Results 1 to 5 of 5
    Help me decide about a helius AM :)
    Discovered this bike... like... want....
    1 - What price is a good deal for the frame alone, in good condition second hand or new but 2010 model?
    2 - I'm 175cm tall, 178 wingspan, 77 inside leg. Usually fit medium frames, would the AM in a medium seem about right? I quite like the idea of a more compact bike so would a small be too small for me. I know I really need to demo one to know for sure but any preliminary advice appreciated.
    3 - Whats the general concensus on best suited shock to this frame, balancing cost, weight and performance?
    Many thanks in advance
    hi
    i ride a Helius AM and a Helius AC. the helius am in germany costs 1849. then the frame comes in black anod. or a pulver coat. 1849 = about 2600$
    if you would buy it new you can take an AFR downtube for free. so the frame can take 180mm forks. my AM got this option and it only weights a 100 gramms more. geometry is the same.
    im 173cm and size M is perfect for me.
    which shock u use depents on what you want to to with the bike. for trailriding i would use an air shock. atm i use the rock shox vivid air r2c wit mid tune. the shock works great.
    for enduro or more i would use a coil shock.
    chris
    ...sorry for my english.... im a german potato =P
    Thanks for the reply! I think the size M should be right then. For now I think I'll go for an air shock then, then if I find my confidence gets the better of me and I start launching off cliffs again, a coil it is...
    Currently looking at vivid air r2c / RP23 / Monarch RT3
    BTW, your english is infinately better than my german!
    Cheers
    jep i think M is perfect for you.
    the vivid air r2c has got a great performance. my vivid weights 580 grams .... i also gat a fox dhx 5 with titanium spring. the fox weights 730 grams....
    so the difference is only 150 grams..... but the vivid is cheaper i think...
  1. Replies: 147
    Last Post: 07-01-2012, 09:53 AM
  2. Converting a 2009 Helius AM into a Helius AC
    By geetee1972 in forum Nicolai
    Last Post: 03-27-2012, 01:14 AM
  3. Replies: 12
    Last Post: 11-24-2009, 10:47 AM
  4. Should i get helius FR, help to decide
    By kike666 in forum Nicolai
    Last Post: 05-19-2008, 05:18 AM
  5. Replies: 9
    Last Post: 02-20-2008, 01:33 PM
