thoughts ?
    F34 only tapered. Warranty void if you use it. Though you probably wont break it. So if you do, don't publish it on here ,
    Takes 1.2 deg off head angle, raises BB by approx 12-14mm with a standard headset and brings the steerer back by 5mm or so as well as slackening the seat angle to 73 deg or so. So it will impact on climbing and weight distribution.
    If you go CC Angleset and slacken it further by a degree to 69.8 deg using the top cup as the offset you put everything back to close to standard in terms of BB height and ST angle.
    Alternatively I believe that Fox will be bringing out a F34 in 120mm flavour, maybe at Sea Otter in April...interim fork?
    If you want to keep the weight down get a German:A excite 29. 120mm, 36mm stantions, yes not a mistake, adjustable travel and...sub 1.6kg...
    You can find a review by guitar ted on twentynineinches.com same guy that reviewed the AC.
    German:A are bringing a sub 2kg 140mm 36 stantion version out in next winter...
    Aka chainline...
    slight changes to spec.
    XTR trail 3x10 and XTR trail brakes. need the option of a full range of gears, but wish shimano did 2x10 in 24/28 ????!!!!????
    avoiding X0 as the arms are carbon and i'm not convinced of carbon cranks.... ?
    possible reverb now or may re-use my old joplin.
    stem will be 50mm thomson with havoc carbon bars. 70mm thomson for long days out.
    float 32 rlc 29" kashima tapered into hope headset.
    rp23 kashima.
    arch ex rims on pro 2 evos and revo's. nobby nic 2.25"
    xtr shifters [why no matchmaker mr shimano ?].
    xtr shadow plus rear mech. xtr 11-36 cassette.
    Reputation: Thylacine's Avatar
    Is there a Syntace 142mm rear axle option?
    What was the final frame price and leadtime?
    No longer member of the bike industry nor society, so don't hassle me.
    Nicolai offer a Rock Shox rear Maxle option - no idea, whether that is compatible to the Syntace standard.
    i've gone for the maxle rear option, iscg and tapered headset.
    no idea on price.
    dont think syntace 142mm is offered on the frame / nicolai's in general AFAIK....
    Currently no syntace 142 option
    Aka chainline...
    whaaaarp !
    it's arrived.
    dipper's sofa is bloody awful, but the frame looks lush :
    photo by the_lecht_rocks, on Flickr
    That is going to be an awesome ride
    Quote Originally Posted by Midgetman View Post
    hope so - i was super-impressed with dippers demo, even tho i was a 29" hater previously......
    xtr trail throughout with 2x10 being the final decision...just got to wait for some bits to arrive before it can get assembled...
    looking forward to it's first ride
    Reputation: Metalheart's Avatar
    2x10 xtr, you'll need the legs of an Olympian for that min...
    Please, please, please tell me when you are heading up the Firmounth coz I want to see YOU ride it
    Oh, it does look lush by the way.
    Quote Originally Posted by Metalheart View Post
    That depends on the gear ratio, not the number of chainrings.
    26/38 11-36....nae bother at all......min......
    "Its All Good"
    Reputation: Whafe's Avatar
    Looking great TLR, cant wait to see this puppy built up, She will be a beauty...
    whafe - cheeers - may i offer an official apology for the wagon wheeler "dis-belief"
    amazing machine, cannae wait to get it built up and ridden
    where is it then TLR? Surely it can't still be 'in build'...
    Aka chainline...
    waiting for some XTR bits...........dipper is aware of the "urgency"...........
    The situation here is even worse. I've prepared everything: wheels built and set up with tires, cassette, and rotors, bar, shifters, brakes, grips, and stem put together, the saddle is already on the seat post - and I'm still waiting for the frame because the powder coating got damaged in the assembling process and has to be replaced. Hopefully, they finish the frame next week. Can't wait for it...
    midgetman - what frame are you going for ?
    Argon CC 29 XL 1.125 kawa green (+Reset HDAL, Reba RLT)
    whooooooop !
    build now commenced.......................................
    MTB B'dos
    Not to be ignorant, but I'm curious what you have to do to mess up a PC finish when assembling a bike? I ask as when I got my first frame test PCd, the first thing I did was smack it on a nice rock to test the finish and it did nothing to it but leave a little white dust which I wiped off.
    I don't know. The damage was done during the assembling at the Nicolai headquarter. So probably when they pressed in the headset? Or maybe the frame just dropped to the floor. But that's only speculation.
    Actually as long as the frame is in A1 condition when I pick it up, I don't care. I just hope that it is finished within the next two weeks because the first race is scheduled for April and I want to get used to the bike before.
    there has been the odd report of nicolais pc being a litttle shonky [very occassionaly]........
    i'd not have worried, taken it and claimed on the warranty if it exacerbated.......
    Hmm, I like the surface quality of my pc main frame better than that of the anodized rear end.
    dipper has played an absolute blinder.
    thanks to gravity sports and their incredible service once again..
    bike ready for it's first ride today !!!
    "Its All Good"
    Well thats all good that it is ready for its first ride today... BUT, what about pictures for us you tease!
    Waiting for my wheels and mechs....
    IMAG0316 by the_lecht_rocks, on Flickr
    Reputation: Momentus's Avatar
    That is a nice looking bike. Like the colour scheme too. ;-)
    That looks like a triple to me...
    Personally I'd have gone for orange extra love but hey ho.
    It looks alright though, even with that steeeeeeep HA...
    tis a triple - dipper convinced me, although i held the middle ring yesterday all day.....
    "Its All Good"
    Me likey, welcome to riding an Adults wheeled bike...
    Really starting to get to k now my new ac29er...
    Brilliant at covering lots of ground in incredible comfort, irons out all trail buzz, massive grip, and exemplary climbing abilities....I'm clearing sections I've not cleared for years, due to the rolling abilities and increased grip......
    Corner grip is crazy, and the whole ride feels brilliantly planted.....and not one pedal strike !!!!
    IMAG0330 by the_lecht_rocks, on Flickr
  1. Blur LT - High spec Al or lower spec carbon?
    By eldiablo in forum Santa Cruz
    Last Post: 09-21-2011, 03:58 PM
  2. another AC29er
    By dipper in forum Nicolai
    Last Post: 01-09-2011, 02:56 PM
  3. GT Zaskar Pro 9r, Upgraded Spec Rockhopper or Spec Epic Comp 29?
    By Magilla_Guerrilla in forum 29er Bikes
    Last Post: 07-05-2010, 12:30 AM
  4. Higher spec sale bike vs. brand new lower spec bike
    By Welsh_rider in forum Bike and Frame discussion
    Last Post: 08-06-2009, 09:36 AM
  5. 2007 Spec Rockhopper vs 2006 Spec Hardrock Pro Disc
    By Danny73 in forum Bike and Frame discussion
    Last Post: 05-30-2007, 06:28 PM
